Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Sealer needed for acrylic paints?
  • Please log in to reply
6 replies to this topic
#1
GemmaJF
GemmaJF
  • Members
  • 34 posts
  • LocationEssex UK
Hi all, very general question regarding acrylic paint to wood. Is a sealer always required? Thinking of acrylic thinned down to airbrush consistency. Seems to me there is a lot of water content there that might not be good for a wooden model held together with PVA. Thoughts and advice appreciated on yes/no and which sealer would work with artists acrylics if it is needed.
Edited by GemmaJF, 03 January 2017 - 07:57 PM.
  • mtaylor, donfarr, thibaultron and 2 others like this
If it is not a challenge, it is just a chore...
#2
Duffer
Duffer
  • Members
  • 358 posts
  • LocationMiddletown, CT, USA
Hi GemmaJF, I use a laquer sealer, then spray the acrylic. Once in a while I will just spray acrylic directly to the wood but I know it will raise the wood fibers that will need to be sanded off.  Then spray again, steel wool it, then a third coat.  Some woods my need a 4th coat.
However, I most often use rattle cans of solvent paint.  The first coat is a primer, then look for blemishes, add filler paste to scratches and dings, sand over all and apply a second light coat of primer, then the finish coat.
Duff
  • mtaylor, thibaultron, Canute and 1 other like this
#3
GemmaJF
GemmaJF
  • Members
  • 34 posts
  • LocationEssex UK
Thanks Duff, I did wonder if not sealing the wood and raising the grain might give an interesting effect for some subjects! I'll try the different ideas you have provided on test scraps and see the results I get before committing to any large areas.
All the best
Gemma
  • mtaylor and Canute like this
#4
Kurt Van Dahm
Kurt Van Dahm
  • Moderators
  • 633 posts
  • LocationFar West Chicago Suburbs
I agree 100% with what Duff said on the subject of the acrylic paints - I no longer use the solvent based stuff.
Don't worry about how "wet" the acrylic is - there just isn't enough to weaken any glue joint.
Kurt
  • mtaylor, Canute and GemmaJF like this
Kurt Van Dahm
Director - Chairman
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
#5
genericDave
genericDave
  • Members
  • 117 posts
  • LocationAustin, TX
Agree with everything said!  I use only acrylic paints because they are so much easier to clean up than enamel paints.  I try to always use a lacquer based primer (I use a light grey one by Tamiya) before I put down any paint. The primer also seems to highlight any defects in the wood - little things I want to fill in or sand down further before I put the actual color on.   I've definitely noticed that I get much, much better finish with that primer on there.
Dave
genericDave
Current Build: Model Shipways Bluenose 1:64
Completed Builds: Model Shipways Phantom 1:96
#6
jct
jct
  • Members
  • 652 posts
  • LocationPittsburgh, PA
Agree with all said, what I started to do is make a thin coat acrylic urethane, that acts like a shellac spit coat but without the solvents.   I mix alcohol/water/urethane at a 25/25/50 ratio and save it in an old pickle jar.  Apply and sand between coats...works great at filling wood grain, then primer and top coat
#7
skifflake
skifflake
  • Members
  • 21 posts
  • LocationSkiff Lake, New Brunswick, Canada
Hi;
     The question I have is what is the appropriate finish when using acrylic paint on restoration projects of early 1900 pond boats. High gloss, simi gloss or flat. Also do you have a US web site for the best brand to purchase. Thanks. Pat
  • mtaylor, thibaultron and Canute like this
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
