Dirty Dozen Abalone Fishing Boat by xken - Finished
With Kurt's encouragement I am stepping into the Darkside of scratch building a boat and I might add much sooner than I thought. This build will run in tandem with my Constitution build.
This build is a commission for the local Maritime Museum here in Morro Bay in which the building is in the process of starting to build with a targeted completion date of October to correspond with the Boat Festival.
They have requested a 1 inch to the foot scale model with an overall size of 32" long.
My first step was to laminate together 1/16" thick x 3" Basswood sheets to the plan size of the deck. The real boat was a local marine grade plywood build with a Cummings diesel engine. I did enough of the CAD drawings to get off to a good start and I use the CAD prints as patterns to cut out parts as seen in some of the following build pictures.
I am not new to scratch building models and the interesting thing is that there are no instructions and plans unless you obtain them or draw them. I use CorelCAD to make the basic rough drawings and then print out what I need as I progress and often refer back to the CAD files as I build for dimensions. One thing about scratch building is that it is much like playing chess and one has to be two or three steps ahead so as not to build yourself into a bad situation. The other thing that happens is off hand building in space and building in structure as you go.
Here are images of the build start on Saturday beginning with the sheet glue up and building in structure with rails and flanges to strengthen the deck sheet.
To establish the deck curve I built up the transom and will progress building from the stern.
The transom flange was cut to 87 degrees relative to the deck. The beauty of having the CAD file is exact degrees when measured in the computer file.
Here the rails and flanges were added for strength and hull set back indexing edges with the flanges.
Next I moved onto bulkhead #8 which is angled and forms the rear wall of the cabin. I also pre cut the hatch door and taped it back in place to maintain part geometry. The horizontal supports for the working deck has been added to #8 as well as the inside of the transom aligning with the supper holes.
Next I made a 105 degree jig for the bulk head this will be used to develop the geometry for the false interior that will be blacked out. I will attempt to have a work hatch door with sliding access panel.
Next I plan to move to the forward cabin for additional structure and strength  before moving to the hull.
Ken
Current build: Maersk Detroit"
Future builds:  Mamoli HMS Victory 1:90
Completed builds: US Brig Niagara, Dirty Dozen, USS Constitution, 18th Century Armed Longboat
https://modelshipworld.com/index.php?/topic/11935-uss-constitution-by-xken-model-shipways-scale-1768/
Link to comment
Share on other sites
I have enjoyed Moro Bay many times, so I'll stick around to watch you build your abalone fishing boat.
I had hoped to build the fishing boat "Wind Walker" at one time and took many pictures which have since been lost.  Is she still there?
Bob
Current build:  SS_ Mariefred
Link to comment
Bob , next time I am down there I will check to see for you. We get many fishing boats that visit here from up north. Is she a local boat?
Ken
Link to comment
I added a deck brace to develop the curve from the forward edge of the cabin area to the bow.
Next I build up the cabin sides with window flanges to provide gluing surface for the windows. I also added a center piece to provide a clamping surface while working on the hull. The cabin roof will go on once the hull work is done.
Here is a picture showing the hatch door open
This shows the window flanges using .020" strip stock.
Here I added the center board of the forward section of the hull with edges pre-carved with slight angles. Again I used the prints for patterns. When gluing the prints to the wood I use 3M 77 spray glue with a light tack coat to lightly stick to the wood. To remove the print I just wipe with a coat of lacquer thinner and then clean off the glue residue with more thinner.
Next I will move to the rear working deck area and add the center board there.
Ken
Link to comment
Link to comment
Thanks Ken.  I don't know if the Windwalker was local.  She looked like a 50 foot clipper bowed sloop that had been converted to a motorized fishing boat.  She was all white and docked on a long pier at the north end of town.
Bob
Link to comment
Bob, she is not there now, but could be out somewhere, I will keep checking time to time.
Tom, it only appears fast but that is the advantage of drawing the plans in CAD because as you are drawing you are building it in your mind as well. I get my prints 34" x 22" D size for a $1.75 a print; sure beats tracing and I use the prints as patterns. I just have to keep in mind angled surfaces and wall stock cut for joints when cutting the wood.
I added the return flanges for the working deck area to the underside of the deck. These needed the ends soaked in water to form the curved corners adjacent to the rear cabin wall. While soaking I added the curved brace to the rear edge by tracing the deck curve and then cutting to the correct center height.
Then I added the center board from bulkhead #8 to the transom. Added stiffeners to keep the centerboard straight and provide a gluing surface for the compartments. I also glue up the working deck surface edge gluing 4 pieces to the needed sizes and while waiting for them to set I formed the working deck side perimeters by edge forming them dry since they are slight curves.
I then added the prop shaft access area box with the top edge trimmed to the working deck height. These compartment are easier to add now and will provide structure as well as gluing edges for the working deck.
While waiting for glue to dry I then added the cabin front wall which was the trickiest part so far with straight gluing surfaces at the edges but curves top and bottom and it took me 2 attempts to get a tight fit at the fore deck. I dry formed it by slowly and carefully bending diagonally from the lower side corner to the upper center to develop the curve. The part was slightly over sized side to side so once glued in place the edges were trimmed to match with a sharp blade.
I also had to go buy a second bulk pack of Basswood sheets. Just a tip; if you have an Ace Hardware in you area I buy a 15 sheet bulk pack much more cost effectively than other wood outlets.
Now to build the engine compartment before adding the work deck surface. This will help define the need bulk heads for the hull.
Ken
Link to comment
Looking great Ken! Count me in!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
I moved on to the engine compartment and built up the basic box with with the top edges shaped to match the work deck. I located and glued it into position align on the center line and used strips clamped to the side to match the deck surfaces.
Here is the working deck glued in place with the compartment locations penciled in for reference when it comes time to cut them out. I will leave the deck solid until the hull is completed for extra strength and reduced flexing.
Once the deck glue was set I added the two compartments adjacent to the engine compartment. I am not sure what they were for but could have been battery and air compressor for the diver. Here they are in place. I also reinforced all key joints that will help when deck surface is cut away. I also added the intermediate bulkhead to develop the hull curve from the transom to bulkhead #8.
I cut clamp holes in bulkhead #8 to assure a good tight joint when glued.
Next I cut the bottom surfaces of the hull using a side piece to develop the tight edge joint. I will glue the bottom surface on first so that the side surface will be smooth and joint free when viewed.
Next I am moving to the forward portion of the hull and using a 3/13 x 1/16" strip to define the hull sweep using the bow reference mark, bulkhead #8 and the reference dimension from the CAD drawing and clamping the strip to the ruler mark. From here I will develop the froward bulkheads. I am also pondering the notion of a solid carved nose section; but will decide that once the bulkheads are in place.
Back to the front bulkheads.
Ken
Link to comment
As I worked back and forth on the forward bulkheads I decided to add the aft hull planking using 1/16" x 3" Basswood sheet. I cut two identical pieces but mirror imaged for port and starboard sides. Here they are glued in place and note the advantage of using the clamp holes cut into the bulkhead to hold the concave curve of the hull.
Here is an "in progress" of developing the forward bulkheads making both left and rights and reinforcing them with 1/8" square strip stock which will also add a good gluing surface as well. I have decided at this point to add a solid nose at the bow to define the junction point of the wale joint of the hull. Later a wood strip will be added at this joint line.
While waiting for the bulkheads glue to set I decided to test fit the hull sidewall to check my joint fit between the work deck and sidewall. I was very glad of the results. My friend Mr. Geometry came through for me again!  :dancetl6:
Now back to the forward bulkheads and the center boards for the aft hull bottom.
Ken
Link to comment
Patrick, yes I like being good friends with Mr. Geometry, he has saved my butt more than once.
I had a good productive day yesterday and made good progress on the hull. I have added notes in the pictures that should explain what is happening. I have discovered that the hull planking will require some strip planks because of the 3" width of the sheets I have.
Now back to the forward hull.
Ken
Link to comment
I fell back on my vintage CAD system to develop the planking for the forward hull using Cardstock Aided Design. Time spent to cut carefully with multiple pieces as needed and this one pattern can be used for both sides. Here you can see the pattern taped in place. The 3" width of the Basswood sheets I have will require using two parts. Once the first wood part is cut the top straight line is traced on the CAD pattern for the second piece.
The wood pattern was cut and trimmed with a small plane to angle cut the curved lower edge and forward bow portion. The bow end was set in hot water to soak and formed into place with edges being trimmed as needed for a tight fit and the piece allowed to dry enough to glue in place. Holes were drilled in the centerboard to insert a dowel to hold a rubber band with a braces to keep the bow edge in place. yellow glue was applied to all edges and gluing surfaces.
Here is the other side being glued in place with forward rubber band clamping and tape to hold edges tight. Spring clamps were positioned to hold the top edges just snug to the bulkheads. Some finger pressing was needed to adjust the lower edges until the yellow glue tacked off due to slight stretching of the tape.
Here the top filler parts were cut using the CAD pattern; curved edge trimmed with plane and soaked in hot water to form. Here you can see the chamfered edge while the lower mating edge is the finished straight edge. Tape and tacking with CA were used to hold in place while yellow glue set. Note that gluing tabs were added to the upper edge of the lower hull part.
Here are the lower hull sections in place and ready for finish sanding once the upper parts are installed.
Here I am back with the CAD system developing the pattern for the upper hull. Note that a second 3/16" strip was added to make up the difference for the 3" sheet width.
Here it is starting to look like a boat. The lines reminded me of it looking like a small P.T. boat.
Ken
Link to comment
Steve, Brian thank you for your kind words. Brian I will be fine tuning the plans once complete and I know that the museum plans to sell some form of them as a fund raiser for the museum. The full size plans are CAD size D 34" x 22". As for the price of the plans I have no idea at this point. In fact you may be able to help the museum...what would you be willing to pay for a set of plans?
Finished closing up the hull last evening after soaking and hand forming and trimming the edges for a tight fit. I knew going in that hot water would expand the wood a bit especially at this size and that it would vary based upon the individual sheet of wood. Both sheets had tight fits when wet and a 3/64" gap developed at the bow once completely dry. Not a big problem, just cut a wedge sliver and filled the gap. There will be a false keel and rub rails to be added down the road.
For now the hull will be allowed to set and I will move on the the upper deck structures and once all the structures are complete I can get back to glazing putty and finish sanding the hull.
This shows the cut side taped in place and drying.
Here are a couple of overall views.
Now back to the upper deck and I located the holes for the two forward cabin wall port hole windows.
I will add the eyebrow for more structure before cutting out the windows.
Ken
Link to comment
Ken, love the "CAD" work! Been following along and really like your explanations of work performed, with annotated drawings.
Ken
Started: MS Bounty Longboat,
Link to comment
Ken, thank you! I had a Deja-Vu moment when working with the card stock back to about thirty years ago BC (before computers) I used these techniques while building RC airplanes for my son. The system still works well for me. I know if I built a 3D computer model in a program like SolidWorks I probably could print out a lay flat pattern; but with my computer skills I probably would still be at the computer building the 3D model.
Yesterday I added the anchor guide mounting brace which on the real boat had concave curves blending into the deck rails.
I finished up the cabin area by gluing pieces together for the roof. I also added a center lateral cross brace to defining the roof line and providing an additional glue surface for the roof since more structure will be added on top of the roof. Once all the fussing and blending was done I then painted the inside cabin surfaces black. This way rather than paint window surfaces black I can add more depth with clear windows. Painting these is much easier to do before the roof is glued in place.
While waiting for paint to dry I cut out the large engine compartment and added the raised edges that prevented the water from flowing into the engine compartment. I am sure that there is a name for them. But I added then for increased strength before cutting out the smaller compartments. I also cut the round port hole window in the front cabin wall.
Lastly, I added the wet roof to dry over night to the cabin to set the crown in it.
Ken
Link to comment
Ken:
I like the way you are proceeding - using the old CAD method to back up the newer CAD drawings. :)
The word you are looking for referring to the raised bulkheads around the engine compartment is "coaming".
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Link to comment
Kurt, thanks I knew they must have had a name. I will be adding more to the other access panels as well.
Ken
Link to comment
I added the cabin roof once dry and set then moved onto the bridge structure which required some edge mating to have both a clean exterior and interior. The challenge was matching the curves and bends.
While waiting for glue to set on the bridge walls, I added inside curves to the work deck corners. I also spent time studying photographs and realized that I needed to narrow the hatchway door opening for the sliding door to work and that the two side access panels were too long and wide and reworked them as needed.
Here is an inside view of the bridge work showing the inside clearance area at the top for the dashboard with gauges to come.
Next to add the coaming, seats and compartment covers.
Ken
Link to comment
I decided to add the seat blocks as separate parts that can be removed to facilitate painting in the bridge area. After building them up I added indexing blocks on the deck for their locations once painting is completed. The starboard seat structure is also the battery box, hence the vent holes. I will add the 2" thick seat cushions later on down the road.
I then reinforced the top horizontal surface of the bridge for the dashboard to align with. Notches were cut in the side wall braces to allow fitting of the dashboard against the side walls. The dash is indexed in and press fits into place. I located the centers of all the instruments and then clear coated the mahogany dash. I will turn the instrument bezels later using aluminum.
I then cut the edges of 1/8" wood stock to form the tracks for the sliding hatch door. Originally I thought this hinged, but after studying the photos I realized I was wrong and that it was a sliding door. Once finished up the top and bottom rails were glued in place while the vertical stop is pinned to be removed for door to be put in place. I added the handle just for testing and can be removed to paint the door.
Next I worked back and forth adding coaming and covers for the access panels and built up the framing for the the engine compartment that is hinged on the port side. Both the front and rear are open for air flow. The bracing was needed to carry the weight of people walking on them. All the work deck surfaces were coated with a non skid material/paint.
Next I will finish up the top hinged sliding door for the hatch that indexes with the sliding door. The slide rails are mahogany. I will need to find a source for small piano hinge for the hatch door. I assume that the first section lifts up and the second section slides back to open while maintaining a water resistant seal. Here is a picture of it showing the piano hinge.
Merry Christmas to all!
Ken
Link to comment
Built up the top hatch cover which is two parts hinged together; the forward part has the sliding rails indexed into tracks on the cabin top and the aft part lifts up and both slide back in the mahogany tracks.
I then moved on to cutting the gauge bezels out of aluminum. The tachometer is 7/16" diameter, the Total hours 5/16" diameter with the rest of the gauges 1/8" diameter. All were polished with metal polish on a Q-tip and buffed with a rag before being cut down ot the parent locating pin.
Here they are in place on the dashboard.
I then worked on the forward deck items that are all mahogany. More to be added like the chain box lid and hawse.
Here is an overall view with the engine hatch open.
Yesterday I had a meeting with the president of the Maritime Museum and we went to the boat yard photographed and measured the rudder. Now I can draw it up and add to the plans.
Now back to work.
Ken
Link to comment
I got back to working with brass and made the porthole windows and Danford anchor and turned the hawse rope holder. I decided since this is a display model that there was no need to make these working porthole windows which on the real boat opened inward. Here is a sequence explaining the porthole building process starting with 1/32" sheet.
The shoulder rim will support the glass window.
Here is the articulating anchor. The copper chain started with round links which I carefully squeezed with needle nose pliers into elongated oval links to look more realistic.
Next I will move onto the ladder and it's support brackets.
Ken
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
