Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
How I fix Boo-Boos and Oopsies (Mistakes) by Dan Vadas - Share your own "Fixes" here
  • Please log in to reply
80 replies to this topic
#1
Dan Vadas
Dan Vadas
    Administrator
  • Administrators
  • 2,190 posts
  • LocationAbermain NSW Australia
During the course of building my Scratchbuilt model of HMS Vulture I've encountered some problems (don't we all :D ) so I thought I'd share some Tips on how I Fixed them.
There are three examples shown below - feel free to add your own "misadventures turned to masterpieces" below.
The first and most important "tool" when faced with an apparent catastrophe is the Right Attitude. Some would pick the model up and throw it against the wall, but that's not going to fix anything except a very short-term sense of frustration :huh:  .
Remember this point - 98% of Mistakes are YOUR OWN FAULT .... NOT THE MODEL'S. The exceptions are if a large truck or a hurricane demolishes half your workshop taking your ship with it - not much you could have done to prevent THAT :D . And don't blame the cat for jumping on the workbench either - what was it doing in there in the first place??
Stay calm, sit down for a few minutes and think of a solution. Keep a positive attitude, convince yourself that ANYTHING CAN BE FIXED (because it CAN  :) ).
_________________________________________________________________________________________________
The first one is a fairly simple fix to a problem that many Builders, whether Kit or Scratch, Advanced Builder or Novice, can encounter at any time:
Gaps in Planking
There are quite a few reasons why you may get a gap or two in your planking - inexperience, not beveling or tapering correctly, a slipped clamp or pin, bad lighting (couldn't see it), rushing to finish it before going to work or wherever. I've been guilty of ALL of the above at times  :D .
The cause of this one : IMPATIENCE - I'd soaked the planks to get a slight lateral bend in them to follow the Waterway. I pinned them in place to dry out, but DIDN'T LEAVE THEM ALONE TO DRY THOROUGHLY before gluing them on.
They looked fine when I first glued them, but two days later the gaps appeared as the planks shrank back to normal size.
Who's fault? MINE
Here's how they looked before the "Fix" :
I wanted to leave the Caulking visible in the planking. Fortunately the caulking was done using an Archival Ink Pen on ONE edge of the planks only. If BOTH edges had been done this fix would not have worked very well - the gap would still have been apparent, only to a lesser extent.
The solution was simple enough. I sanded down a scrap of the same Castello timber used for the planking, mixed it with some diluted white PVA glue, forced it into the gap and let it dry thoroughly :
The next two pics show the results after sanding it, both before any finish was applied :
And after a coat of Minwax Poly :
Total Time taken to fix this : About 10 minutes (not counting time while the glue dried).
Current Builds : HMS Vulture Cross-section
Build Logs : Norfolk Sloop   18 foot Cutter    HMS Vulture Scratchbuilt from TFFM books Index 1   Index 2
18th Century Longboat in a BOTTLE
Gallery : Norfolk Sloop, HMAT Supply, HMS Bounty, HMS Victory, Charles W. Morgan 18' Cutter for HMS Vulture HMS Vulture
18th Century Longboat in a Bottle
"The measure and merit of an individual is not how they handle themselves in times of prosperity and good will, but how they handle themselves in times of turmoil and chaos"
#2
Dan Vadas
Dan Vadas
    Administrator
  • Administrators
  • 2,190 posts
Broken Knee of the Head
Cause : TAKING A SHORTCUT and FORGETFULNESS  - I'd been doing some work on the hull with it off the baseboard,  which was mounted to my Tilting Attachment. The ship is held by two supports fore and aft and is normally screwed to the  baseboard through the keel, but I only needed to do a few minutes work with it on the workbench before returning it to the baseboard so I didn't bother screwing it down.
I was distracted for a few minutes by a phone call and when I returned to the ship I'd forgotten it wasn't screwed to the board. Naturally enough, as soon as I tilted the board to get at a piece on the other side the model fell out of it's supports and  crashed to the floor, breaking the Knee of the Head.
Who's fault? MINE
Here's how she looked after the crash :
The Knee broke through only one piece, but (of course) it was the most difficult one to fix - The Lacing Piece.
First thing to do was drill a series of small holes through the Lacing Piece alongside the join with the Stem. This helped the Isopropyl Alcohol penetrate the timber close to the join :
Then it was time to get out the Isocol, fix a piece of gauze around the join and soak it thoroughly until it started to soften the glue. Carefully wedging the join apart helped speed the process :
Here's a pic of the broken Lacing Piece removed and the Stem cleaned up :
A new Lacing Piece was made and dry-fitted to the Stem and shaped until a perfect join was remade. The outer edge of it was left a fair bit oversize at this stage :
The undamaged Bobstay Piece and Cutwater were then fitted to the fore part of the Knee :
After a bit of sanding here is the result. No finish had been applied when this pic was taken :
Total Time taken to fix this : About 4 hours (not counting time while the glue dried).
  • JPett, dafi, edmay and 8 others like this
#3
Dan Vadas
Dan Vadas
    Administrator
  • Administrators
  • 2,190 posts
Warped Keel
This one went pretty close to ending the Build when I first discovered it. But with nothing to lose I figured I may as well try and fix it  :) .
The Cause : INEXPERIENCE - This is my first attempt at a Fully Framed model.
My intention for the Build was to Fully Plank one side and leave the other side Open, so when it came time to put the Fillers into the lower sections between the Frames I only did the Open side - the other side wouldn't have been seen at all.
What I SHOULD have done was fit them to BOTH sides, or at the least every 2nd one.
I didn't know it at the time, but PVA glue shrinks as it dries - especially so over such a large area. The shrinkage caused a warp in the keel of about 10mm in the middle. I'd been fitting all the Fillers with the hull upside-down and not on the baseboard. After I'd sanded them to shape I tried to remount it in the baseboard, but it wouldn't go on. That's when I discovered the problem :
To fix the problem I cut out two of the Fillers and the Ribands that were already fitted. I used wedges to force the keel back into shape, holding the top of the framing in line with a clamp. Then I glued two fillers into the Port side opposite the two I'd removed and let them dry THOROUGHLY :
Then I made two slightly larger Fillers and fitted them into the vacant slots :
The Keel finished up perfectly straight :) . This pic was taken a long time after the initial incident.
Total Time taken to fix this : About 6 hours (not counting time while the glue dried).
  • gieb8688, JPett, dafi and 14 others like this
#4
Jim Lad
Jim Lad
    Moderator
  • Moderators
  • 5,231 posts
  • LocationSydney Australia
Here's mine, and I think it's might be reasonably common.
Broken Mast
Cause: Reaching across my partly rigged model of the Nautilus without thinking and catching the royal masthead on my sleave.
Who's Fault?: Mine, for being so careless and stupid - easpecially around delicate parts on a 1:96 model.
The masthead snapped off clean at the collar, leaving the already attached rigging just hanging.
I had to strip off all the rigging for a start, then I carefully drilled a No.78 drill hole in each section of the mast and inserted a length of wire into the lower section, added some glue, and slipped the broken upper section back into place over the projecting wire - presto, just like a new one!
With the rigging re-done, it  looks as though nothing has happened.
Lesson Learned:  Be very aware of what you're doing and where your arms and clothing are going around a model - especially once the rigging is started.
John
  • JPett, dafi, tasmanian and 6 others like this
#5
mtaylor
mtaylor
    Bilge Rat
  • SPECIAL CONTRIBUTOR
  • 14,228 posts
  • LocationMedford, OR
I'm in agreement.. attitude is everything.. along with a scrap box, isopropyl alcohol, and acetone.  (the Isopropyl for dissolving PVA and the acetone for CA).
I've messed up more on this scratchbuild than I care to admit and more than on my kits  and I won't overwhelm with pictures.  From mis-cutting frames to breaking the stem.  Some frames, I tossed.  Other frames, I shimmed since the hull will be completely planked.  I've replanked the lower deck, removed and repositioned all the furniture on the gundeck. Oh, did mention I've made almost every bit of furniture twice so far?  Gunports have been reset, clamps redone.  I"ve learned and it's been fun.
No one to blame but me.  I'm sure there will be other things.
The most important thing I've learned... re-work until satisfied that's it's as good as you can do.  Then go one step further and try again.   She may not be perfect in other eyes when I'm done, but she'll be the best I can do in mine.  Of course, the next one will be better. :)
  • Rafael 3, Elmer Cornish and FriedClams like this
Licorne - 1755 from Hahn Plans (Scratch) Version 2.0
Triton Cross-Section
USS Constellaton (kit bashed to 1854 Sloop of War (Gallery) Build Log
Wasa (Gallery)
#6
bbrockel
bbrockel
  • Members
  • 129 posts
  • LocationWestminster, Colorado
Thank you gentlemen for the sage advice we can all use now and then.  Next time I have a lapse in consentration or make an error, I will stop and remember your words.  Of course thats after I turn the air blue with several 'explatives deleted'.   :D
Bob
"I've told you a million times, don't exaggerate   ;) "
 Current builds:
  TRITON Cross section
#7
J.P.
J.P.
  • Members
  • 256 posts
  • LocationEdmonton, AB Canada
Great thread,...I'll be on board soon enough.....with a few doosies (is that a word?)....... that I recall :huh:
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel),
Current WIP:Le Renommee (Euromodel)
On Shelf: Berlin (Corel), HMS Bounty (Billings),
Le Renommee - Euromodel
#8
robbl
robbl
  • Members
  • 78 posts
  • LocationAuckland, NZ
This is my most adventurous fix. I had a frame on Blanche that was sitting too high on one side.
Cause: Setting up frames in a rush just before going out to dinner with the Admiral and not triple checking the alignment in every axis.
Who's fault: Well, I suspect the Admiral won't take the blame, so I admit, I was that soldier.
The Fix:
Rather than try and force it to align properly, I decided to replace one side of the frame.
To remove it, i first drilled a series of small holes with my pin vise vertically down through the floor of the frame, alongside the keel. This allowed me to use a small saw to cut the floor at that point and with the help of a fair bit of alcohol, remove that entire side of the frame. I then used a small mill cutter in my Dremel to clean up the cut alongside the keel.
Being lazy, and since the timbers above the floor were fine, I removed the remains of the floor from the frame, then made half a floor, to which the chock of the lowest futtock fit perfectly.
This was then inserted into the gap to align correctly.
The result:
Cheers
Rob
  • dafi, chris watton, Elmer Cornish and 1 other like this
Current build: HMS Blanche 1800, Scratch POF
#9
MSzwarc
MSzwarc
  • Members
  • 53 posts
Dan, I have to say this is one of the best threads I've seen on  a modeling forum. It reminds modelers that they are in control of their builds, and that no problem is insurmountable if one will just calm down, and give it the old critical thought process. Thanks for the reminder!
  • AnobiumPunctatum and Doreltomin like this
Mike
In progress: nothing
Completed:
Midwest Chesapeake Bay flattie
scratchbuilt Grand Banks dory
Young Modeler 1:100 turtle ship
This was the morning when father, mending one hole in the thermos-flask, made three
--Dylan Thomas
#10
lb0190
lb0190
    TMCNEI
  • Members
  • 958 posts
  • LocationFlorida, USA
This is a great thread. When people ask me about the amount of time I spend on a model, I tell them 30% of my time is fixing  "aaah crap, why did I do that" items, but like others have said, it's just another way to learn. I've used the sawdust fix several times and I'm amazed how well it works.
I hope this thread grows with more examples, I suspect I'll need the help...  :)
  • Mick_S likes this
Regards,
Larry
Current Build
US Brig
Niagara
Completed Builds
George W
Washburn
- 1890 Tugboat
Future Builds
18th Century Longboat by MS
HM Cutter Cheerful
Wappen Von Hamburg by Corel
[color=rgb(128,128,128)]If your not making mistakes, your not challenging yourself – my life has been full of challenges :)
#11
Skybolt
Skybolt
  • Members
  • 2 posts
I use clear dope instead of PVA glue it is specialy good for filling the gaps.
Dope is better because it has no effect on the wood dust color after drying, The other plus for clear dope is its sanding characteristic, you can sand it to a very smooth finish.
The downside is it is not that hard so if you use it for shallow dents, a normal sanding can just remove all of it from the surface
Edited by Skybolt, 06 March 2013 - 11:09 AM.
#12
Augie
Augie
    Ship's Cat
  • Gone, but not forgotten
  • 5,488 posts
  • LocationColorado, USA
This really is a great thread Dan.  Glad you started it.
As a relative newcomer, I make plenty of mistakes/oop's.  My latest catastrophe is detailed on my Syren log.  The problem is that when we look at the logs from you Top Gun guys and gals, we get the impression that everything goes perfectly.  This topic puts things in perspective, much like Briddoch's USS Constitution where he had a mishap transporting his lady.
The bottom line is that all on here share the same emotions as we move through a project.  And when the unthinkable happens to someone else on the Forum we at least try to lend support.
Thanks again.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
#13
Kevin
Kevin
  • Members
  • 3,529 posts
  • LocationSomerset England
lol - i believe this could be the most viewed topic in MSW 2-0 - brilliant idea
it could be an ideal way of pointing to another thread on home made jigs - like setting gun port side - and another one that Dan showed of reversing the calipers to set the height of an item
Edited by Kevin, 06 March 2013 - 01:15 PM.
Please click on photo for a better image
All the best
Kevin
In build
HMS VICTORY by Wilber - Caldercraft/Jotika - 1/72
http://modelshipworl...raftjotika-172/
Bismarck By Wilber - Trumpeter 1/200
http://modelshipworl...r-plastic-1200/
Posting a Profile of Your Build
http://modelshipworl...-of-your-build/
#14
Geoff Matson
Geoff Matson
  • Members
  • 569 posts
  • LocationHarvard Illinois
Thanks Dan for starting this thread.
The fixes were outstanding. For a beginner like myself it is great to see how things can be fixed and reapired. Thanks to all who posted
Geoff
Current build : USS Constitution
Finished builds: Armed Virginia Sloop (in gallery)
#15
sonicmcdude
sonicmcdude
  • Members
  • 179 posts
  • LocationKriva Palanka, FYRO Macedonia
Nice thread! Nice idea! I can proudly say that I have a lot of this lol :D. But you can learn I lot from "oopsies", I think that is how you get the experience! The best thread ever I have to say again!
Greetings, Sinan :pirate41:
Build log:TRITON POB 1:72
#16
Erik Nyren
Erik Nyren
  • Members
  • 187 posts
A wise man learns from his misstakes. A genious learns from the misstakes of others.
I cant remember who said that but I love the thread.
Erik
  • xavjar, CaptainSteve and Altduck like this
#17
Remco
Remco
  • Members
  • 596 posts
  • LocationThe Netherlands
Well one of many of my oopses.
The problem: misalignment of the gunport stills
Cause: An impatient builder (me...) relying on a not so good jig instead of measuring from a fixed point
The fix: guts to take the frames out with isopropyl and start all over again.
The pencil lines mark the correct hight
Remco
  • Dan Vadas, mtaylor, JPett and 5 others like this
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
#18
Mahuna
Mahuna
  • Members
  • 990 posts
  • LocationSun Lakes, AZ
As a relatively new ship modeler I thought I was totally unskilled because of the errors I've made.  Thanks for showing me that mistakes are a part of the process.  I'll sleep better now!
Frank
#19
xavjar
xavjar
  • Members
  • 47 posts
  • LocationFleetwood, England
Erik
Thats a great quote,
Cheers Phil,
HMS Victory 1:84
YNWA
Cheers Phil,
#20
shortgrass
shortgrass
  • Members
  • 39 posts
  • LocationVictoria, B.C. Canada
What a great thread - good for all modellers.  Thanks Dan.
Dave
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
