RMS Titanic's Lifeboat by shane762 - Artesania Latina - Small - Scale 1:35 Kitbashed
So this is the beginning of my first build log which will cover my third wooden ship (well boat in this case) model.  I’m building the 1:35 Artesania model of the Titanic’s Lifeboat.  I’ll be modifying the kit quite a bit because as Monkeyman discovered in his build of the same kit, Artesania’s model is more “inspired by” than a “model of” the craft in question.  Speaking of Monkeyman’s build:  I already owe him a great deal of thanks as he found and pointed out some of the biggest errors in the kit so before I even opened the kit I was able to start planning some corrections.  A lot of the beginning stage will just be me copying his good work I hope he doesn’t mind.
My desk not having any idea of the devastation about to hit it.
The contents of the box laid out for perusal.
I printed out to scale a side view of the boat on heavy paper.  Here it is to compare with the kit’s internal keel.  They should look pretty similar but don’t.  The kit piece is too long and the wrong shape.
Here are the bow and stern with extra material added and excess material marked to be cut away.
Here is the bow cut to shape.
Two of the frames clamped and glued in place.  I’m using legos to make sure they stay good and square.
The next night was a two steps forward one step back sort of thing.  Once I removed the blocks and clamps I realized that I had set one of the frames catawampus.    Once I fixed that I set two more frames and now I'm calling it a night.
Edited by shane762
Link to comment
Share on other sites
So after tinkering on the boat through the week I've managed to assemble and reinforce the frame.  Even using Legos I still managed to glue up a couple of the frames cockeyed but some alcohol and patience and they were fixed.  Now I've started fairing the frames.  It's proving to be a bit trickier than fairing the frames on my last build, the Caldercraft badger.  I think that I needed to redesign the bow and stern frames a bit more before I glued them up.  Still, they're coming along.
I want to get everything pretty well faired before I add the keel and stem and stern posts. .  Once I'm just too likely to break them off half a dozen times if I don't wait.  It does make it harder to visualize  how all the planks are going to come together without it though.
I've largely decide to mark the boat as number 14.  I've always found fascinating the story of Officer Lowe and his return to look for survivors.  Of course the only difference between it and any of the other boats will be the very small numeral 14 on the bow and the stern.
I am thinking of recreating a small area of deck and just the edge of the Titanic's hull to serve as the display stand.  I had also considered scratchbuilding the davits but I decided I didn't want to go quite that far.
Edited by shane762
Link to comment
So the frame is fare.  Or at least a lot more faired than when I started.  I'm a little nervous that I don't have the contour of the stem and stern quite right but I'm pretty sure I can work with it.  I've also cut the keel pieces but as I said before I think I'll leave them off until the planking is finished.   The next thing to do is to start fitting the garboard strake.  It's certainly a more straightforward fit than on a larger vessel but the wood strip the kit came with is thick.  1.5 mm thick.  If I was so cheap/broke I'd pony up and buy some new wood but I'm going to see how I can make out with these.
Looks a bit like a fish skeleton
Edited by shane762
Link to comment
So after even more reshaping of the bow and stern the first plank has been soaked and clamped in place.  It's funny how actually placing the and fitting the plank made the poor or wrongly faired areas so obvious and so much easier to correct.
Since there's so much going on with the garboard strake I'm only fitting one end at a time.  Tomorrow night I'll start fitting the other bow portion.  I have a feeling that it's going to be a very slow planking process.  At least I should have plenty of time to make the oars and figure how to improve those really awful life preservers.
Link to comment
So after getting little or nothing done lately thanks to changing jobs I've finally made some progress.    I finished and attached both garboard strakes.  Once the glue set and I can remove the 753 clamps I can do the final smoothing on the planks.  I am begining to think that I may regret decifding to use the kit planks though.  They're really thick.
I left the plank just slightly long so I can finish the edges all at once.
Link to comment
The new job has been keeping me busy but I've finally gotten some work done.  Veeeerryyy  slowing working the planking.  It's my first ever clinker build so I'm not unhappy with it but I definitely see where I could have started it out better.  Still, it's getting there.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
