| Who is Online? |
In total there are 61 users online :: 20 Registered, 1 Hidden and 40 Guests
Registered Users: bbusa, Captain Slog, chach_86, danvad, Darius359au, deckape, dr_hemlock2, Ferrux, flyboy441, Garward, Janos, javimetal, Padreh, popeye_the_sailor, reklein, riverboat, spud, TristanHallett, w33, Zarko
[ View complete list ]
Most users ever online was 209 on Tue Jun 26, 2007 2:15 pm
New Page 1
Thanasis
Lieutenant
Joined: 19 May 2006 Posts: 448 Location: Volos Country: greece
Hi mates. After a time of bad mood…I got back working on my “Peramataki”. It will be a fishing boat so I want to add (among other things) and an oil lamp…certainly by scratched. Here is what I did…
_I took a small piece of a wooden rod close to the diameter of the oil lamp that I wanted to build. I made a hole with my rotary tool and when the drill appeared from the other side I widened the second hole so nailing… a toothpick (side to the drill) I secured the rod on the drill. So I had an off-hand lathe….
_With a file I carved and cut the rod to the shapes showing on photo.
(Wearing protection glasses)
_Then with a pin’s head, as a cap, a piece of plastic glass (from a ballpoint) and little wire as a handle I made a compose …
_With the items showing on photo and some extra side holes… I had a second version of an oil lamp.
_Sealing the holes and painting I think I have the oil lamps for my fishing boat.
Many thanks _________________ There are no good or bad modelmakers.There are more or less expirienced.
http://www.naftomodelismos.gr/Greek%20Traditional%20Modelships.html
Current scratchbuild: I'm thinking of it...
Finished scratchbuild models:Varkalas, Trehantiri, Karavoskaro, Perama, Peramataki, Vomvarda, Skafe, Sakoleva, Bombarda Sabatiera, Half models.....all in gallery with Greek flag. |
| Back to top |
| Choose Display Order |
| User Permissions |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
