Foredom rotary tools.....how good are they?
I am considering buying a used Foredom tool primarily for carving, but have never used one (I have been using a 35 year old Dremel tool that is on its last legs). Before I spend the money I'm hoping to get some sage advice from some of the members. Some questions I have.........
Are they as good as everybody says they are?
Do they have a lot of vibration in the tool, similar to the Dremels, or are they truly smooth?
Are they pretty much maintenance free?
Which model do you prefer, and why (again, especially for woodcarving)?
Are they disturbingly noisy?
I could not find a lot of info on the internet about these tools, nor could I find a lot on this site.  Hoping that this request for input can result in an interesting topic.  Thanks in advance for any thoughts you have to offer.
Jim
Link to comment
Share on other sites
Jim:
I have had one for 15 years or so.  Very smooth.  10X better than anything Dremel makes.  Not noisy.
Occasional lubricating of the flex shaft drive is needed but it's real easy - lube is in a tube - disconnect from the tool, drop some lube into the flex shaft housing reattach.  I have the cc model with the std hand piece.  Very happy with it.  I don't use it for carving any more as I now have a dental machine for carving but the Foredom is a fine tool.  It will go very slow and I have done a lot of trimming with sanding drums of fiberglass and styrene w/o melting the styrene.  It can also spin like crazy to hog out wood.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Link to comment
Foredom is built for tough job, many heads are available.
But I prefer an electric pen, more delicate for small job.
The main advantage: no shaft to reduce the flexibility of use
and for this reason I do not use anymore the Foredom which in addition is like using a bulldozer when a smaller tractor could be more than enough.
Link to comment
Guest Tim I.
I love mine. I dropped my Dremel a year ago in favor of my Foredom. I use the foot pedal, to vary the speed -- it comes in handy.
Bottom line, well worth the money.
- Tim I.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
