Amerigo Vespucci 1931 by schiffebastler - Mantua - scale 1:84 - Italian sail training ship build
Now it goes on. So here are the staysails at the foredeck with sheets and downhauls.
The sheets of each sail have the typical precursors with blocks at the end through which the sheets run. The downhauls are attached to the clew horn, run high over a block attached to the nock horn back down to the neck horn and over a block attached to it to the reference point.
The lines are still occupied, the whole line bundles are still missing and then everything has to be finally fixed.
Joachim
My new Book in ENGLISH and GERMAN available:
"The colour blue in historic shipbuilding"
http://www.modellbau-muellerschoen.de/buch-en.htm
Current build   Amerigo Vespucci    http://modelshipworld.com/index.php?/topic/836-amerigo-vespucci-by-schiffebastler-mantua-model-scale-184-italien-sail-training-ship-build-1931/
See also our german forum for Sailing Ship Modeling and History:
http://www.segelschiffsmodellbau.com/
Link to comment
Share on other sites
The bottom mast sail of the foremast is attached to the yard and I have already attached the most important lines to it, especially the gordings have to be threaded through these tiny thimbles.
Joachim
Link to comment
Now there is also the upper topsail. Everything looks somehow the same, and yet each sail is different, is fastened differently to the respective yards, all have a different line guide.
Bild_24.thumb.jpg.7f5590220acc466fa2d5bb14b2d8d53c.jpgBild_24.thumb.jpg.7f5590220acc466fa2d5bb14b2d8d53c.jpg
Joachim
Link to comment
Joachin,
Clicking the "like" ikon is much too little. This build needs an "Amazing" thumbs up option as well. Brilliant work!
Sincerely,
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Link to comment
Dear Michael,
thank you very much for your great compliment!
Cheers
Joachim
Link to comment
the only one we have is this one 👍   just magnify it about a hundred times for the job your doing  ;)     very nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Oh, that's a nice Thumbs Up :)  thank you very, very much  👍
Cheers
Joachim
Link to comment
Hello folks,
now the first pictures of the rigged lower sail at the foremast. The jib boom is rotatably mounted and is held by chains on the jib mast. At first I had attached the lift. Two of the Gordings are brought together by one of the double blocks, they are fixed at the bottom of the bitt in front of the mast. The elaborately designed reef troughs are fixed at the betings on starboard and port. The clew-lines again lead directly to the bitt in front of the mast.
Before the lines are finally fixed, some of the other sails have to be attached.
And now a few pictures.
Cheers, Joachim
Link to comment
Hello folks,
and again a bit further, now the staysails between forestay and main mast are finished and attached. The staysails don't have so many lines, only halyards, downhauls and sheets, but the tethering of the jib riders is quite time-consuming.
I had a hard time with the pictures, but I hope it will come over. When an intermediate result is reached again, I will photograph the ship in my wife's photo studio, that will be a bit better.
First of all the sails have to be prepared, also more than 50 jib riders are needed.
Cheers, Joachim
Link to comment
Joachim,
As always - a masterpiece indeed!!
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Many thanks for the compliments and the Likes :)
Cheers, Joachim
Link to comment
Dear colleagues, enough time has already passed and things must continue here.
Well, the mizzen sail is on today. First I had to make the tree and the gaff. And that's how they look in the group picture:
The outermost end of the gaff is fitted with an attachment with a deflection pulley for a flag. There I tried again my soldering arts, well, at least painted it looks quite bearable.
At the gaff there are also some pulleys for Gordings attached and finally the gaff must be able to be fixed behind the snow-mast.
Of course the tree also has several fitting parts, to see here, the guides of the lower leech stretcher, which is led first over a deflection pulley in the tree and then under this by the illustrated guides for the attachment to the bitt.
And now the gaff with the mizzen sail attached.
Cheers
Joachim
Link to comment
By the way, I had received a fantastic review of my book from Chris. You can read it here:
Cheers
Joachim
Link to comment
Wunderbar Joachim !
I just came across your lovely buildand am very much impressed about your handcraft skills. Those sails are top notch, I`m wondering how you got the different colors in the reinforcement patched areas,
A very nice model    :)  :)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
  • 10 months later...
good evening
as i have restarted my AV do you have any build photos of the hull and deck fittings prior to your first entry in 2013?
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
  • 5 months later...
flawless execution of a beautiful model, not at all easy to make.  really nice compliments
greetings
Iosto
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
La Jacinthe French Schooner
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Bisquine La Granvillaise
Fishing-boat
English pinnace
18th Century Longboat
Link to comment
  • 1 year later...
6 hours ago, DanielD said:
This is a spectacular build. I'm getting ready to start my own Amerigo Vespucci and will frequently review your log as I build mine.
I have also been following his build for a few years now, as I try to try to finish mine
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
  • The title was changed to Amerigo Vespucci 1931 by schiffebastler - Mantua - scale 1:84 - Italian sail training ship build
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
