HMS Victory by dafi - Heller - PLASTIC - To Victory and beyond ...
The question is: would Nelson recognise this entry-port....
There is a nice model in NMM showing Victory as she was supposed to be n 1803 without the entry-ports.http://collections.rmg.co.uk/collections/objects/66474.html
There is alos a model that shows victory as she was supposed to be in 1805 sith entryports and even a platform outside the hull....
http://collections.rmg.co.uk/collections/objects/66475.html
The one without is assumed to be the contemporary model
Jan
Note the important wording in the description on the 1803 model - "Model also shows further modifications which were proposed after Trafalgar which were not carried out".  Even contemporary models represent many different things, probably in a world before CAD design it was the most effective way to convey ideas for real world discussion rather than attempting to be a definitive reference manual for how the ships looked at a particular time.  All this is speculation without definitive proof...which is why its so fun because no-one is wrong :-)
Edited by Beef Wellington
Cheers,
Jason
In the shipyard:
Link to comment
Share on other sites
Please also see http://modelshipworld.com/index.php?/topic/333-side-entry-ports-on-british-first-and-second-rates/#entry109230
There is a copy, for the content of this discussion not to be lost in my thread only.
XXXDAn
Link to comment
And I still do not give up the dream, that one day my lower gundeck will be finished, I managed to prepare some ...
... and to do some more ...
... to come closer to this dream of mine.
XXXDAn
Edited by dafi
Link to comment
The lower gundeck ...
.. perhaps ...
XXXDAn
Link to comment
i love the stern decoration in this photo
i will remove this post - if your unhappy with me posting it
Edited by Kevin
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
No, leave it, it is a great picture!
XXXDAn
Link to comment
would that be the design after they closed the stern in and then before the big repair
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
As Wellington mentioned above - this line submits the model to suggestions of your wildest dreams ;-)
XXXDAn
Link to comment
A few thoughts, if I may.   The photos reference by Jan have interest in that the model with the entry port doesn't have the boarding ladder going above the entry port.  As I recall, entry ports were for the exclusive use of the brass.  Everyone else had to go up and over the top.  Is this a faulty assumption?  The model says "yes, everyone boarded the ship via the entry port".
The other two pic show "without entry ports".... if they weren't there, and there's only 28 guns, which ports would have been empty?  Unless the very formost were used as a bridle port.  Curiously, many of the contemporary models and paintings show the ports, yet the photo from 1909 doesn't.
A pity we don't have a time machine....
Link to comment
So the pot is empty ...
... time to do something more important and worthy ...
... as both scuttles for the vent trunks were mere black holes. So they got their wooden cases and look much more in tune now  :-)
And here some fresh impressions from the shipyard.
Good night, Daniel
Link to comment
Fantastic, Daniel.
Link to comment
splendid work Daniel.......the rigging looks great!    so life-like  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I have a question, not on your fantastic technique, but on the reality of gun-handling....
Quite often, you see ringbolts placed in the deck, and a tackle rigged (sometimes even two) to haul back the gun in order to sponge out and load.
Seeing how far the gun has to be run backwards to get the sponge in the barrel, I was wondering: were should the ringbolts be placed to get the system working?
Jan
Link to comment
Thank you Sirs :-)
Jan, the tackle in the back usually is a single one (only the French had a double tackle for 36 or 46 ponders). It was hooked into the ring that was as much at the center line as possible. At the Vic, the plans show the rings more or less at the line that coaming/gratings give.
At the last picture with the reloading of the gun, the rings are situated just beside the anchor cable, which is just enough for the tackle to work.
Here two more of the rings to be seen.
XXXDAn
Edited by dafi
Link to comment
Jan,
Dafi is correct. The ringbolts were normally positioned as near to the centreline, behind each gun, as was possible. This would give the tackle the maximum amount of room to operate and be effective. However, depending on the gun's position, I am not sure that the guns always entirely cleared their ports, and there are instances of the rammer and sponger having to operate with their implements out of the port. Incidentally, the gun's own recoil would normally return it to the loading position.
Regarding the entry ports, Goodwin in his 'Construction and Fitting of the Sailing Man of War', says that they were fitted between 1660 and 1810, although some ships continued their use after that date. That is presumably why early 20th cent. photos of the Victory show her without an entry port. He also states that the first use of entry ports, port and starboard, was from 1671.
As to their use, I think Mark is right, and that they were for the use of senior officers only. I may be wrong here, but I'm not sure lowly mids and lieutenants would have been allowed to use it, unless they had special dispensation.
Edited by Stockholm tar
Kester
Current builds: Sherbourne (Caldercraft) scale – 1/64th;
Statsraad Lehmkuhl (half model) 1/8th" – 1'.
Victory Bow Section (Panart/Mantua) scale – 1/78th  (on hold).
Previous build: Bluenose ll (Billings) scale – 1/100th.
Link to comment
Thanks!
I'm more used to models that place themlike Jotika suggests...
Jan
THAT is far too near, as the gun would run over. It should be just where the opening starts.
Also the breeching line is far too short :-)
Gruß, Daniel
Edited by dafi
Link to comment
Thank you Maurice :-)
And what does one do if one is bored? One starts pimping around ...
... with the gunport lids I alreadyshowed, that it is possible, to attach the needed ring onto the eyebolts, so why not doing this on a larger scale, say perhaps the breeching ropes?!?
So ripped the single guidance ring for the breeching rope out of the carriage, build in the new double one and already prepared the rest. So it looks like there still was place for improvment in the old carriage ;-)
And of course attached the breeching ropes - again showing the infamous goodwin´s preventer breeching rope - and here we are, gun 2.0, aka Dr. Tentacle :-)
And here he comes, Dr. Tentacle´s arch enemy, the incredible Dr. dafi ® - terror of all multi-armed creatures, in his insatiable wish to bind Dr. Tentacle and confine him down onto a secure place!
Cleverly Dr. dafi ® puts up a trap:
... a needle on a shish kebab skewer ...
... makes the aiming markings on the inner hull :-)
Afterwards - no not the same picture again ...
... no this time ...
... there is a fine drill attached :-)
Then Dr. Tentacle was lured into the trap ...
... and detained :-)
...hihihihihihihihi...
... see him fidgeting around in despair but no more escape will be his :-)
Once again Dr. dafi ® wins and shows the limits to one more abominable creature of maritime navyisms!
And please tune in again next week, when we will show: Who the hell is Captain Hook?!?
Greetings from the tentacle-tamer, Dr. dafi ®
Link to comment
is he still there?
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
ohhhhhhhh.....my head.......it's......vibrating!  the pressure.........it's starting to build!   too much..........I've got....information overload!  arggggggggg!
would this be the norm for larger bore cannons?   I can imagine the recoil in touching one of these bad boys off.  you make thing so interesting..........and looks good in the process  ;)       I really enjoy what you do,   good Dr.  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Sirs :-)
Kevin who?
- Dr dafi® still around, alive and kicking !!!
- Dr. Tentacle is still there to all eternity - he can´t move any more ...
- Captain Hook? Who the hell is Captain Hook?
Popeye: As mentioned earlier, the only source I find so far for the preventer breeching is Goodwin. But as in the rigging all important systems are with a redundancy system to get fail safe, I see it quite logical to have one on the breeching ropes too in case of breaking while firing the gun or due to battle damage. Showing it in the build is of course some kind of risky, but  I would like to put this feature up to discussion by doing so. Perhaps this helps to enlighten the affair. Does anybody has any clue or where Goodwin has his sources from?
Jan: The special treatment just will be just for those 6 guns that will be run out, as they still will be in the photographic focus for some future documentation. The installed lashed up ones will stay the way they are :-)
But as there is always a growth in ability and know-how, there will be always new solutions and perhaps I will still find out new tricks for the guns on display on the upper deck - who knows, I am already beyond everything that I ever imagined in my wildest dreams when I started this build :-)
Cheers, Daniel
Edited by dafi
Link to comment
Daniel,
I like the kebab stick idea for reaching right through the ship to mark and drill. I am about to do some retro fitting around my cannon so I now know how to do the drilling required! :dancetl6:
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
Link to comment
Are you sure - a week is a long time,
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Do not worry, I will have a close eye on him :-)
Thanks Kevin, Ian and Channell
Edited by dafi
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
