Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Half Moon by Popeye - Billings 1:40 scale kit
  • Please log in to reply
783 replies to this topic
#1
popeye the sailor
popeye the sailor
    imagine
  • Members
  • 6,256 posts
  • LocationManchester N.H.
I came in possession of this kit quite by surprise.   the box was fairly intact,  with only minor damage on one of the side panels.  along with it,  were a few assorted bundles of planking and a package of different size dowels.  one of the bundles was for this kit........
Attached File  #1.JPG   91.78KB   8 downloads
I added it to the kit.......to the bundle of planking that was already in there.......I guess I'll have more than enough.  doing a complete inspection of the contents,  I found that I was missing a good deal of parts.
Attached File  #2.JPG   81.22KB   3 downloads
Attached File  #3.JPG   74.4KB   2 downloads
Attached File  #4.JPG   76.75KB   2 downloads
I took pictures of the contents,  after I removed the hull parts........they,  at least,  are all there.   I contemplated renaming the ship,  but it would be hard to do,  since most of the ships that I know of,  all sport these tops {crows nests}.   some of the deck platforms,  most of the crows nest parts,  the cannon port lids,  and some of the deck fittings {wood},  is a pretty good tally of what's missing.   I see I'll be doing a good deal of scratch work.   the bones are all there......I think I can make it work ;)
  • trippwj, Anja, SkerryAmp and 3 others like this
I yam wot I yam!
finished builds:
Billings Nordkap 476 / Billings Cux 87 / Billings Mary Ann
Billings Regina - bashed into the Susan A
M&M Fun Ship - semi scratch build / Gundalow - scratch build
Phylly C & Denny-Zen - the Lobsie twins - bashed / semi scratch dual build
Billing's AmericA -reissue
Andrea Gail 1:20 - semi scratch using Billing's instructions
on the table:
Billing's Gothenborg 1:100
Billing's Boulogne Etaples 1:20
Revell U.S.S. United States 1:96 - plastic/ wood modified
Trawler Syborn - semi scratch
Holiday Harbor dual build - semi scratch
Academy Titanic 1:400
#2
Jim Lad
Jim Lad
    Moderator
  • Moderators
  • 4,158 posts
  • LocationSydney Australia
Of course you can make it work, Popeye!  You're being drawn inexorably into the gaping maws of the (shudder) DARK SIDE!!!!!!!! :D
jOHN
  • mtaylor and Bindy like this
#3
Augie
Augie
    Ship's Cat
  • Members
  • 5,235 posts
  • LocationColorado, USA
If anyone can pull this off it's you, Popeye.  Looking forward to the voyage!!!!
Augie
Current Build:    US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises  (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
#4
popeye the sailor
popeye the sailor
    imagine
  • Members
  • 6,256 posts
what is missing probably amounts to a complete parts panel.   the kit also was to come with a build slip,  but the only parts in there for it was the slip rail.  I put it together.......
Attached File  #1.JPG   89.75KB   2 downloads
the keel parts were cemented together.
Attached File  #2.JPG   81.09KB   3 downloads
Attached File  #3.JPG   75.36KB   3 downloads
I got the instructions........I can get some insight as to what the parts are to look like.   this is so cool!  I miss the smell of wood.........after the hull is painted on any kit that I've done,  there is only limited wood fabrication to do......the small parts and fittings for the deck and mast.  even with the rigging,  which I love to do,  can become tedious.  this is probably the main reason why I amass builds the way I do......
not because I'm in the habit of not finishing a kit,  but that I miss the construction part of it......
making sawdust.   this kit couldn't have come to me at a more opportune time........it will make for a perfect companion,  for the kit I plan on finishing next.   well......anyway.........
the build slip came out of the closet.
Attached File  #4.JPG   89.28KB   1 downloads
Attached File  #5.JPG   89.66KB   0 downloads
I had punched out all the cast off from the bow stem.   I had already dry fitted and tested the parts.....a nice fit.   the build went on.
Attached File  #6.JPG   72.91KB   0 downloads
Attached File  #7.JPG   90.66KB   0 downloads
I added short pieces of 3/16 square stock in between the ribs to aide in locking them in.
Attached File  #8.JPG   61.32KB   0 downloads
Attached File  #9.JPG   62.7KB   0 downloads
Attached File  #10.JPG   51.73KB   0 downloads
the hull frame assembly continued.
Attached File  #11.JPG   95.44KB   0 downloads
Attached File  #12.JPG   85.92KB   0 downloads
before the transom rib was cemented in place,  the deck joices were slid in place.  I went all the way forward to rib #6,  and all the way back to rib #13  {strange way to number parts}.
Attached File  #13.JPG   86.43KB   3 downloads
Attached File  #14.JPG   71.3KB   2 downloads
Attached File  #15.JPG   86.73KB   3 downloads
Attached File  #16.JPG   67.73KB   2 downloads
Attached File  #17.JPG   95.25KB   1 downloads
the transom rib finishes off the frame assembly.  I will be adding short strips under both ends of the joices for support.
Attached File  #18.JPG   96.84KB   1 downloads
Attached File  #19.JPG   90.64KB   0 downloads
there are the bow rabbits that still need to be cemented in place.
  • SkerryAmp and Senior ole salt like this
I yam wot I yam!
finished builds:
on the table:
#5
Jim Lad
Jim Lad
    Moderator
  • Moderators
  • 4,158 posts
Ummm, I thought you were cutting down on the number of builds you were doing at once, Popeye? :huh:  :)
John
#6
popeye the sailor
popeye the sailor
    imagine
  • Members
  • 6,256 posts
thank you Augie and John for your vote of confidence.    roll the bones............darn!  they STILL tell me nothing! :)
I got back to 'er........now,  to make heads or tails of the deck platforms.   I was simply going to plank over the ribs,  but staggering the planks every  "1"  didn't impress me.   I did run into my first chigger.....in handling the frame,  I broke the thin bridge along the top of the bow stem.   I fixed it and put the cast off back in to protect it.
Attached File  #1.JPG   60.5KB   1 downloads
you can see the supports for the joices I put in there.   the deck platforms I have are fitted in place.
Attached File  #2.JPG   83.58KB   1 downloads
the main deck platform is supposed to be in two sections.......I did it as a single piece.
Attached File  #3.JPG   60.93KB   0 downloads
after marking out the bulwark posts,  lines were drawn and the notches were cut out.
Attached File  #4.JPG   63.83KB   0 downloads
Attached File  #5.JPG   66.71KB   1 downloads
Attached File  #6.JPG   83.1KB   1 downloads
there is a rounded section of decking that is to go at the bow.   it is to be level with the main deck.
Attached File  #7.JPG   68.74KB   1 downloads
I got to this section of decking the following day.....in between working on the AmericA  {all of this was,  for that matter}..........the upper mizzen deck
Attached File  #1.JPG   79.8KB   1 downloads
Attached File  #2.JPG   79.48KB   3 downloads
I'm going to add in small pieces of square stock under where the bulwark posts are {underneath} to support the platforms,  when the frame is fared.   they need to be flush to the inner walls,  come time for planking.   this puts the build up to speed......I can update as I go along.   enjoy!
  • SkerryAmp, Senior ole salt and Chief Don like this
I yam wot I yam!
finished builds:
on the table:
#7
popeye the sailor
popeye the sailor
    imagine
  • Members
  • 6,256 posts
I know John........my inability to keep one's hands out of the box........I am guilty.......I am sooooooooo guilty.   I'll be doing the Gothenborg, which is very close to her rigging stage.  this will make for a good companion,  planking the hull and decks,  while I do the rigging  :)
I have one other card to play as well..........you've seen it John,  remember ;)
I yam wot I yam!
finished builds:
on the table:
#8
Augie
Augie
    Ship's Cat
  • Members
  • 5,235 posts
Great Scott------you're already at warp speed!!!!!
  • Chief Don likes this
Augie
Previous Builds :
#9
mtaylor
mtaylor
    Bilge Rat
  • SPECIAL CONTRIBUTOR
  • 9,810 posts
  • LocationMedford, OR
"Damn it Jim, he's a shipwright not a doctor."    Ok.. so I misquoted... sue me.
Popeye, you are amazing... models just popping up on the workbench as if by magic.
#10
Sjors
Sjors
    On the road again
  • Members
  • 5,112 posts
  • LocationSchiedam, Netherlands
Hi Popeye,
So this is the surprise!
Nice one  :D
I think you need to rent the house of the neighbours to place all those builds.
I have now an other one to follow…..
Now we can see the difference between the Corel kit and the BB kit.
We will see how it ends.
Bon Voyage with this one.
Current Builds: HMS Agamemnon by Sjors - Caldercraft / Jotika - 1:64
Finished builds:
San Ildefonso by Sjors - OcCre - Wood (1:70)
Smit Rotterdam by BB
Spirit of Mississippi by OcCre
Corsair by OcCre
Le Mirage by Corel
#11
Anja
Anja
    Moderator
  • Moderators
  • 3,274 posts
  • LocationSchiedam, the Netherlands
Hello Popeye,
The Half Moon ..... What a surprise. animaatjes-smiley-met-bordje-65103.gif animaatjes-smiley-met-bordje-64395.gif
Will you be following the plans or just go with comes into mind?
Whatever you do, with your skills and imagination, she will be a beauty.
Enjoy this build.
Take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
Current build - Half Moon by Anja - Corel – Wood 1:50 (d’Halve Maen)
Next build: Schooner Hannah - POF Hahn style - First scratchbuild
Completed : Albatros 1840 by Constructo
#12
trippwj
trippwj
    Scullery Maid
  • Members
  • 3,028 posts
  • LocationEastport, Maine, USA
Wicked nice start, Dennis.  Will join the crew to watch this one as well!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
#13
patrickmil
patrickmil
    Dangerous with Woodworking Tools
  • Members
  • 1,187 posts
  • LocationColumbus, OH
Surprise surprise.... you've got yet another build going....  LOL and just kidding around. It looks like you have a great start and I doubt you will have any trouble with making up for missing parts. BTW, you need to update your signature. It's the only way we have track of all your builds.
#14
popeye the sailor
popeye the sailor
    imagine
  • Members
  • 6,256 posts
thanks Augie ;)
thanks Mark..............this hobby is sure amazing,  isn't it.
thanks Sjors and Anja..    yup,  this is the surprise.   it will be very interesting comparing the corel kit with the Billing's kit.  I'm going to be following the plans....they look good, but I will also be looking at pictures I may find of her.   it will be a good build.....thanks again ;)
welcome aboard Wayne..........thanks!
thanks Patrick.......well,  I have a reputation to uphold ;)   I can do a little rigging.........make a little sawdust........do some more rigging,  you know,  always something to do.   I will adjust my signature........thanks for the good word ;)
I yam wot I yam!
finished builds:
on the table:
#15
Sjors
Sjors
    On the road again
  • Members
  • 5,112 posts
If you need pictures of her Popeye let us know.
Anja has a lot of them somewhere…...
She have also a book about the Half Moon.
If you want anything to know, you know where you can find us.
Finished builds:
Corsair by OcCre
Le Mirage by Corel
#16
Sherry
Sherry
  • Members
  • 947 posts
  • LocationOntario, Canada
Wow Popeye - I am amazed how many ships you take on at once, and all look great. This is, and will be, no exception. I guess I'll pull up a chair. :)
  • popeye the sailor likes this
Sherry
Every goodbye is the birth of a memory...
Current Build: San Felipe
Finished Builds: Mayflower Build Log
Gallery: Mayflower
#17
Sjors
Sjors
    On the road again
  • Members
  • 5,112 posts
Let me help you Sherry.
Popeye is to buzzy with his builds…..
Finished builds:
Corsair by OcCre
Le Mirage by Corel
#18
popeye the sailor
popeye the sailor
    imagine
  • Members
  • 6,256 posts
I'll keep that in mind Sjors........I'm sure Anja would love to assist ;)
thanks Sherry........story of my life :)    got into this habit early.........build and paint,  then let it sit to dry with nothing to do.  so I'd work on another build until I can get back to what I was doing.   the wharf is a busy place ;)   glad to have you looking in.
I yam wot I yam!
finished builds:
on the table:
#19
mobbsie
mobbsie
  • Members
  • 1,342 posts
  • LocationHarwich UK
Popeye, I've just fallen off me bloomin chair, :D  boy you really are traveling at a speed on this one. :o  :o
It was only yesterday I saw that kit in the box, now she's almost finished, well not really. ;)
Got my seat close by and am already waiting for a viewing position. :huh:
Have fun buddy.
mobbsie
Posted Image
mobbsie
All mistakes are deliberate ( me )
Current Build:- Granado Cross Section 1/48 in Unison with Grant, Jack Panzeca & ASAT ( Lou ) :- Scratch Build ( the dark side beckons )
Completed Builds :-
HMS Agamemnon 1781 - 1/64 Caldercraft Kit
HM Brig Badger,
HM Bomb Vessel Granado,
Thames Steam Launch Louise
Thames Barge Edme
Viking Dragon Boat
Next Build :- Ships Battle Station
#20
popeye the sailor
popeye the sailor
    imagine
  • Members
  • 6,256 posts
too funny Mobbsie...........I've just begun :)    I figure that by the time I get most of the planking done  {there's a lot of it},  I should be well on the way with the Gothenborg.........masting and rigging {the yards probably won't be up by then.......I'm not that good}.   it should be fun though.....especially having to make all these missing parts.   thanks for the good word,  my friend!  :)
I yam wot I yam!
finished builds:
on the table:
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
