18th Century Longboat by Nirvana - FINISHED - Model Shipways - 1:48
Frame alignment is really critical to have a smooth shape of the hull, better fix it now, not fixable if planking is done.
I had just one single frame a bit out of line on Pinnace, it was hardly visible when model is not planked. Result - skewed hull shape. Nobody sees it except me, but I know it's there :)
Link to comment
Share on other sites
Per, On my build every bulkhead's notch had to be opened up slightly as well as every notch in the false keel. We are talking about just enough to allow the bulkhead to move off perpendicular in both directions(fore and aft)as well as side to side. I used a block to get 90 degrees(see third photo on my build log http://modelshipworld.com/index.php?/topic/4930-18th-century-longboat-by-stuntflyer-mike-model-shipways/). Once the first bulkhead was glued in place, I used my eye to align each subsequent bulkheads top to the one previously glued. Hope this helps. Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
I have tears in my eyes, after being away from home for about a week (work),
How this happened I don't know, I always making sure the door is closed and secured,
the admiral feels bad.
Office/workshop door was open when I got home.
But now I am back to square one.
Don't like it at all as I were very happy with the results to date.
Next is to call ModelExpo for replacement items.......     sigh :(
And start again.
Didn't want this at all. :( :(
Respectfully
Link to comment
Per - Oh my! I am sorry to see this. I guess you are going back to working on the Harvey for about a week.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Link to comment
Ouch!!
But looks fixable with a good wood glue? Joint between stem and keel will handle the load, and false keel is thick enough to be edge glued?
Link to comment
I agree with Mike Y.  It is very fixable.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, John Smith Shallop
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch 1/4 scale-Model Shipways plans)
Link to comment
Per, I'm also sorry to see this but I do agree with Mike Y. and Chuck S. As long as the broken off pieces are not smashed then you should be able to glue things back together. Besides, the false keel will not show on the finished model. If you need a stem, I have one still in the laser sheet. I would be more than happy to send it to you.
Link to comment
Since I started over on my false Keel twice. I have 5 spare Stems. You can have them all! :P
Link to comment
Okay, repair work commenced and turned out that the stem piece was broken where the keel meets up, didn't see until I had the stem fixed without checking with the false and true keel.
Bummer, new stem is to be manufactured.post-967-0-50451900-1402861324_thumb.jpg
Edited by Nirvana
Respectfully
Link to comment
Unless you're going to have a natural finish (as opposed to a white bottom of some sort) why would you have to manufacture a new stem?
Just cut the bad area square and cut a corresponding size piece out of the scrap sheet the parts came off of. Glue it on, Fill and sand the joints and paint as if nothing happened.
Just asking?
Sam
ABSOLUTELY NOTHING UNDER DEVELOPMENT
Link to comment
Sam,
Keel and stem is out of Boxwood not the original material basswood.
Otherwise your idea would work.
Respectfully
Link to comment
Put the plan in the scanner and had part printed.
Used double sided clear tape and attached to the boxwood sheet.
Next is the cutting and trim, and I should have another workable piece. :)post-967-0-96949200-1402869894_thumb.jpg
Respectfully
Link to comment
Having a somewhat new shaped stem again I used double sided clear tape and attached the broken piece for the final trimming.This pic shows the two separate.post-967-0-34712400-1402943483_thumb.jpg
Respectfully
Link to comment
The new stem piece is in place, I preferred to attach the stem before the remaining piece from the false keel.
The stem piece has little "extra meat" which is sand-able.
On the other hand I got it perfectly straight! :)
I even got the connection between the keel and stem tighter this time.
Edited by Nirvana
Respectfully
Link to comment
Pops, Thank you for those words.
However, I think everyone in here will remember when one has done a repair or modification, even though it may not be visible to others.
I also got a nice and tight fit with the smaller false keel part without any modifications.
Respectfully
Link to comment
Nice job. I looks like I am finishing my repairs just about the same time as you are. The Club meeting is this Saturday and we hope to start planking then.
Link to comment
False decking accordingly to MikeY in Sweden, this to stabilize the bulkheads before fairing.
First plank down matching the keel length.post-967-0-65540900-1403116681_thumb.jpg
Respectfully
Link to comment
Wood stirring straws which are flexible enough works as a stand in for the temp deck.
The bulkheads are rigid. No flexing at all.
Sanding and planking will be next.
Pretty happy with it so far.
Respectfully
Link to comment
So I dry fitted the sheer plank and it follows the top of each bulkhead perfectly! :rolleyes:
The instructions reads " This is about 1/16" below the top of the bulkheads mid ship"
Guess I have to force the dip in order to get the curve.post-967-0-77614300-1405915011_thumb.jpg
Respectfully
Link to comment
The top of the shear plank rests along the dashed line shown on the plan which is about 1/16" below the top of the bulkheads. The shear should have a natural flow into the stem. Notice the position of the dashed line relative to the stem. This will leave room for the cap rail, something I didn't do initially but corrected later. You only need to "dip" the center of the sheer lower if you want more curve.
Link to comment
Per,
It looks like bulkheads E thru H at the bow need to be faired more. I took quite a lot of wood off of the leading edge of these bulkheads so that my planks would lay flat against the frames.  Fairing of the bulkheads produced a natural sheer line at the bow on my Longboat.
Ryland
               - Nautical Research Guild
Link to comment
Ryland - That's a great observation that I missed when I first looked at the photos. On my build I was quite surprised at just how much bulkheads E thru H had to be tapered.
Link to comment
Ryland, thanks for the sharp eyes,
I will fair them further.
The technique of plank bending of Chucks works great. but I didn't use the hair dryer :D
Respectfully
Link to comment
I don't use a hair dryer either. I am willing to wait. there is plenty to do while it dries.
Link to comment
Dont forget that its not just for the time...the hair dryer adds heat.  A lot of heat.  This will make it very pliable and you can get a more drastic bend or twist.   Probably another 20%.
Chuck
Link to comment
Chuck - I had not thought of that. Ok I will give it a try.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
