| Who is Online? |
In total there are 57 users online :: 14 Registered, 1 Hidden and 42 Guests
Registered Users: bbusa, Captain Slog, Chuck, danvad, deckape, Janos, Peter Jaquith, popeye_the_sailor, reklein, riverboat, spud, TristanHallett, w33, Zarko
[ View complete list ]
Most users ever online was 209 on Tue Jun 26, 2007 2:15 pm
New Page 1
Bosco
Vice Admiral (Special Contributor)
Joined: 13 May 2006 Posts: 181 Location: Ste-Therese (Quebec) Country: canada
Building the Ship`s Boats - Part 3 (end)
After the laying of 2 strakes on every side, we can calculate the variation of width that the next strakes must have. This calculation was already explained by video. For this 4"3/4 long launch, calculations are simplified.
When the planking is completed around the transom (1), we divide by 4 the spaces remaining to be planked (2).
The last 8 strakes are going to be profiled according to these marks.
Before removing the finished hull from its supporting frames, let us clarify the gluing points used during the assembly:
1. The keel is held on the bulkheads by 3 points, which will be removed before setting the last strakes.
2. The first two strakes are also held by three points, removed when "turning out" the hull.
3. Gluing points of strakes.
First rough hull, the jig is ready for the second one.
For the hull finish, a coat of wood filler is applied, then sanded (paper nș 220).
The joints between the hull and the keel (2) are filed with a half round file (1).
Last step before the final painting: a coat of primer (1), the keel and the stem are extended with a "Plastruct" strip (2).
For the "stern boat" of the Niagara, I will use 1mm x 0.5mm strips to see if it is better to use them in stead of 2mm ones.
Friendly,
Bosco  _________________ Soon enough,
Is well enough
Wooden Ship Modeling for Dummies |
| Back to top |
| Choose Display Order |
| User Permissions |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
