Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Swift by themadchemist - AL - 1:50 - The Dock Side of the Moon, Pink Floyd custom build
  • Please log in to reply
1559 replies to this topic
#1
themadchemist
themadchemist
  • Members
  • 2,519 posts
  • LocationJohnston City, Illinois
00 - The Kit - Artesania Latina - Swift Virginia Pilot Boat 1805
Greetings to MSW 2.0,
As I embark on a second attempt at a wooden kit, but this time I've stepped up the kit from a canoe to something with sails and rigging. Ive noticed the Swift 1805 models are quite common on ebay, which is where I found this one. Upon ordering I didn't realize that the kit had been upgraded/modified, but at the price I paid I cant really complain.
As I was in the built of the peterboro canoe when the kit arrived I only gave it a quick run through for completeness. I then later before prebuild did a complete inventory and found all part present and accounted for, so off to the dry docks she going.
I'm sure many pictures of this kit abound but I find it interesting that of  the 8 pages of instructions (pictured) there is really only 4 1/2 pages of actual instructions once the introduction and parts list are deducted. Hopefully The newer version has improvements in this area, but then figuring things out can be almost as much fun as having everything spelled out for you.
Again, as with the Peterboro, I chose this kit as a tutorial. It shold give me experience with a double planking and rigging before I attemt a larger more intricate kit (ie one with rat lines).
So here are a few picture of the kit dated the year I graduated high school, 1982.
  • Attached File  1.jpg   153.11KB   21 downloads
  • Attached File  2.jpg   136.24KB   11 downloads
  • Attached File  3.jpg   255.07KB   10 downloads
  • Attached File  4.jpg   286.39KB   8 downloads
  • Attached File  5.jpg   248.58KB   8 downloads
  • Attached File  6.jpg   107.76KB   9 downloads
  • Attached File  7.jpg   230.38KB   10 downloads
  • Attached File  8.jpg   234.39KB   9 downloads
  • Attached File  9.jpg   226.48KB   10 downloads
  • Attached File  10.jpg   245.85KB   8 downloads
Edited by themadchemist, 25 October 2013 - 02:09 AM.
  • E&T, John E., ringbolt2013 and 1 other like this
Shine On -/\=
Keith (tmc)
Whatever you do will be insignificant, but it is very important that you do it.
 — Mahatma Gandhi
Current build: Swift - AL - 1:50 - Dock Side of the Moon, Pink Floyd custom build
Side project: Longboat - MS - 90mm of Holly and Ebony
Almost completed: Peterboro Canoe - Midwest - 1:12
Complete: Dinghy - Midwest - 1:12
#2
philo426
philo426
  • Members
  • 556 posts
Yes I am working on the same kit.Should be a fun learning experience!
  • John E. likes this
#3
Adrieke
Adrieke
  • Members
  • 2,197 posts
  • LocationSydney
its a nice model to learn on  :)
are you plannin gon making sails for her as i beliee they are not included ?
  • John E. and ringbolt2013 like this
achter elke traan van verdriet, zit een glimlach van herinnering
behind each tear of sadness, there is a smile of a memory
farewell my friend I ll miss you
Current build : OcCre Gorch Fock 1/95
Next build : AL HMB Endeavour 1/60
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : MMSD San Salvador (Card) 1:100
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
#4
themadchemist
themadchemist
  • Members
  • 2,519 posts
01 - Bulkhead and Keel Construction (part 1)
I debated on how to approach squaring the bulkheads to the keel for a couple of days until I finally decide to use angle aluminum. I used a 3/4" width 1/8" thickness angle as I wanted enough thickness in the jig to not allow any give and the thinner 1/16 angle seemed a bit flimsy. I made a 2" and 3" set for this and future builds and had enough stock left for other projects.
  • Attached File  1.jpg   229.88KB   8 downloads
  • Attached File  2.jpg   237.17KB   10 downloads
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#5
themadchemist
themadchemist
  • Members
  • 2,519 posts
01 - Bulkhead and Keel Construction (part 2)
The bulkheads were glue using PVA glue and clamped down using the angle aluminum and squeeze clamps in 2 planes. Of course Al had to get in on the act and check all my placements before giving his victory dance atop the work in progress.
  • Attached File  3.jpg   150.19KB   7 downloads
  • Attached File  4.jpg   197.18KB   5 downloads
  • Attached File  5.jpg   218.11KB   2 downloads
  • Attached File  6.jpg   221.21KB   4 downloads
  • Attached File  7.jpg   190.37KB   4 downloads
  • Attached File  8.jpg   210KB   3 downloads
  • Attached File  9.jpg   134.4KB   4 downloads
  • dgbot, E&T, CaptainSteve and 3 others like this
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#6
themadchemist
themadchemist
  • Members
  • 2,519 posts
01 - Bulkhead and Keel Construction (part 3)
After gluing of all bulkheads into place one can see a bit of a curvature in the keel. This will be addressed later. Bulkheads were aligned at the top of the keel with the low point of the keel as the curvature of the deck would require fairing before deck placement.
  • Attached File  10.jpg   135.81KB   2 downloads
  • Attached File  11.jpg   247.43KB   1 downloads
  • Attached File  12.jpg   203.86KB   3 downloads
  • Jaxboat and John E. like this
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#7
themadchemist
themadchemist
  • Members
  • 2,519 posts
02 - Setting The Mast Blocks
As with the bulkheads, the mast blocks were glued using PVA glue. Slide arm ratchet clamps were used as the clamping distancew as larger with the blocks. Blocks were also aligned with the top of the keel, again with the lowest point of the block so that again the block could be faired before deck placement.
  • Attached File  1.jpg   154.27KB   6 downloads
  • Attached File  2.jpg   157.8KB   5 downloads
  • Attached File  3.jpg   196.83KB   4 downloads
  • Attached File  4.jpg   215.85KB   3 downloads
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#8
themadchemist
themadchemist
  • Members
  • 2,519 posts
Hello Philo426 and Adrieke
The kit didnt come with sails but there is a plan layout sheet for their construction. as the rigging isnt very intricate on this one I figured I'd put sails on her. Havent Decided furled or unfurled but most likely unfurled. I'd love to know how to shape the sail as if she is tacking in a nice breeze. That is the one thing about sails that often make the ship look dead in the water, limp lifeless sails. Any Ideas on this would be appreciated.
Shine On -/\=
Keith
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#9
themadchemist
themadchemist
  • Members
  • 2,519 posts
03 - Bosun Hook Arrives
Well as I was preparing Blocks for the bow and stern from balsa, The kit provides Basswood and I wasn't up to that much work trying to shape the harder stuff I threw them To the Side. So I decided to give Al a boss, as he thinks he's in charge and it was going to his head. Figured I wouldn't hurt to practice my carving skills either.
Keith
  • Attached File  1.jpg   71.72KB   5 downloads
  • Attached File  2.jpg   59.39KB   4 downloads
  • Attached File  3.jpg   52.92KB   2 downloads
  • E&T, Marcus Botanicus, Farbror Fartyg and 1 other like this
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#10
themadchemist
themadchemist
  • Members
  • 2,519 posts
04 - Adding Bow and Stern Blocks
To aid in planking, blocks were added to the Bow and stern. The kit came with basswood blocks but these were exchanged for more workable Balsa inserts.This proved to be a good choice, as the balsa took quite a bit of work to shape. They were semi-shaped before placement but I still left much to be shaped away. Again They were glued using PVA glue and held in place with rubber bands. I knew I'd been saving those chunky rubber bands they put on broccoli and asparagus in the produce section of the grocery store for something.
  • Attached File  1.jpg   244.13KB   3 downloads
  • Attached File  2.jpg   110.37KB   3 downloads
  • Attached File  3.jpg   129.4KB   4 downloads
  • Attached File  4.jpg   172.75KB   2 downloads
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#11
hircsailor
hircsailor
  • Members
  • 41 posts
  • LocationWakiki, Hawaii
Welcome aboard themadchemist. I also just brought a AL Swift from ebay and it turns out to be a model from 1983, I learned this from the Model Expo material dated 1983 that was included in the kit. I look forward to following your progress and to pick up on any ideas that you may have. In one sense I am one step ahead of you and two step behind you; My kit came from an estate sale where the orignal owner started to build it and attached the frames and deck to the keel. Only trouble was that they didn't square the frames and keel. I beleive that it is frame #7 where the deck seperates and the frame is about 1/16" off center on one side. When the kit arrived the keel and aft deck behind frame #6 was broken off so I have to repaire that before I can really get started. I also have to let the kit air out as it smells a little musty from being in storage somewhere. While that happens I can finish building the T50 and T37 rc sailboats that I am building right now.
I plan on starting a building log when I get started working on it.
#12
themadchemist
themadchemist
  • Members
  • 2,519 posts
hello hircsailor
I found 1982 on the kit I purchased. Funny the stuff you find in these old preowned kits. Another kit I purchased had an old hobby catalog. Not sure if your kits broken as on the older Swift (I dont know on the newer model) the deck is split at bulkhead 7. The front deck ends on bulkhead 7 and the aft deck sits on the 8th bulkhead and keel ridge, adding the block gives it a nice gluing platform. I'm a bit farther along then the photos, I just ran out of steam last night resizing pictures. At the moment Ive stopped at the planking. I have the garboard strake bent and ready to cut and glue but I'm waffling over just how far forward to extend them as I don't want the strakes crowding the Bow. I figured it would be a good time to catch up the log and be able to ask question in real time.
I also found that the assembled bulkhead required alot of fairing. I had to shim up 4 bulkheads, 2 for the deck and 2 for the hull to get a smooth fit, not to mention adding to the deck even. With the compound curvature of the deck its a bit of a struggle to get it on, I hope to finish getting caught up with the build log today.
Keith
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#13
trippwj
trippwj
    Scullery Maid
  • Members
  • 3,028 posts
  • LocationEastport, Maine, USA
Ahoy, Keith :piratetongueor4: !
It seems you are most assuredly enjoying this hobby!  Nice job so far - looking forward to how your shipyard superintendent and Al manage to cooperate - which, of course, is all relative anyway...
Enjoying both of your logs - nice work!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
#14
themadchemist
themadchemist
  • Members
  • 2,519 posts
Hello Wayne
   Not just enjoying, its the hobby that saved my sanity. Being disabled took its toll on me and having something to focus on to draw my mind from myself has be very healing and liberating. I see each task as a huge accomplishment. Each piece is a model of that piece and that gives me a feeling of accomplishment that I had lost. MSW is the frosting on the cake. It allows me to break from the isolation of being homebound. As an Ex-High School teacher its hard to go from seeing and interacting with 100's of young minds each day, to spending weeks never leaving the house.
As far as Al and Hook, Al has 5 or six inches on Hook but my money is on Hook. He's a salty Old Barnacle. Funny, it all started because I wanted to carve a tricome hat. Wait 'til you met the Captain...
Shine On -/\=
Keith
  • trippwj and ringbolt2013 like this
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#15
themadchemist
themadchemist
  • Members
  • 2,519 posts
5 - Shaping the Bow and Stern Blocks
I got around to shaping the Bow blocks rather quickly but then stalled on the Stern. I now realize this must have been a defense mechanism that us builders develop to justify the need for more Tools. I convinced the Admiral (not a hard feat as she's seen the effects of this hobby on my well being) that I couldn't continue without more toys... er, um... I mean tools.
I found a set of medium sized rasps at Hobby Lobby in the soapstone carving section (I snagged a bit of nicely coloured soapstone also (I need to figure out what to carve in it). These and my 5/8" Dowel with 100 grit sandpaper CA'd to the middle of the staff did the trick. I rasped down close then finished by sanding with the dowel riding on bulkhead 7 with the sandpaper over and passed bulkhead 8. Alot of material had to be removed but it looks good to my eyes. Overall I was quite happy with the job and really glad I switched the Basswood for Balsa.
Attached File  3.jpg   207.63KB   4 downloadsAttached File  4.jpg   210.91KB   3 downloadsAttached File  5.jpg   213.52KB   3 downloadsAttached File  6.jpg   220.79KB   2 downloadsAttached File  7.jpg   75.15KB   2 downloadsAttached File  8.jpg   60.93KB   1 downloadsAttached File  9.jpg   120.54KB   3 downloads
 I've included a few pictures of some of the tools I used during shaping.
Attached File  1.jpg   135.42KB   3 downloadsAttached File  2.jpg   141.47KB   1 downloads
Edited by themadchemist, 06 March 2013 - 08:06 PM.
  • trippwj, canoe21, E&T and 3 others like this
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#16
russ
russ
    Special Contributor
  • SPECIAL CONTRIBUTOR
  • 2,381 posts
  • LocationBiloxi, Mississippi
You can also use emory boards for fine sanding,especially on something like basswood. You can use it on anything thin enough as well.
So far, your hull is looking very good. Nice work.
Russ
#17
themadchemist
themadchemist
  • Members
  • 2,519 posts
06 - Shimming the Bulkheads
Upon checking the bulkheads with a plank I found that the frame was going to require quite a lot of fairing. I spent a day thinking about the best way to approach this. One could sand everything down to the lowest point, but that won't necessarily be correct. My Final decision was that deck side of bulkhead #7 need height added to the larboard side and #5 to the starboard. Using a chunk of planking left over from the peterboro canoe I CA'd the strip, then shaved the width to the thickness of the bulkhead. I then sanded, again using the 5/8" dowel with paper in the middle. I again used the tactic of using the fore and aft bulkheads as my sanding guide.
On the hull side of the bulkheads #6 seems to be low so they were extended in like manner. It seems in sanding that your taking nearly everything off, but I allowed the ajoining bulkheads to decide where the sanding stopped. I also stopped periodically to check alignment with a plank also.
  • Attached File  1.jpg   88.56KB   2 downloads
  • Attached File  2.jpg   130.86KB   1 downloads
  • Attached File  3.jpg   112.88KB   0 downloads
  • Attached File  4.jpg   121.92KB   0 downloads
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#18
themadchemist
themadchemist
  • Members
  • 2,519 posts
Hey Russ
Funny you say that, because I had the Admiral take me to Sally's beauty supply the other day and found several items I could use for building. Hair clips, emory boards and permanent (Al wants to curl his hair, go figure). I think Al's been taken aback by the Bosuns gruff nature.
Keith
  • trippwj likes this
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#19
themadchemist
themadchemist
  • Members
  • 2,519 posts
I knew this would happen. Looks like Hooks teaching ole Al what a Bosun is.
  • Attached File  1.jpg   235.05KB   0 downloads
  • Attached File  2.jpg   240.38KB   0 downloads
Edited by themadchemist, 06 March 2013 - 09:11 PM.
  • trippwj and capnharv2 like this
Shine On -/\=
Keith (tmc)
 — Mahatma Gandhi
#20
trippwj
trippwj
    Scullery Maid
  • Members
  • 3,028 posts
Al could desperately use that perm you got him....
Wayne
Epictetus
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
