HMS Victory by dafi - Heller - PLASTIC - To Victory and beyond ...
Dafi,
From your photo you appear to be "going at it hammer and tongs" (or at least pliers) which is an old UK blacksmithing related phrase meaning going at something really fast and hard.
I am intrigued by the character watching over you past your left ear.
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
Link to comment
Share on other sites
And now, its Hammer Time!
That is the result of well planned building activities.
In the old days I fixed the standing knees without being able to level the upper edge, now that I can, the deck is quite clattered with other activities ...
... time to get out the heavy tools for some desperate measures.
The blade laid over the now existing beams and with some persuasiveness of the hammer (or tweezers as they are smaller) split the knees to pieces.
After the first trials I replaced the hammer with better dosed hand enforcement and it worked wonders.
The bounty was rewarding.
Almost no collateral damages, just some sailors looked a bit down, but they are already up to their feet again :-)
Cheers, Daniel
Finest etch parts for HMS Victory 1:100 (Heller Kit) and other useful bits.
Link to comment
Good heavens Dafi. You are worse than I am for attacking your ship with shovels and rakes and implements of destruction!
Ian M.
Link to comment
... oh Ian, you know, I did not even start yet ...
... breaking bad ;-)
XXXDAn
Edited by dafi
Link to comment
blow torch.....jack hammer........no problem!  keen to see what your idea is  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Dafi I just love following your work
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Every single time I check this build I get excited and terrified  to start my one.  I know that I will be ordering every Dafi option before I start, already started collecting copper sheeting etc.  I don't expect to be near this level but you have certainly more than shown what is possible despite limitations of the kit.
Amazing.  Simply amazing work and research.
1775 / 1893
Link to comment
Thank you Popeye, Kevin and Orca!
And Orca - just do it !
XXXDAn
Link to comment
Statement 1:
dafi is torturing wood. For the first time I was bending watered wood with the soldering iron - fascinating for a stubborn plastinator how willingly even 3 x 3 mm battens take the right turn :-)
And why this? Originally planned were 5 deck beams to hold the upper deck, but for some unknown reasons the number of deck beams became larger ...
The other deck beams are forced into the curve by the stanchions, but if those are missing ?
Statement 2:
Holes that mean the world - at least to me ;-)
As already seen midships, where the anchor cable is disappearing towards the hold ...
... one can nicely see ...
... how much ladders and stanchions are in the way if it is to work there.
So using swift the jack ...
... and lift the deck beam - and with it all the upper decks - some inches or so, take out the ladders and stanchions ...
... and all that is left on the deck are some small holes and plenty of space to work. Now I too understood the short arms of the jack - it allows to go near the stanchions or even the hull. And as my new deck beams are already fitted with a nice curve, they stay nicely up as they should.
Thinking about the color of the space underneath the stanchions, I believe that the wood in itself possibly stayed with a lighter color, but with all the muck from cleaning that went underneath I opted for a dark brown.
So I prepared the taken out stanchions ...
... pimped them up ...
... and cluttered them together with the ladders behind the companionway.
Looked pittoresk, but not really Bristol fashion, so I preferred the following solution :-)
Question: How were the ladders - if in place - secured on the deck? Was there there chocks or wedges or something nailed to the planks?
Cheers, Daniel
PS: Do not worry on the first pictures, there is no fire in the hold. Just a small ball of wad is doing wonders against the unsought will of certain parts that strongly do believe that their future should be in the hold :-)
Link to comment
Do not worry Jan, I already projected a ramp for easy wheel chair access beside ;-)
XXXDAn
Link to comment
And todays Oscar for best suspense goes to ...
... dafi ...
Edited by dafi
Link to comment
And the Oscar for best destruction sequence goes to ...
... dafi ...
Edited by dafi
Link to comment
Where's the pictures on the split screen?  Who else was nominated?  Was there a fist fight in the audience when the winner was announced?     :D  :D  :D  :D
Link to comment
Im worried about the fire below, hope you dont loose the supply of tic tacs
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Oh yes the spech, Mark - still in the phase of having to peep away most of the expressions ...
Do not worry Kev, all Tic Tacs are all doing well!
So Jan, kudo now!
XXXDAn
Link to comment
... no words ...
XXXDAn
Link to comment
Naughty-naughty-messenger, naughty!
XXXDAn
Link to comment
When I first installed the messenger I was opting for the display in Portsmouth, showing a left handed rope as described by Nares for later periods. Now much time later, I have not yet found a source for this setup in the period around 1800. Here are the two cables to compare.
Link to comment
That´s why Ms. Cyrus inspired me ...
... using the wrecking ball and ...
... even though fully dressed taking carefully out the components in question. Luckily the nippers were fixed the right way and ...
... could get off easily. Just call me a smart Nipper :-)
The original build was shown in details, so we have only a fast tour of the changes
The lashing of the messenger ...
... the rolls to guide the messenger around the bows and the guy with the hose to water the incoming anchor cable and the boys to clewan it with a brush.
The bosums mate surveys those 4 gents nipping the two cables ...
überwacht diese vier Herren beim Befestigen der Nippers, der Taustücke, welche Kabelaar und Ankerkabel zusammenhalten ...
... while these man escort the cables backwards ...
... and those to open the nippers for the anchor cable to disappear in the hold. I gave a bit more space to those gents by taking out the pillars in that area.
Link to comment
The messenger still moves backwards and changes direction on those solid stanchions ...
... towards the capstan ...
... and the strain of the pulling already worked the messenger up the drum.
Behind the capstan 3 gents are pulling the rope clear ...
... in that area I placed two more stanchions as they are out of the way and on the rest of the track ...
... some other gents make sure that the messenger is moving swiftly forwards again.
Cheers, Daniel
Link to comment
Well.. at least we didn't have to shoot the messenger.  Just replace him.    :D  :D  :D
I'll go quietly now... oh.. there's my coat.. post-76-0-75428300-1454318702.png
And a little happy dance for all this deconstruction and re-construction....  post-76-0-24916500-1454318753.gif
Link to comment
would there be sailors tending the capstan while this is going on?   interesting that it's the messenger that is wound 'round the capstan and not the anchor rope itself........to be honest,  until I came to this site,  I was not sure how this process worked.  you've done well in shedding light on the process.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Hi Dafi,
there`s real life action on your decks,.........looks wonderful with all those little guys
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
