Tips on cutting small pieces?
Light pressure. Many passes. Slice the wood by drawing the knife across the fibers, don't press the knife against the wood with a lot of force; cut, don't crush. And keep your blades sharp - every several slices, draw the blade over a fine stone to restore the edge. I've found a self healing cutting mat helps too.
Good luck!
Currently building: Model Expo AMERICA, A/L KING OF THE MISSISSIPPI
Completed: Mamoli Victory cross-section, Revell LSM (Plastic, in memory of Dad), A/L SANSON tug, MS Longboat (awesome model Chuck!), Dumas 1949 Chris-Craft 19' Racing runabout, A/L SWIFT, MS ELSIE, Constructo ELIDIR (now LOUISE), Midwest Muscongus Bay Lobster Smack, Amati 1:80 Yacht ENDEAVOUR, Mamoli CONSTITUTION cross section, Revell VIIc U-boat (1:72 plastic), lotsa other plastic ships
Next up: who knows - there are too many to choose from!
Link to comment
Share on other sites
Sharp blades and a cutting mat work well. But, balsa is a very soft wood; really only useful as filler for a hull, between the bulkheads. Trying to shape items, like deck furniture, is difficult because the wood is so soft. The edges don't hold up if much pressure is applied, so fine detail is hard to achieve. You may want to try some basswood. It's still soft, but it doesn't have the issues of balsa.
Ken
Started: MS Bounty Longboat,
Link to comment
What might help also, is to put the balsa on a slab of basswood with some PVA.  cut what needs to be cut and the drop it in an alcohol bath.  Once the glue dissolves, let it dry and you can use it.
Link to comment
I find it interesting that a soft wood like balsa is harder to cut accurately and uniformly than a hardwood like pear or boxwood.
The problem with balsa is that the fibers are large (even though they are spaced apart to give it the low density). To cut balsa across those fibers is easier than cutting them at an angle or slightly off center.
Likewise balsa does not sand nice and smooth like a hardwood.
It should be kept for fillers as Mark suggests or for really lightweight places like model airplane frames.
I might add that cutting balsa with an Exacto knife is not as good as using a razor saw. Again it is a matter of cutting those fibers and a saw does a better job than a knife.
Edited by Modeler12
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Link to comment
Crackers,
Yes.   That would work.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
