"USRC 30tons Revenue Cutte1829" by Small Stuff - 1/24 - Scratch
There... moved it.  I like magnifier that I assume needs to be emptied occasionally.
Link to comment
Share on other sites
"Moderation is the order of the day!" otherwise you're going to build a catamaran... :D  ;)
Here te latest news:
Here you see the inner part placed on the beech plywood strip and below the Stern & Stem - but the keel!!!
Is it possible that a nearly 60ft long keel is made from one single pice of tree???
And the plank under it is also from one pice???
Due to the Mondleld's rule "No plank was longer than 35ft" I ask my question.
Looking foreward toward your answers,
:piratebo5:
Christian
Edited by Small Stuff
My carpetmonster adapted to laminate flooring!
GK - Modellbau No. 2002 a little boat 680 after E.Paris  - PoF 1/50
AL 18021 Scottish Maid the 1st Aberdeen Clipper 1839 - PoB 1/76 (?)
Dream: a hullmodel of the 66 55/95 tons US-Revenue drop-keel Cutter 1/2"=1ft, plans by H.I.Chapelle
Link to comment
Christian,
In real life, the keel would have been made from 2 or 3 pieces of wood and put together using a hooked scarf joint. Go to the early pages of Danny Vada's Vulture log to see the joint.
Link to comment
Christian, as Mark has written, you can follow Goodwin in this detail for your model
Regards Christian
Link to comment
Thaks a lot - inbetween I made some progress in the workshop:
I've got some tooling equipment by eating not so and avoiding contatct to cigar dealers -so saved the money for this.
The framed ship in the background is the Georgian "Experiment" from the "50 Gun Ship" but far too big to be built in 1/2" and on its right the "HMS Hood" of the era of uncertainy Admirals-class copied from "Birth of the Battleship" and framed on VC-cross red ground... she and the giant gun fitted "Benbow" are the favorites of this era to me...
But to be realistic towards my capacitys to steam & sail I'll have to turn my mind towards the Crimean Gunboats under 110' Lpp or the later screw sloops with board side guns... and without guns in 3/4 turrets.
The next projects will still be Revenue Cutters under Sail. For ships of this size under 1.000 m/m I prepared the workshop:
Link to comment
Hello again,
I.
As the sideview only gives us the position of the deck's superstructure, an auxilliary source may give us the rigt deepon deck... the 14 years older 31 3/95 cutter may be a good reference to look at. Also a sceptic view to the bigger sisters of this class type's trio may be usefull. So I added them, too.
What do you think about this?
II.
I wasn't in the workshop this night - I still was thinking, drinking and constructing my RC's backbone. So I got some solutions and some more problems figured out: So I highlighted these areas with yellow circles for you.
The mast's area will be easily supportet against cracking by adding softwood and drill the mast's hole inside. But the staircases area is still a problem and the reduced bulkhead destabilised this part of the construction additivly.
Have you any solutions for this, too?
Thanks a lot,
Chris
Link to comment
I nearly forgot the reality-check!!! :o
Does it realy fits
in the place
where I want
to put it laterly???
:Whew:
Link to comment
Chris,
I guess I'm not seeing the problem you circled.   The bulkhead could be trimmed out in center area for the ladder.
Link to comment
Hello friends of the saw,#
due to the fact that I'm permanendly in trainings and teachings I've got no time really to work on my model. So here is the very last progress - the backbone is redy to take in the drawings for the bulkheads slots:
Link to comment
  • 2 months later...
Due to the massive reconstruction to be done in here I decided to stop this project.
But it is not destroyed - I just "put it on ice" as we say in Germany, when something has to wait until other things are done.
Chris
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
