Cutty Sark by townpiper - FINISHED - Constructo - 1/90
Ahoy Mates
Here we go:
1. This is an old Constructo kit-pre -laser cutting, so everything was done with a router, so I had to be real careful cutting the bulkheads. The decks,  false keel etc. are in 3ply -used an exacto #11 to cut them.
2. The bulkheads didn't fit the false keel.. had to widen the keel . They extended way below the base of the keel so I had to raise the keel by putting blocks on top to insure the bulkheads were level with the keel , and ended above the base to allow sufficient room to cut the rabbet. (Shown in the pix) . The rabbet was a PIA to cut as the false keel was only 3/16 wide. I could only leave a 1/16 ridge. I thO ink if I had to do this again, I'd add to the BOTTOM of the keel to even things out and get a good level top. Maybe  a dado cut before adding the strips would have taken care of the rabbet. I installed the real keel and a cap that Constructo likes to use. Rabbet was cut on the stem , but I haven't installed it yet. Had to add strips where the bulkheads weren't symmetrical. Used balsa for filler blocks fore and aft- to much of a hassle fooling with small bulkheads and then trying to bend planks to fit ( See pix---Had to adjust these to leave an edge to receive the first planking.(used some filler-white was all I had.. it doesn't have to be pretty at this stage , it just has to work ...Oh yeah... raising the false keel with blocks on top made it necessary to raise the fore and after decks as well. Did it with balsa.
3. The deck planking in the kit was way out of scale: on the original ship ( per builders specs from Longridge's books {recommended- but not as detailed as the Mc Kay Anatomy of the Ship series}were 5x3 inches, so in the scale of 1/90 their planks would have been 18 in or so. Had to buy 2mm strips which is the closest I could get from the local shop.
The deck planking went on pretty well. caulking was done w w a wide sharpie with the strips held vertically  in small clamps.
I used a cut down straight exacto blade ( cut to 2mm) run through a black eyebrow pencil to mark the butt ends.
Scraped the decks with a razor blade in a holder.. Put on  a coat of varnish and steel wooled (OOOO)it when it was dry.Have a new coat of varnish drying now, and after another steel wool rub, I'll mark the treenails with a needle dipped in eyebrow pencil. (I did my last ship my simply marking with a lead pencil...looks OK  but I think this is better.
Next up: first planking.
This is my first build log, so I hope it helps somebody.
Fair winds to ya
Link to comment
Share on other sites
I'll be glad to follow!!!!
Nenad
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Also, had a bent false keel-straightened it by lengthening one of the support blocks around bulkhead #4 on the concave side of the bend (port side). . Still have to add some strips to bulkheads that do not meet the rabbet. The bow filler block will be shaped better after 1st Planking.
My other Constructo build was the Bounty 1/50 . It was laser cut  and a whole lot easier .
The plans on both kits were a bit fanciful in some places , so if the accuracy bug bites, references from the actual ship are needed. Of course, sites like this one are invaluable.
BTW Constructo is very good to deal with... they'll send you updated plans etc . Good folks!
Fair winds to ya
Link to comment
Carefull with stern surface angles
In progress:
Content of log :
Past build:
Link to comment
I'd say you are more experienced builder than me, and I doubt I can help you pointing on issues you already do not know know, in this most important stage of building ( I realized that too late)
Just to share one point which can be helpfull
Considering questionable accuracy of plans I used to pull out ribs as basic hull structure, with a little "help" of my inexperience and luck of patience in this early stage, I was faced to big differences between this I have got toward lines and look She has in Campbell's plans and lines I saw on photos. Only way out of this sotuation was - start ovet, or try something ... I was forced to redo some points by deep surgery, and for another - something I call "artistic approach" - just believe in your feeling and sense - from time to time during sanding and applying putty, stop, and look at Her often from distance from different angles of view with question - Hmm, does She LOOK as She has to look. If not, what is and where is luck or less of material. In my situation, this approach helps me a lot to make quite proper hull lines which "seems like", as solid base for second plank layer and coopering. When you latter add hull rails, rudder and stern and bow decorations and another details, eventual mistakes on hull lines are just not visible for 99% people. When you look at her from distance and from outside
If you are interested and have enough patience and time, in my log you can see many negative examples how mistakes with lines reflects later as source of large amount of another problems ( almost nothing of structural elements is on place it has to be)
Even you have correct hull lines, this approach can be helpfull for final look
Nenad
Edited by Nenad M
In progress:
Content of log :
Past build:
Link to comment
Part Deux  - First planking
Went well I think.  Soaked the strips for the day overnite in a clear plastic tube filled with alcohol...they came out quite flexible and assumed the natural bend of the tube , minimizing the need for steam iron bending. Attached with carpenters glue and temporary nailing, except for atealers which did not end on bulkheads-used cyano there.
While I had access to the internal hull, I attached shaped blocks to the bottom at bulkheads 4 and 7--to allow for use of screws for attaching to pedestals when it's finished.
With the  dynamic shape of a clipper, I probably could have foregone the bow filler blocks.. a habit, I guess. But it works.
Now to reshape the stern (Thanks Nenad) block, use filler as caulking all over the hull, and  final sand/shape before installing the secondary planking. Had to purchase sapele strips from.http://tallshipbuilder.com . Good selection of exotic woods.
The pix are not in ant particular order.
Any suggestions will be appreciated.
Thanks and fair winds
Link to comment
It seems to go in right direction. She starts to show Her beautifull lines
In progress:
Content of log :
Past build:
Link to comment
Ok here we go
Secondary planking completed using 1mm x4mm sapele planks. To do it again, I'd use .5mm planks, but the 1mm were cheaper and gave a greater sanding leeway. Somewhat harder to bend though.
Bulwarks installed and planked.
Although I had reshaped the stern prior to planking, it was only after the bulwarks were on that the stern angle was incorrect. So major surgery was indicated. Got out the rasp and hacked away until the shape was right. This left a good sized gap in the stern planking . I cut a.5mm edge all around and placed .5mm planks in the gap, keeping the sweep of the original planking. After some filler , sanding and steel wool, the gap is hardly noticeable( you have to really look for it).
So with that completed, i stained the hull with MInwax red oak which left a great shading of the sapele. Filler, Sanding,Stain, Steelo wool repeated several times provide a pretty good finish. I hand waxed it with a good quality carnauba wax instead of varnish. So it has a not so shiny but rich looking finish.
Next dilemma was whether or not to copper the bottom. Nenad M sent a diagram(thanks much, brother) and  used a balsa mock up of the fore end for practice.  Turns out I really like the waxed wood finish, so no coppering. I'll wait until I tackle the Constitution (on the shelf) for that.
Put on the rudder and stern post. Again - filler ,sanding, stain, more sanding and steel wool.
I used .5mm sapele strips ( to plank the interior of the bulwarks , cut the clearing ports and stained with Minwax white oak.
That's it for now , mates.
Next is to put on the main rails stanchions wales etc.
Fair winds to ya
Link to comment
Nice and smoth. And sweet too. Do you plan longitudinal moldings on hull?
Edited by Nenad
In progress:
Content of log :
Past build:
Link to comment
After a literal computer crash (from table to floor-@#$%$ wires)my old machine wouldn't work. Had to buy a new one and have somebody smarter than me retrieve the old data and set the new machine up. Had to learn Win 8 as well.
So from last post , I got the bright(?) idea to stain the inner bulwark planking ( Constructo left this out) with white oak stain. It looked terrible, so I tried painting it white..Even worse. So I ripped off the inner planking and stained the bulwarks. as with the rest of the hull. I put basswood strip frames around the drainports-gives it a good contrast and approximates the internal framing on the ship.
Used basswood for the wales, and because I really like the wood look, I marked the waterline with 1/16 auto pinstriping tape in.accordance with photos of the real Sark, Hand waxed the hull rather than varnish....
Built and planked the heads, as well as the structure between the main and aft decks (no idea what it is--probably some hatch with horizontal doors IF the plans can be trusted (?) Next, the pinrails which lean on the heads fore and the aft deck.
I used wood strips for bulkhead stanchions, though the real ship had iron rods to which were welded rings and hooks. For my meager skill level, the scale was just too small for me to accurately reproduce these. Wood looks good anyhow.
Next is to strop the main deck deadheads. Probably use 24 ga wire and extend it thru the pinrail, attaching it to the hull for support. (Constructo didn't think of this)..
I'll try to attach some pix but with a new machine it may take several tries.
Thanks mates for your kind and helpful comments.
Fair winds to ya....
Link to comment
My dream is to build all wooden look model, but think I do not have enough skill.
I like look of your Cutty. And don't see any sanding needed
Edited by Nenad
In progress:
Content of log :
Past build:
Link to comment
  • 2 months later...
Ok  here we go again.
 Attached bulwark stanchions and metal supports. The real shi p had steel bars angling down from the  pinrails and attached to the bulwarks. I tried to get that, but couldn't get the proper angle d/t scale so I used vertical bars. The pin rails need some support in reality. Stropped and installed the deadeyes. Installed the catheads and whiskers- the real ship had 3 cleats evenly spaced on the whiskers, so I soldered 3 rings on each, and then cut the rings down leaving a small ersatz cleat.  The Stem and top rail was reshaped to accept the bowsprit at the proper angle; slot cut for gammoning( the kit left that out, but the real ship had chain gammoning abt 6 turns nailed to the stem. Shaped the bowsprit for fit (left it on for the pic) fashioned knightheads and installed them adjacent to bowsprit for lateral support (the kit forgot this as well) Put in the portholes. Installed the bow pin rail, but I think I'll take it off and make another one to fit the external edge of the toprail.
Constructo is really good at getting you updated plans if any. My kit was an earlier one 1/93 vs 1/90,  they sent me a very helpful download of their current plans with photos etc, Bueno!!!!
Here's some pics.
Next up: deck buildings, windlass etc.
Thanks for all your helpful and encouraging comments,
Fair winds, mates
Link to comment
Very nice work. Keep on !!!!
In progress:
Content of log :
Past build:
Link to comment
Link to comment
  • 3 months later...
This is the third time I've tried to post this.
Installed the deck furniture:cabins, hatches , pumps etc. The cutouts for the cabin sides were a pain and the plans did not help. I 'm using Longridge's "Cutty Sark" (2 vols) for reference.
Had  to build the booby hatch and rework the wheelhouse as Constructo left the details off. Broke the wheel trying to drill it for a spindle, so used a heart from another kit as a hub and wires for spokes to repair it.
Constructo's base was crap, so I bought a base from Hobby Lobby for $3 and used bronze pipe fittings for stands.
Noticed some scale errors after everything was installed > Thanks Constructo.
My mentor, the late great Hubert Sicard would have ripped everything off and rebuilt, but I'm too lazy .
Thought  the bow/stern decorations were a bit Disneyesque, but what can you do at the 1/96 scale and make it look good?
Hope the photos will help somebody.
Fair winds to ya.
Link to comment
She looks nice
Overscaling in some details just has to be, to point on some construction detail. In 1/96 or 1/100 all details just can not be presented in scale. For instance, dead eyes, the largest of them shoyld be 3mm dia. And smallest? Ropes should be as a hair.
Dont worry about. If you plan sails and forest of ropes, that scale "mistakes" just will be hiden under
Enjoy your work and keep on.
In progress:
Content of log :
Past build:
Link to comment
  • 2 months later...
Back at it... installed stanchions  fore and aft-had to fashion some from brass wire, a steel bead w/hole in it, and a crimp bead for a base. Constructo did not provide enough and they're too pricey on the aftermarket. There's a photo of the jig I used for soldering.
Finished the boats, put some oars in them and placed on the rack aft of mainmast.
Put on the figurehead which required some  minor adjustment to the bow.
Prepositioning the running rigging-really helps later on. Thought I'd be smart (sarc)and label each line, but later found that to be unnecessary as the pins are numbered in the plans.
More pics to come- have to edit them for size.
Fair Winds to ya
Link to comment
Here are the rest of the pix...
Next is to hang hanks of rope on the pins with rigging... I make a jig consisting of 2 small nails spaced 1/4 " apart (for this scale) , wrap several turns and then tie in the middle  with a drop of white glue to hold.The accuracy bug bites....
On then to mast assembly.
Fair winds to ya
Link to comment
  • 5 months later...
The shipwright is slow but still at it... got the bowsprit on, anchors aweigh (me boys). Started on the top platforms the accuracy bug struck again, and I  had to build  and plank them .and take them apart several times  ....the original plans are, very sketchy and don't work with the future rigging. Ready to start on the  masts and spars  The original ship's masts  and topmast platforms were steel; but hey, this is a wood kit so I guess I'll have to make allowances..I'll post some pix when I can...Fair winds to ya
Update: tried to attach pix below; got the bolt ropes sewn on. Next time I may use beige painted wire ON the hem. Surprise! The pix download worked!
IMG_0190.odg
IMG_0226.odg
IMG_0227.odg
IMG_0229.odg
IMG_0231.odg
IMG_0231.odg
IMG_0232.odg
IMG_0233.odg
IMG_0234.odg
IMG_0235.odg
Link to comment
I am working on the same model as you do! It is nice to see some other people working on the same model.
Currently I am working on the masts and rigging now. I will also put on a building log soon.
Good job on your build!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
