Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Tube for soaking wood
wood water pvc tube bending soaking
  • Please log in to reply
12 replies to this topic
#1
Nirvana
Nirvana
  • Members
  • 1,817 posts
  • LocationConnell, WA
I think someone made a similar posting a while back, however I can't find it so here is my version.
Soaking wood to make them softer for bending is always an issue. Some of us has a bathroom or another great nearby facility of water where one can drench the wood without being disturbed.
Here is the material list:
3ft 2" PVC pipe
2" endcap
2" C-clamp
1/4" dual thread bolt.
Two 1/4" nuts (used for tighten the bolt into the wood)
Washer
1/4" large wing nut.
To make sure the end was water tight I used silicon both when attaching the end cap to the pie but also around the "thread" line.
I tested the tube, having it filled to the rim with water sitting over night.
No water came out.
The C-clamp literally snaps around the pipe.
Setting the height towards the table, I drilled and attached the bolt.
With the wing nut it is easy to remove when not needed.
  • mtaylor, avsjerome2003 and thibaultron like this
Respectfully
Per aka Dr. Per
Ship modeling is a long lesson in patience - Me
It's better to get something done later than never
Denial is futile, MSW is here to stay.
 Therapy for Shipaholics
Finished: T37, BB Marie Jeanne - located on a shelf in Sweden
Current: America by Constructo, Harley almost a Harvey , 18th Century Longboat, Solö Ruff
National Research Guild Member - 'Taint a hobby if you gotta hurry
#2
Dan Vadas
Dan Vadas
    Administrator
  • Administrators
  • 2,190 posts
  • LocationAbermain NSW Australia
Sounds like a lot of work Per (do you REALLY NEED to soak 3-foot lengths??).
Here's my version - a 2 litre plastic bottle, a self-closing tweezers to hold the plank, and a piece of stick to stop the tweezers from falling into the bottle :) . Cost = $0.00 :D .
Good enough for 1-foot lengths of planking, which is longer than I use anyway.
:cheers:  Danny
  • cog, Augie, CaptainSteve and 3 others like this
____________________________________________________________________________________
Current Builds : HMS Vulture Cross-section
Build Logs : Norfolk Sloop   18 foot Cutter    HMS Vulture Scratchbuilt from TFFM books Index 1   Index 2
18th Century Longboat in a BOTTLE
Gallery : Norfolk Sloop, HMAT Supply, HMS Bounty, HMS Victory, Charles W. Morgan 18' Cutter for HMS Vulture HMS Vulture
18th Century Longboat in a Bottle
"The measure and merit of an individual is not how they handle themselves in times of prosperity and good will, but how they handle themselves in times of turmoil and chaos"
#3
Nirvana
Nirvana
  • Members
  • 1,817 posts
Danny, there is nothing that prevents me from shorten the tube,  but it's sturdy and does its duty.
Besides you never know when I want to build something outrageously big that I can't get out from the shop/office :D
Respectfully
Per aka Dr. Per
#4
normanh
normanh
  • Members
  • 295 posts
  • LocationSouth Essex UK
I use a tall thermos flask - keeps the water hot but sometimes needs the plank reversing if a long plank.
Norman
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
#5
Patrick Haw
Patrick Haw
  • Members
  • 392 posts
  • LocationSt. Michaels, MD, USA
Here's my version.  Yes, I needed to soak 3 foot strips of wood.  My Caldercraft Victory is huge!   Glad I'm done with hull planking now!
Patrick
  • cristikc and biltut like this
#6
JPett
JPett
  • Members
  • 1,082 posts
  • LocationTexas DFW
Ahoy Mates :D
I too am a fan of the PVC pipe soaker, but use 1/2" sprinkler pipe. Its threaded, available in multiple lengths, and is much better for smaller work areas and closet builders like myself.
It should be noted that I cut my planks to length (actually just a bit longer) and only work on one or two at a time.
If that is your style, this is all you need.
Edited by JPett, 17 September 2013 - 11:15 PM.
  • WackoWolf and cristikc like this
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworl...28-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworl...l-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworl...as-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
#7
sonicmcdude
sonicmcdude
  • Members
  • 179 posts
  • LocationKriva Palanka, FYRO Macedonia
Nice ideas for plank soaking I will remember this for my first planking job ... hoping it will be soon  :huh:
Greetings, Sinan :pirate41:
Build log:TRITON POB 1:72
#8
usedtosail
usedtosail
    Trying hard
  • Members
  • 1,244 posts
  • LocationNorth Reading, MA
Hey, JPeet. I hope you are not using that nipple indoors :D
- Tom -
Current Build: Model Shipways Constitution
Next in Line: Billings Half Moon or Dumas 1938 Cris Craft
Completed: MS Bounty LaunchHMS Beagle - highly bashed Mamoli kit using Anatomy of Ship book,
Santisima Trinidad Cross Section, Dapper Tom, Sultana, Phantom
Member: Nautical Research Guild
#9
Hipexec
Hipexec
    hipexec
  • Members
  • 2,002 posts
  • LocationScottsdale AZ
I built a PVC tub for my 30 inch planks and it works great.
Thanks for the tip
Rich
hipexec USS Constitution
#10
Froggy 79
Froggy 79
  • Members
  • 9 posts
  • LocationOttawa Ontario Canada
Another cheap way is to buy a plastic tub for wallpaper. Much easier to grab wood.
  • Ryland Craze, mtaylor, Canute and 1 other like this
#11
hornet
hornet
  • Members
  • 544 posts
  • LocationNewcastle, NSW Australia
I've posted this before, but for those who haven't seen it. PVC cut down and mounted on a stand. Tap on the end for easy drainage.
Cheers
Steve
  • mtaylor, biltut, Tadeusz43 and 2 others like this
Hornet
Current Build: - Caldercraft - HMAV Bounty
Completed Ship Builds:
                                     Caldercraft - HM Brig Supply (In Gallery)
                                     Aeropiccola - Golden Hind
                                                        - Constitution
                                     Clipper Seawitch (maker unknown - too long ago to remember!)
                                     Corel - Victory
                                     Modeller's Shipyard - A Schooner of Port Jackson - In Gallery
        - Brig `Perseverance' - In Gallery
        - Cutter `Mermaid'- In Gallery
        - Sirius Longboat (bashed) - In Gallery
        - Sloop Norfolk - In Gallery
                                      Completed Cannon:   - French 18th Century Naval Cannon
        - Napoleonic 12 pound field piece
        - English 18th Century Carronade
                                       On the shelf awaiting construction: - Caldercraft  - HM Bark Endeavour
#12
thibaultron
thibaultron
  • Members
  • 575 posts
  • LocationWarrenville, SC
I built a similar tube to Nirvana's a about 3 decades ago, yes I did need to soak 3 ft lengths at the time. The only differences were that I glued the end cap on one end, and glued on a threaded connection? end on the other.cap on the other. After adding the water and wood, I would screw on a plug to seal the end. I stored it upright, but the couple times it fell over it didn't leak.
  • mtaylor, biltut, John Allen and 1 other like this
#13
John Allen
John Allen
  • Members
  • 276 posts
  • LocationMobile, Alabama
Mine was like yours, PVC  with an end cap, other end left open, secured by just 2 plastic ties to the leg of my work table but loose enough when I finish lift it out pour water out slip it in the ties for next time. All leftover stuff on hand cost nothing, time 5 minutes.
Simple is always best Wife calls me Simple Simon hope she was referring to my ingenuity and not mind I hope. :(
Edited by John Allen, 29 December 2016 - 02:32 PM.
  • mtaylor, biltut, thibaultron and 1 other like this
John Allen
Current build Mamoli HMS Victory
Armed Launch-Panart
Diligence English Revenue Cutter-Marine  Model Co.
On deck Maori (Waca) war canoe
and Double hull Polynesian canoe (Holakea)
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
