Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Deck Plug Tool
  • Please log in to reply
4 replies to this topic
#1
Maurys
Maurys
  • Members
  • 715 posts
  • LocationFort Worth, TX, USA
Several people have mentioned using hypodermic tubing to simulate decking plugs.  Some with greater success than others.  I gave it a try, first with 24 gauge (.022" O.D.) then 20 gauge (.035" O.D.).  While the 24 gauge may be closer to correct scale at 1:48, it was too small to even notice.  The 20 gauge works out to 1.68" at 1:48 scale.  Someone may want to try 22 gauge.  I sharpened the outside edge and twisted a pin in the end to eliminate any burr on the inside (per Ed Tosti's suggestion).  The burr would have caught the "plug" and pulled it out.  To stabilize the tube while tapping with a small hammer, I glued it into a hole in the end of a small piece of doweling.  I suspect occasional honing and de-burring will be required. There is a very small learning curve to get an appropriate plug appearance.  I've not tried it on darkened or oiled deck material (the plug may become invisible) but I think it works well on light colored decks.  One question:  When you cut off a piece of the tubing with nippers, you crush the end.  That means you only get two tools from a length of tubing.  How do you cut it without crushing the end?  Will a jewelers saw cut the stainless tubing?
Maury
  • Ryland Craze, mtaylor, davyboy and 8 others like this
Current diversion:  Anchor Hoy c 1815 - 1825  1:48 scale
Recent Builds:
Fair American:
18th C. Longboat:  http://modelshipworl...pways-by-chuck/
Echo Cross Section:  http://modelshipworl...ction-by-maury/
Emma C. Berry http://modelshipworl...2-pof-by-maury/
#2
dgbot
dgbot
  • Members
  • 5,078 posts
  • LocationRaymond IA
A jeweler's saw will do the job.  any otheer method will deform the tube.
David B
  • mtaylor and Canute like this
Work in progress USS Maine in cardstock.http://modelshipworl...rd/#entry220003
Completed Blockade runner Teazer http://modelshipworl...ck/#entry175967
Completed  The Monitor Lehigh http://modelshipworl...el/#entry203680
Completed Kingston Class MCVD http://modelshipworl...gs-in-progress/
#3
Ulises Victoria
Ulises Victoria
  • Members
  • 1,685 posts
  • LocationMonterrey, Mexico
I use my dremel and a sanding drum. A cutting disk will work too. No crushing whatsoever.
Edited by Ulises Victoria, 03 November 2016 - 03:21 PM.
  • mtaylor, davyboy and Canute like this
Ulises
If you want something you've never had,
you have to do something you've never done.
Current Project Build Log: French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Last finished projectRoyal Ship Vasa 1628
Future projects already in my stash:  Panart: San Felipe 1/75  (most likely my next project);
                                                         Artesanía Latina: HMS Surprise 1/48;
                                                         OcCre: Santísima Trinidad 1/90.
My Wish List: Soleil Royale. Sovereign of the Seas. Amati 1/64 Victory (if it ever comes out :) )
#4
Kurt Van Dahm
Kurt Van Dahm
  • Moderators
  • 633 posts
  • LocationFar West Chicago Suburbs
I have used the hypo needles but found this jewelers tool that a lot of plastic modelers use to replicate flush rivets on aircraft - a deck plug is close to identical in appearance to a flush rivet.  This tool is used in jewelry for setting diamonds into settings by pushing on the small tabs to trap the stone in place so they come in all sorts of sizes.  In the set shown the largest tool piece (in top photo) makes a 0.047" circle when pressed into wood all the way down to sizes I can hardly see (with my optivisor) let alone measure.  I have made impressions in Box wood w/o a problem.
Members who attended the 2014 NRG Conference in St. Louis met John Vojtech, owner of UMM-USA and bought a lot of great tools from him.  The link below is to UMM-USA.  I am sure this can also be found at most jeweler's supply places.
Kurt
http://umm-usa.com/o...roducts_id=1322
  • allanyed, mtaylor, WackoWolf and 13 others like this
Kurt Van Dahm
Director - Chairman
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
#5
Thanasis
Thanasis
  • Members
  • 204 posts
  • LocationGreece-Volos
Hi all.
Here's my suggestion.
When I need to make tiny round shaped pieces of wood (thin plywood) or cardboard, I use the "tubes" from which the antenna of a small radio  is consisted. These tubes  give me some options in diameters.
I have a small one from those  that plumbers are using and if is needed I place a "pad" under the tube when it doesn't fit properly. A small diameter's rod or a toothpick inside the tube, usually supports the cutting.
This tool makes a cut around the tube by turning the tool or the tube and increasing the pressure after some turns. The final cut gives an end with smaller diameter that the rest tube, but with a kind of sharp edge that can be used as a punch tool, for light work.
I think it would worth the try to simulate your decking plugs...
Thx
  • mtaylor, WackoWolf, Belco and 3 others like this
There are no bad or good model makers. There are only less or more experienced.
www.naftomodelismos.gr/English.html
In gallery
Tsernikoperama -  Trechantiri Brachera Bombarda Sabatiera -Tserniki vessel rigged as Penna - NE Aegean Sea Tserniki -Tserniki of Mykonos Island
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
