Lady Nelson by Leo-zd - 1:119 - SMALL
The problem with the bell was that (the one on the photo) was too big :angry:
So after painting, returned to dremell and sandpaper and reduced it on a half of size , now is OK (a bit too big so, but it could pass) :pirate41:
Edited by Leo-zd
Link to comment
Share on other sites
The bell is reduced, painted and put on its place, I also put the piece of rope underside.
I decided to made a stove, in fact just a chimney tube because fortunately nothing can bee seen inside.
I used styrene tube , external diameter 2,4mm and piece of styrene strip for the base.
As this is armed cutter, the cannon without ammunition are useless so i decided to put the cannon balls.
Fist options were the balls in cartigge for hunting rifle but the smallest are 1,5mm and that is so big.
I chosen the steel balls from ball-bearing, the smallest one is 1 mm diameter, approximately the dimension I needed.  It was a bit laborious to made the wooden support  (1*2 mm) and as could see it isn't perfect but it is so small that I think it will be OK.
The problem is the brightness and color of balls, but wasn't possible to color so small and glanced surfaces.
Maybe the mat transparent coat will got better appearance.
At last one photo with the laptop monitor just to indicate the real dimension and the fact that in reality all is much smaller than on the screen( especially errors and imprecision)
Link to comment
Thk Patrick, but You knew it, newer satisfied and allays wish better and more precise, but honesty for the work done yes a lot :D
Link to comment
Link to comment
attacked racks and chimney and group picks with new , a bit eclectic, work.. the heart of paper.
Link to comment
Thk..
The second hul is Le Coureur, time ago I found (download) paper model for this boat.
Al started as a play, I wanted to see how is to made a paper model.(in fact I like the hull forms)
Nturaly I reduced to 1:120 , and printed on first harder paper I found (You can see that on internal part is something printed, I think that was one envelope for assurance contract or similar).
It's interesting to work with paper :D , naturaly, as the paper wasn't the adequate thickness although i glued two together the hull's first layer wasn't as I expected.
So I impregnated it with CA glue and then covered with mono-component car putty (IMPA) which dries relatively fast and it is pretty strong and easily sanded.
When finished with that putty coated with liquid fine putty Mr Surfacer , sanded with water card 1000 and polished with piece of cotton and nail laquer remover (with acetone)
So the play became serious and probably I will open a thread :)
Edited by Leo-zd
Link to comment
Thk..
Hi Leo
That sounds really interesting!
Nice
Cheers Patrick
Link to comment
Lady Nelson 16,7 cm
Le Coureur  about 18 cm
The picture is deformed as is taken with wide angle lens , I haven't a tripod so it was easier to take pictures with widest angle of zoom.
Edited by Leo-zd
Link to comment
Today the captain decided to visit the yard so it was necessary to mount the ladders
Link to comment
Thk Patrick
External ladders are a bit outdimensioned, I used the 0,6 mm plywood but seems to bee too big.
Probably I'll pass darker tone on it to made slimmer :D
Link to comment
Nothing new but as I made this photos for another purpose (macro theme on one forum) and as this is a interesting indication of scale I decided to put it here.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
