Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
How do I make the slots in the Cathead?
  • Please log in to reply
31 replies to this topic
#21
egkb
egkb
  • Members
  • 1,449 posts
  • LocationArklow, Ireland
Thanks D, another clever method to add to my list.. the more I think of this method the more I like it (especially if you are painting the Cathead as that would cover up the Laminate.. so to speak !)
Have a great New Year.
Eamonn
  • WackoWolf likes this
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is ^_^
Almost There  :  Bounty
#22
Mike40
Mike40
  • Members
  • 108 posts
  • LocationKleppe Norway (southwest coast)
This is a very easy job for a scroll saw. Just drill the two holes, insert the scroll saw blade and cut first on the far edged of the first hole to the second and then repeat on the other side and  you are done. I think every model builder and woodworker should have a scroll saw. They are VERY handy tools to have for so many different tasks.
  • mtaylor and egkb like this
Mike,
an American living in Norway
Current build:  Galley Washington - 1:48 - Scratch POF - NRG plans
#23
jbshan
jbshan
  • Members
  • 1,131 posts
  • LocationWest Coast of NH
If you are not going to be using actual sheaves, but leaving some of the wood in the slot to simulate them, try drilling your two holes each than shaping as if there were a sheave in there using a 'reamer'.  This is a small, tapered, four-sided drill bit sort of thing that you merely twirl along where the sheave should be.  It won't grab like a drill and you can shape it fairly precisely.  You will be putting line here, so make it deep enough so the line can curve around as if there were a sheave down in there.  It isn't as aggressive as a file, and is less severely tapered; you can also use a reamer to clean out drilled holes without enlarging them too much.
  • mtaylor, Altduck, egkb and 1 other like this
#24
Chazz
Chazz
  • Members
  • 19 posts
You can also put a coping saw blade in a pin vise and saw the slot directly between the drilled holes.  They come in many sizes, even round ones that will cut in any direction.
Chuck Ward
#25
  • Members
  • 759 posts
  • LocationParis, France
If the cat-heads are to be painted, one can also build them up from layers, leaving a space for the slot. The sheaves then can be added later.
Btw, the reamers mentioned above have five sides not four, at least those that you normally get from watchmaking supply houses. A four-sided reamer would not cut, but just dig in.
  • mtaylor, WackoWolf, Altduck and 2 others like this
#26
jbshan
jbshan
  • Members
  • 1,131 posts
wefalck, I'm not sure of the intended use, but mine all have four sides.  They came from a hobby shop.
  • mtaylor, Altduck and donrobinson like this
#27
  • Members
  • 759 posts
I was talking about this kind of broaches or reamers:
e.g. from https://www.eternalt...g-broaches-set.
They come in sets of different sizes up to 2.5 mm I think.
#28
jud
jud
  • Members
  • 1,090 posts
  • LocationLexington, Oregon
Reamers need 5 or more cutting edges to prevent being forced into the material and cutting, breaking or jamming. Often you will find reamers with 5 or more cutting edges not symmetrical in their cutting edges around the center, 'odd spacing to prevent chatter'. There are drilling devices made to drill square holes in wood, never have seen any small enough for model applications, they are high speed drill bits within a square cutting guide with chisel corners.
jud
  • wefalck, mtaylor, WackoWolf and 3 others like this
#29
  • Members
  • 759 posts
Yep, this square-hole drilling or rather milling devices always fascinated me. There is a nice animation on YouTube:
https://www.youtube....h?v=L5AzbDJ7KYI
It's a bit like a Wankel rotary-engine ...
However, the slots in the cat-heads do not have to have sharp corners at all. I gather on the prototype one would drill two holes at the ends and then chisel-out the wood in between. Using a fret-saw, a scroll-saw or a filing-machine would be closest to the prototype. In small scales there will be limits due to the width of the saw-blades that would need to fit through the hole at one end.
Another option would be to use a reasonably precise drill-press as morticing-machine. Grind a chisel-edge onto the drill you used for driilling the end-holes and chuck it up the 'wrong' way around. With this you can nibble away the material between the holes. If I had to do this, I would use my hand-shaper, even though it would somewhat cumbersome for small model work.
If you have a lathe with a hand-lever tailstock, you can use this in the same way, with added advantage that you have very controlled feed for the morticing operation through the top-slide of the lathe. You would need to devise a way to fit a vice on the cross-slide, perhaps with a vertical milling slide.
As these deep, narrow slots are recurrent machining problem, also in the production of blocks, one may want to construct a small morticing machine for that purpose ...
  • mtaylor, jud, Altduck and 2 others like this
#30
jud
jud
  • Members
  • 1,090 posts
www.amazon.com/Uxcell-Hollow-Square-Mortiser-Chisel/...
This is more like I was thinking about.
jud
  • mtaylor and Canute like this
#31
WackoWolf
WackoWolf
  • Members
  • 2,734 posts
  • LocationRhode Island
Thanks for the YouTube link.
Wacko
Joe :D
Go MSW :) :)
#32
JerryTodd
JerryTodd
    Scale Sailor
  • Members
  • 547 posts
  • LocationSeverna Park Maryland USA
There's also lamination, especially for things that will be painted.
  • mtaylor, WackoWolf, cristikc and 4 others like this
Click a pic to go to that build log
sig_flags.png stamp_stella.jpg stamp_mac.jpg stamp_pride.jpg stamp_gazela.jpg
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
