HOGA (YT-146) by Cap'n'Bob - SMALL - 1:96 - Navy yard tug - Finished
  • 4 months later...
Oh, okay... I'll put you guys out of your misery. Here's the USN's Booklet of General Plans, 1944, for the Woban Class. You'll have to draw your own lines drawings using the sections provided, but that's easy enough. The PDF is high-pixel quality and can be enlarged by holding down your "control" key and turning your mouse wheel.
See: https://maritime.org/doc/plans/ytb142.pdf
Link to comment
Share on other sites
That would work but not quite as accurate, I Did find these  plans and by applying the 109ft should work as the under water shape is similar. If I drew out the section plans and compared them they should be similar.
Cheers, Guy
The Learner
Current Member NRG,SMA
Current Build: HMS Triton 1:48 on line
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
