Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Interesting milling problem
  • Please log in to reply
11 replies to this topic
#1
dvm27
dvm27
  • Members
  • 1,092 posts
  • LocationBaltimore, MD
I have an interesting milling problem regarding the quarterdeck transom. The simple solution is CNC but I don't have this. A router would also accomplish task but, again, do not have one. The transom is rounded up over it's top surface and concave over it's fore surface. I need to create a 3" wide by 2" deep rebate for the quarterdeck planks to land on the fore edge (outlined in pencil). I could slice off this 3" and add a correctly dimensioned filler piece but I'd like to use the full thickness if possible. Any of you advanced millers have any ideas?
Edited by dvm27, 02 December 2016 - 10:01 PM.
  • WackoWolf, Mike Y, thibaultron and 1 other like this
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
#2
mtaylor
mtaylor
    Bilge Rat
  • SPECIAL CONTRIBUTOR
  • 14,228 posts
  • LocationMedford, OR
Greg,
What I've seen in some of the logs is something similar to what I did for the beam sanding.  Set the jig up such that the milled area rests against a mating surface with an opening for the mill to have access to the workpiece.
I'm including two photos ... one of the curved beam jig and one of the waterway jig.  Using the beam jig, I could cut a rebate into the deck beam if I wanted.
I would use a piece like on the waterway jig to keep your fingers away from the cutting tool.
  • WackoWolf, dvm27, druxey and 4 others like this
Licorne - 1755 from Hahn Plans (Scratch) Version 2.0
Triton Cross-Section
USS Constellaton (kit bashed to 1854 Sloop of War (Gallery) Build Log
Wasa (Gallery)
#3
thibaultron
thibaultron
  • Members
  • 575 posts
  • LocationWarrenville, SC
You don't need a mill for the sanding setup, you could also do them on a drill press, or a router table.
  • mtaylor, WackoWolf, dvm27 and 1 other like this
#4
jhearl
jhearl
  • Members
  • 140 posts
  • LocationMilford, Virginia
Ah, but note the OP indicated that the piece is not flat in either plane - the top is rounded up and the forward part is concave. That means the jigs shown above won't work. The cut has to be made in two directions at once. I frankly don't have an idea how to do this, but I'll be interested to see if someone comes up with a workable solution. It's an interesting little problem.
Cheers -
John
  • mtaylor, WackoWolf, dvm27 and 2 others like this
#5
jud
jud
  • Members
  • 1,090 posts
  • LocationLexington, Oregon
Knife and chisels, finishing up with careful sanding.
jud
  • mtaylor, michael mott, thibaultron and 1 other like this
#6
mtaylor
mtaylor
    Bilge Rat
  • 14,228 posts
John... I missed that.  Excellent point.  I guess Jud has the answer.   Or maybe a table of offsets....?  Hmm....
  • WackoWolf and Canute like this
Wasa (Gallery)
#7
dvm27
dvm27
  • Members
  • 1,092 posts
You are correct John. Other than CNC, I could think of no way to mill this. So I sliced it off and replaced with the properly dimensioned ledge. Careful use of chisels might have resulted in a similar result but a slip here or ther would ruin the rest of the piece.
  • davec, mtaylor, WackoWolf and 8 others like this
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
#8
jud
jud
  • Members
  • 1,090 posts
Marks method would have worked it the fence had been raised enough to allow continued sanding until the desired depth was reached.
jud
  • mtaylor, WackoWolf, thibaultron and 2 others like this
#9
reklein
reklein
  • Members
  • 545 posts
  • LocationLewiston Idaho
possibly you could band saw or scroll saw in two separate pieces. Cut a curved side , tape the cutoff back on and cut the second curved side. Then cut the smaller step piece and add it to the larger piece.
Edited by reklein, 05 December 2016 - 05:57 PM.
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
#10
Mike Y
Mike Y
  • Members
  • 987 posts
  • LocationStockholm, Sweden
Mark's method should work in both projections, just with a taller fence.
I ended up cheating and steam bending piece in one projection, but milling it in another projections like TFFM suggests (where the curve would be more visible, hence should be more accurate).
  • mtaylor, thibaultron, Canute and 1 other like this
#11
mtaylor
mtaylor
    Bilge Rat
  • 14,228 posts
I've given this problem a bit more thought... a jig could be made using what i suggested before BUT the base would have be curved (see picture) and also long enough for the entire piece of wood to remain in contact with it.
After watching Michael Mott machine things, perhaps a table of offsets would be easier to generate than making the jig.
  • WackoWolf, michael mott, dvm27 and 4 others like this
Wasa (Gallery)
#12
michael mott
michael mott
  • Members
  • 3,570 posts
  • LocationLake Wabumun, Alberta, Canada
Mark depending on how fine a set of offsets it can get you very close and is quite accurate, then just finish off with some sanding sticks.
Michael
Current builds  Bristol Pilot Cutter 1:8
                                Skipjack 19 foot Launch 1:8
                               Herreshoff Buzzards Bay 14 1:8
Other projects  Pilot Cutter 1:500
                         Maria, Sloop 1:2
Restoration      A Bassett Lowke steamship Albertic 1:100
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
