Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
MSW Conversion Chart
Conversion Chart inches to mm ruler guides pdf chart
  • Please log in to reply
17 replies to this topic
#1
zeptraderUK
zeptraderUK
  • Members
  • 85 posts
  • LocationWelling, Kent, England
I've been searching my HD for anything left over or that was downloaded prior to the 'disaster', anyway I first found MSW some years back and it helped me like you would never believe, in fact I owe my knowledge to THIS SITE!!
In return I made this conversion chart, nothing that would set the world on fire but it helped me and I remember a few people showing interest. I've attached a picture of it but I do have the pdf which needs to be printed out at 100% to get the full benifit of the rulers on there, so don't print out using this image or you could find the ruler will be out of scale..
UPDATED!!! I've added the PDF file to this post, just print out at 100%, do not scale larger.
Edited by zeptraderUK, 17 February 2013 - 01:31 PM.
  • Chuck, Dan Vadas, Ray and 17 others like this
Colin
Current Build
HMS Victory Cross Section 1:72
HMS Hood 1:200
On Hold
HMS Victory (Full Hull) 1:84
HMAV Bounty
#2
WackoWolf
WackoWolf
  • Members
  • 2,734 posts
  • LocationRhode Island
Thank you, it should help out more than one of us that's for sure.
Wacko
Joe :D
Go MSW :) :)
#3
zeptraderUK
zeptraderUK
  • Members
  • 85 posts
PDF now attached to the first post, and thanks.
Colin
Current Build
HMS Hood 1:200
On Hold
HMAV Bounty
#4
Remco
Remco
  • Members
  • 596 posts
  • LocationThe Netherlands
Thanks Colin that's very useful. I have something similar converting Inches to 1:48 scale millimeters and real size rope circumference to 1:48 scale millimeter diameter. It hangs right in front of me in the works shop as I refer to it very often.
Remco
Attached File  inch to mm and rope circumfence .pdf   28.38KB   796 downloads
  • jim mclay, giku22, Marcus Botanicus and 1 other like this
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
#5
zeptraderUK
zeptraderUK
  • Members
  • 85 posts
thanks Remco, I've downloaded your one which I will pin up next to mine.
Colin
Current Build
HMS Hood 1:200
On Hold
HMAV Bounty
#6
dafi
dafi
  • Members
  • 1,848 posts
  • LocationLudwigsburg Germany
There are some nice apps to help you with: I use "measures light", but there are plenty of others for free.
XXXDAn
To victory and beyond! http://modelshipworl...ory-and-beyond/
By the Deep 17 http://modelshipworl...-display/page-4
SMS Trinkstein http://modelshipworl...navy/#entry3314
Finest etch parts for HMS Victory 1:100 (Heller Kit) and other useful bits.
Honorary Member of the Tic-Tac-Man-Appreciation-Society
#7
Modeler12
Modeler12
  • Members
  • 1,874 posts
I am sorry but it is probably the engineer in me. To convert any inch measure to millimeter (inch to mm) multiply by 25.4.
To go from mm to inch divide the number by 25.4.
If you want an approximate value drop the .4 and do it in your head. Thus 4 inches is 100 mm (approximately).
That number has been in my brain for more than 60 years.
  • trippwj likes this
Jay
Current build Cross Section USS Constitution  http://modelshipworl...s-constitution/
Finished USS Constitution:  http://modelshipworl...n-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
#8
Modeler12
Modeler12
  • Members
  • 1,874 posts
Let me expand a bit on my last post above. But let me start by saying that the metric system is great. It is easy to use and easy to 'visualize' dimensions.
I hate fractional dimensions in the English system. So I usually convert them into the decimal system first. Then it is much easier to visualize how much you are talking about. For example, what is the difference between 13/64 inch and 3/8 inch?
Can you really 'see' how much 13/64 inch is? I can see 3/8 but not 13/64, let alone what the difference is.
Now if you take .375 inch minus .203 inch or .172 inch, I can visualize how much that is. And I can measure it real nicely with my  calipers (it has a dial indicator with markings down to a thousands of an inch).
If I have to convert a dimension of 1 and 13/64 inch to mm I don't use aps, I use my little calculator in the drawer in front of me:
(1+13div64)x25.4 = 30.559 mm. Of course, I would call 30.6 mm being close enough
If your model is in 1:48 scale, you take the full scale dimension (let's say twenty feet) and convert it to mm for your model by doing the same conversion on a calculator: 20 x 12 x 24.5 div 48 = 122.5 mm.
Finally let me give you another example how poor the fractional system is. If you are working with a line that is 0.50 mm thick and you want to know how much that is in inches, you divide the mm by 25.4 which is 0.020 inch. Now would you convert that to fractions of an inch? I don't think so.The closest I come up with is 5/248 inch, which is ridiculous.
BTW. In 1959 the inch was set to be exactly 25.4 millimeters.  Prior to that, it was set at 39.37 inches per meter. The difference is only 0.0002%, or 2 parts per million. That's something we don't have to worry about. But it is interesting that the inch was set to that value, not the millimeter.
Edited by Modeler12, 27 February 2013 - 04:45 PM.
  • iaincwil, Marcus Botanicus, rtropp and 1 other like this
Jay
#9
michael mott
michael mott
  • Members
  • 3,570 posts
  • LocationLake Wabumun, Alberta, Canada
here is my own converter  I have it in Excel  format and is dynamic so if you ad a new dimension row and add the new dimension in the grey full size column the chart will automatically ad all the numbers in each column.
I can only upload a webpage so if anyone want a copy of the file I will happily send you a copy.
This chart is easy to modify and it is great to see the information at a glance.
Attached File  comparison of scales for shipmodels.htm   80.4KB   466 downloads
Michael
  • trippwj, iaincwil, Marcus Botanicus and 1 other like this
Current builds  Bristol Pilot Cutter 1:8
                                Skipjack 19 foot Launch 1:8
                               Herreshoff Buzzards Bay 14 1:8
Other projects  Pilot Cutter 1:500
                         Maria, Sloop 1:2
Restoration      A Bassett Lowke steamship Albertic 1:100
#10
TomShipModel
TomShipModel
  • Members
  • 76 posts
  • LocationEast Brunswick, New Jersey
Thank you very much for both charts. If you have a smart phone or an iPad in your shop there are several conversion apps that you can install for free. I really like the charts myself but there are digital ones out there.
#11
Mahuna
Mahuna
  • Members
  • 990 posts
  • LocationSun Lakes, AZ
I use iConvert, which will convert any to any.
I also use Model Scaler from Woodland Scenics for converting from scale to actual and vice-versa.
Very handy apps.
  • iaincwil and Marcus Botanicus like this
#12
marius
marius
  • Members
  • 57 posts
  • LocationBotriver nr. Cape Town South Africa
I printed several copies and pinned them all over my workshop. We chnaged over to the metric system about 40 years ago. So I am used to both systems. The only imperial measurement device i still have is an old boxwood folding rule. Because so many plans and info are in imperial measurement I have to do many conversions.
Thanks for the Chart
marius
#13
Modeler12
Modeler12
  • Members
  • 1,874 posts
I realize that some people have trouble using a calculator, but what if you had a situation where the original ship plan calls for a beam that was 9 feet and 10 3/4 inches long? Your model is in a scale of 1 : 90. How do you determine the model length of that beam? Certainly there are no conversion charts for all of those situations.
Jay
#14
cog
cog
  • Members
  • 3,209 posts
  • LocationGelderland, Netherlands
Jay,
I agree that it is impossible to have conversion charts for everything and everymeasurement, thus:
It seems that those people need to learn how to use a calculator and need to know how to look up measurements ... in your example:
9 feet = 9*12 inch ( 1 foot = 12 inch)
plus 10 inch
plus 1 devided by 3 and after that multiplied by 4 (the 3/4")
that value divided by 90 gives the scaled value in inches
the inch value can be calculated to mm multiplying it by 25.4
shorthand:
((9*12)+10+((1/3)*4))/90 =1.325926" (*25.4 = 33.678582 mm)
google may come in handy ;)
needed to edit as I forgot a ')'
Edited by cog, 06 April 2013 - 11:40 PM.
Carl
Builds
Kit Wood
Dolphyn [Corel] 1:68, Higaki Kaisen [Woody Joe] 1:72
Kit Plastic
IJN Musashi [Tamiya] 1:350
Finished builds
Scratch: Sea Witch 1:109
#15
Modeler12
Modeler12
  • Members
  • 1,874 posts
Thank you Carl. There are times when a few calculations come in handy, rather than to rely on charts.
I, for one, like to put a simple conversion into a simple 'formula', just like you showed.
That is not to say that all charts are useless.
I still have a conversion chart above my drill press that converts numeric and alphabetic drill sizes to something I can understand.
Like a number G drill is actually 0.261 inch, or a number 69 drill is 0.0292 inch.
  • jim mclay and rtropp like this
Jay
#16
kiwibob
kiwibob
  • Members
  • 6 posts
  • LocationTokoroa New Zealand
Hi All,
Please see attached a link to a downloadable scale converter takes all the pain out of conversions . Hope this helps
http://msfm.seryan.c...ScaleMaster.exe
Cheers
Bob
  • bjoern likes this
#17
Dave Fellingham
Dave Fellingham
  • Members
  • 470 posts
  • LocationJoshua Tree, California, USA
Jay,
plus 10 inch
shorthand:
There's an error here:  1/3*4 = 4/3 = 1.333... [3 repeats infinitely]  which does not equal  3/4 = .75
The correct equation is ((9*12)+10.75)/90 = 1.319444..." (*25.4 = 33.514888...mm)  [4 and 8 repeat infinitely in the inch and metric conversion answers]
The simple keystroke sequence is 9*12=+10.75=/90=
Current Builds:  ESMERALDA Chilean Navy School Ship, 1/640 in a bottle
insanity Dan Clapp's hard water race boat in a bottle
Completed Build:  Prairie Schooner OGALLALA 1/96 in a bottle
Research Project:  Cruizer-class Brig-Sloops
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
#18
Don9of11
Don9of11
  • Members
  • 659 posts
  • LocationAkron, Ohio
This is a conversion chart I have been using for years. Very simple and quick.
Edited by Don9of11, 11 December 2013 - 10:10 AM.
  • trippwj and michael mott like this
Current project: MS Mayflower
Developing plans for a 3rd rate 74 gun ship, circa 1780-1820.
Projects in waiting
MS Katy of Norfolk
www.howefamily.com
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
