AL's CNC Wood Milling Machine
Hi folks.... my name is AL, and I'm a CNC wood milling machine enthusiast. I've been asked by a few members here to show my CNC wood milling machine and share some insight into the world of CNC'ing and what you need to know to possibly build your own.  There are many web sites devoted to CNC machines, in fact there are many sites showing how to build a CNC wood cutting machine, I've been there.... done that, and now over 14 years later I'm designing and building my own machines from scratch. I do not know everything about them, just enough to make it work for me. I firmly believe in DIY, and knowing how to build your own machine will help you keep it running and improve it over time. Just like building model ships, the more you build them the better at it you become, the more you learn!! Now if your really interested I have a PDF file made by Richard Wildey who can explain whats its all about a lot better then I can!!
Getting Started in CNC.pdf
That being said..... I'll next be posting pictures of my machine, if you have any questions, jump in and ask!
AL
H.M.S. Triton, 28 gun frigate (Cross Section) 1:18 Scale build in progress
Link to comment
Share on other sites
WOW Al!! That looks at fantastic piece of kit.My imagine is already running away with me thinking of all the jobs I could do with something like that :D  :D  :D Do you use it just for sheet material,or have you had a go at more complex 3D shapes?
Kind Regards
Nigel
Currently working on Royal Caroline
Link to comment
Machine stats:
Cutting Area: 48" x 48"
Router used: Hitachi M12VC Variable Speed 2.25 HP, 8,000 RPM to 24,000 RPM
Cutting Speed:  80 Inches Per Min. (IPM) Max.
Stepper Motor Size: Nema 23, 425 oz., 8 wire
Drive Screws:  ACME 1/2" diameter 8 thread 2 start which means 4 TPI (Threads Per Inch).
Electronics: HobbyCNC Pro 4 axis Driver board.....   http://www.hobbycnc.com/products/hobbycnc-pro-chopper-driver-board-kits/
and  Gecko G251 4th axis driver card, CNC4PC C1 & C10, AnTek 30VDC 20A power supply.
All Alum construction, NO MDF or WOOD used other then table top.
AL
Link to comment
THANKS for starting this. I think that my last post under your Triton Cross section thread might have had something to do with it.
THANKS..
Going to reviewing this a lot when I get home from work. I've been at the edge of this for a while and if I get some money up again then I think that I might know where I'm going to be spending a few dollars of it.
Thanks Again.
Later Tim
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Link to comment
Al from UA
If you used very light cuts, slow passes could you use your setup for Aluminum? Or steel?? Brass??
Thanks
Later Tim
Link to comment
Ok, more questions.
You used """Stepper Motor Size: Nema 23, 425 oz., 8 wire""" on all four of your axis or ??
Can you please post pics of your 4th axis and another of your cannon making. Thanks
Thanks Tim
Link to comment
Yes.... Its the same size stepper 425 oz. on all 3 axis, the 4th axis is a ready made gear box (18:1 gearing) with its own stepper motor 125 oz. and seems very capable for what it does. But a 425 oz. could be used with no problems on the 4th axis provided it was set up with its own reduction system.
Yes, it will cut alum with light passes .020" deep and slow speeds 10 IPM and the router set on lowest speed! I've made quite a few alum parts with it. I'm sure it would cut brass with no problem.
For just the parts for a machine like this figure a starting cost of approx. $2000.00, The software (Aspire, Mach3, 3D CAD) alone cost me more then my machine.....LOL But thats spent over a period of time, not all at once. But do you really need a big machine or will a smaller one do?
The 4th axis set up.
The 3-jaw chuck is off my HF 7x10 mini lathe, with a homemade backplate of alum. The gear box with stepper motor was from MPJA surplus, its no longer available from them.
AL
Link to comment
Al
You listed the X-Y as 48x48 what is you vertical Z axis travel?
Also is the 4th axis sitting at the edge of the X-Y table or ?? In your by hand 5th axis of course. I guess that I'm almost asking for a stepped back overall view of everything.
Thanks
Later Tim
Link to comment
Thank you for the video Al,that is seriously impressive!You possess some serious talent building a machine like this from scratch!I really would know where to start on the software side of things myself :rolleyes:
Kind Regards
Nigel
Link to comment
I have about 6" of Z axis clearance at the table top thickness I'm running now.  I can push lower thru the table top by a 1.5" inches, so total travel is 7.5". Thats a set thing due to the bearing slides I'm using and how I have the trucks set up on the backplate that holds the router.
The 4th axis is inside the 48" x 48"  , probably eats up about 10.5" x 48" inches of real estate for it to have clearance. The keyboard is in that same area due to no space in the room, kind of tight in there!!... LOL The room is approx. 11' x 11'.
AL
Link to comment
Nigel ......I've worked in machine shops, and a metal fabrication plant working with alum & stainless steel for many years and kind of picked up a talent for this hobby.... LOL Plus I'm a hobby machinist, with electronics knowledge, jack of all trades, master of none of them..... LOL  Also having a HF mini-mill & HF mini-lathe sure helps to make parts for the Cnc wood mill. The software took me awhile to feel comfortable with and I still don't know everything that it can do, you only learn what you need to do the job..... LOL  And like most computer software, easily forgotten if not used often!!
AL
Link to comment
One thing I must stress to anyone thinking of building a Cnc wood milling machine is they need to know how to use at the minimum a 2D CAD program!!! Like any tool, to get any use out of it at all, you're going to need drawings to turn into gcode for the Cnc machine to cut. The gcode software needs DXF files which a 2D CAD program generates, and as with most things, your on your own when it comes to DXF files so without any 2D CAD knowledge to make your own drawings your dead in the water!!  I've built 3 cnc machines and did it all with a cheap 2D CAD program, you don't need 3D CAD, Solid Works or any of those expensive programs to do it. Every part on my cnc machines started out as a drawing in 2D CAD before the metal ever got cut, like the old draftsman said ...... if you can draw it , you can build it!!! ;)
AL
Link to comment
And look at that nice new table saw. It got there. I remember you stating in a post that one was on the way. Well Enjoy it. Wish I had one.
Thanks for that info and pictures of everything.
Later Tim
Link to comment
An interesting bit of Kit, for sure.
Michael
Link to comment
Tim..... YES!!! Jims fantastic little table saw got here!!! Its one serious table saw and very well made, I love it!!! :)
http://modelshipworld.com/index.php?/topic/6464-model-machines-4-table-saw/
Michael......Thanks!! Its only limited by the imagination!! ;)
AL
Edited by dewalt57
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
