Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Le Soleil Royal Cabin Layout
  • Please log in to reply
14 replies to this topic
#1
EJ_L
EJ_L
  • Members
  • 1,072 posts
  • LocationWichita, Ks
While researching the cabin layouts for SR, I came across these three scans. While they are exactly what I was needing for the layouts I cannot read all of the words due to the scans being fuzzy. I don't care about the words being in French as I can translate that but, I do need them to be clear enough to read so I can translate. Any help in identifying the source of these scans so I can try to get answers there or if anyone has a better scan that would be great. Thanks!!
  • mtaylor, Archi and Canute like this
"Anchors Aweigh"
-E.J.
Current Builds - La Couronne - Corel &  Le Soleil Royal - Sergal
Completed - Wood - Rattlesnake - Model Shipways, HMS Bounty - Constructo
Member : Nautical Research Guild
#2
cog
cog
  • Members
  • 3,201 posts
  • LocationGelderland, Netherlands
When you look careful you can see pieds and pouces. Have a look here for their current equivalents: https://en.wikipedia...ench_Revolution
at floor level it is spelled longueur, at the sides you'll see haut(eur). Admitted, these latter measures are a bit hard to read ... but at least 5 p (pieds) 6 pouces at the lower left
  • mtaylor, druxey, Canute and 1 other like this
Carl
Builds
Kit Wood
Dolphyn [Corel] 1:68, Higaki Kaisen [Woody Joe] 1:72
Kit Plastic
IJN Musashi [Tamiya] 1:350
Finished builds
Scratch: Sea Witch 1:109
#3
EJ_L
EJ_L
  • Members
  • 1,072 posts
Thanks, Carl. I was thinking that was what the dimensions were and with one, I can come up with a scale for the rest.
I love researching these old ships but it would be nice to find a simple answer on occasion... :P
  • mtaylor and Canute like this
"Anchors Aweigh"
-E.J.
#4
cog
cog
  • Members
  • 3,201 posts
So, what do you call this one, mate !? A hard one to crack :P
  • mtaylor, Canute and EJ_L like this
Carl
Builds
Kit Wood
Kit Plastic
Finished builds
#5
dafi
dafi
  • Members
  • 1,845 posts
  • LocationLudwigsburg Germany
Which of the three Soleil Royal was this?
XXXDAn
  • mtaylor, Archi, Canute and 1 other like this
To victory and beyond! http://modelshipworl...ory-and-beyond/
By the Deep 17 http://modelshipworl...-display/page-4
SMS Trinkstein http://modelshipworl...navy/#entry3314
Finest etch parts for HMS Victory 1:100 (Heller Kit) and other useful bits.
Honorary Member of the Tic-Tac-Man-Appreciation-Society
#6
vossiewulf
vossiewulf
  • Members
  • 83 posts
The blur wasn't a problem, but there just aren't enough pixels here for some of the smallest letters. Regardless I've removed the blur to the extent possible without artifacting. You should be able to read all but a couple lines. At least I could if I was better with cursive French.
#7
vossiewulf
vossiewulf
  • Members
  • 83 posts
Wow, annoying, MSW is resizing that image and reinducing some of the blur.
This one is pushed a tad harder to compensate. But as noted what you need is something twice this resolution to be certain on all the notes.
  • cog, mtaylor, dafi and 3 others like this
#8
EJ_L
EJ_L
  • Members
  • 1,072 posts
Thanks for helping to clear those up. Getting even a few of the dimensions cleared up allows me to make reference points to scale the picture. From there I can get the rest of the dimensions. Just a matter of getting the equivalent measurement in either imperial or metric which was a simple thing thanks to Carl. To scale, I have a handy app on my phone which converts most measurements into any scale you want.
This is the Soleil Royal of 1669.
  • mtaylor, Canute and donrobinson like this
"Anchors Aweigh"
-E.J.
#9
vossiewulf
vossiewulf
  • Members
  • 83 posts
This is what I get and I'm reasonably sure these are correct.
  • mtaylor, Canute, donrobinson and 1 other like this
#10
cog
cog
  • Members
  • 3,201 posts
EJ,
A pouce is a thumb, not an inch (") it's 2.7 cm (1.066"),  It's funny, but those two French units (pied du roy, and pouce) were 1.066 times the size of their British equivalents
Top left segment of the wall looks to me 3p 5p. But you can verify that using the known length
29 pieds = 29*32.48 cm = 941.92
pieds 7*3 = 21 = 21*32.48 cm = 682.08
pouces 16+x 16*2.707 cm = 43.321
pieds + pouces = 725.401 <> 941.92  which means x should be 216.519 cm which is slightly over 2 meters!!! That is odd because when you look at the wooden bars which could be the difference, they,  considering the missing distance, should be 27 cm wide :blink: I'm missing something here
Edited by cog, 24 December 2016 - 09:36 AM.
Carl
Builds
Kit Wood
Kit Plastic
Finished builds
#11
EJ_L
EJ_L
  • Members
  • 1,072 posts
Outstanding guys thank you!!
I'm running into the same addition problems you are. What you have translated out makes sense to me but I think something is off on this drawing. The main thing that makes me think that is at the doorway on the upper left. The opening is calling 4pieds, (4') yet the spacing measurement above between only equals 3pieds, 10pounces (3'-10"). From the way it is drawn, if the opening is truly 4' than the upper measurement should be closer to 4'-3" +/- 1". My guess is that something is either off in the way the ship's angles are compared to what is drawn or the measurements are not as accurate. Being that I work off of architectural plans everyday, I know very well how it is easy for something to get lost in translation or written in wrong. Unfortunately, S.R.'s architect is unavailable for questions at this time. :P
I know I can use what is here to get me in the right ballpark with what I am doing and make it look credible.
I do have another question that someone may be able to answer. On a lot of British models I have seen a checker diamond pattern for the floors. Does anyone know what if anything the french might have done or were they just the wood planking? This is something that I have not seen a good answer on and really wonder if they would have bothered with anything decorative on the floor in the 17th century. Was this just something that came about in later years?
"Anchors Aweigh"
-E.J.
#12
cog
cog
  • Members
  • 3,201 posts
Couldn't the upper wal part be narrower compared to the distance at floor level. At least when you look at the curves of the hull, (tumble home e.a.) ... just a thought
Edited by cog, 24 December 2016 - 09:35 AM.
Carl
Builds
Kit Wood
Kit Plastic
Finished builds
#13
vossiewulf
vossiewulf
  • Members
  • 83 posts
I thought it would be clear, but if not, my foot and inches marks up there are pieds/pouce and I don't think it's to scale, so I wouldn't try measuring the drawing itself.
  • mtaylor and EJ_L like this
#14
cog
cog
  • Members
  • 3,201 posts
E.J.
The top differs from the bottom width if you use 4 pieds as bottom distance between bars you'll get 7*4 = 28 pds * 32.48 cm/pds = 909.44cm which gives you a difference of 32.48 cm. This would result in bars of 4.06 cm wide. As the width between bars might not be equal all over the length of the wall it is still an acceptable assumption (although assumption is TMOAF) hat the top and bottom lengths differ, and you cannot use the measurements from the top for the bottom
Carl
Builds
Kit Wood
Kit Plastic
Finished builds
#15
EJ_L
EJ_L
  • Members
  • 1,072 posts
That is what I was thinking. Knowing that these are not scale drawings, I know they won't be accurate. to measure from. This will however give me a good idea on spacing and relativity for the various features and will eliminate a lot of guess work. I should be able to run with that and build something respectful to what she would have looked like. :)
  • cog and mtaylor like this
"Anchors Aweigh"
-E.J.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
