RegisterRegister
Classified AdsClassified Ads Search AdsSearch Ads
MSW NAVIGATOR
New Page 1
New Page 1
New Page 1
Your Details
Username:
Password:
 Remember me
I forgot my password
Don't have an account yet?
You can register for FREE
Who is Online?
In total there are 60 users online :: 20 Registered, 1 Hidden and 39 Guests
Registered Users: bbusa, Captain Slog, chach_86, danvad, Darius359au, deckape, dr_hemlock2, Ferrux, flyboy441, Garward, Janos, javimetal, Padreh, popeye_the_sailor, reklein, riverboat, spud, TristanHallett, w33, Zarko
[ View complete list ]
Most users ever online was 209 on Tue Jun 26, 2007 2:15 pm
New Page 1
Member of International List of Scale Model Related Web Sites
Glazing Cabin Windows
Post new topic   Reply to topic   printer-friendly view    Model Ship World Forum Index -> Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
adrift
Rear Admiral
Rear Admiral
Country: uk
PostPosted: Wed Dec 05, 2007 2:59 pm    Post subject: Glazing Cabin Windows
After some experimenting and a few failures I think I have finally cracked the process using crystal resin.
I start by spray painting the frames, this is not only for decoration but to seal the laser burn area around the glazing and stop it giving the glazing a brown hue. You could of course then sand off the front of the frames if you wanted to see wood.
I then pinned the frames down over a sheet of release tape ( I used Sellotape). As the glazing resin is very liquid, to stop it running out I put a drop of Golden self levelling gel in each opening. This forms a lining and seals each cell. After allowing 12 hours to cure I then filled each cell with a drop of "Solid Water" crystal clear resin . A touch of the finger on the top of each frame levels up the resin and removes any excess.
Put the windows somewhere dust free to cure and bingo !.
The Solid Water clear resin can be obtained from http://www.guidelinepublications.co.uk/acatalog/deluxe_materials.html
The Golden Gel is an artists glaze and this or something equal is available at art shops
_________________
ADRIFT.
Ship modelling :- Is it an Art ? Is it a Craft ? Or is it therapy for the bewildered.
Back to top
View user's profile Send private message
coater87
Admiral (Moderator)
Admiral (Moderator)
Country: usa
PostPosted: Wed Dec 05, 2007 4:38 pm    Post subject:
WOW!
That really looks good! Thanks for the detailed explanation on your work. I have one question, if I were to make a mess of one single pane-do you think there is a way to fix this without starting all over, or is this a one shot type deal?
I like the look you have achieved far better then other methods I have seen, very nice.
Lee
Back to top
View user's profile Send private message Send e-mail Skype Name
Viking
Commodore
Commodore
Country: uk
PostPosted: Wed Dec 05, 2007 4:50 pm    Post subject:
Nice job on the windows Adrift, looks like old glass, might give it a try myself when the opportunity arises
_________________
Live for ToDay, Tomorrow is promised to no one
Regards
Viking (Les)
Back to top
adrift
Rear Admiral
Rear Admiral
Country: uk
PostPosted: Wed Dec 05, 2007 5:42 pm    Post subject:
Thanks guys.
Lee , the unit is recoverable until the resin cures. It can be cleaned up with Acetone. But once it has gone off it as solid as a brick. This is why, having gone through the learning curve I have posted the method, hopefully to avoid others getting in a mess. To be honest if you copy what I have done everything should be OK, the only thing to watch is getting the resin /hardener mix correct at 2/1. Too far out it can dry cloudy. But it has to be a lot out. In the States you have a different product available called Liquid Glass and it may be with this you do not have such difficulty. However in the UK this is not available and my search has been to find suitable products we can get hold of.
_________________
ADRIFT.
Back to top
zeldazork
Gone, but not forgotten.
Country: usa
PostPosted: Wed Dec 05, 2007 8:40 pm    Post subject:
That window treatment looks very good. A great find. Another good tip for my note pad.
Back to top
BANYAN
Admiral (Moderator)
Admiral (Moderator)
Country: australia
PostPosted: Wed Dec 05, 2007 9:39 pm    Post subject:
Hi Adrift,
This is the same idea I have been experimenting with and discussed in an earlier thread - looks like you have found the right way to do it - Congratulations mate - an excellent finish/result!
I was having problems with "hollowing" where the liquid would contract in the middle while retaining its original level at the edges of the windows (surface tension). To get around this I had to build it up in several layers.
I also made the mistake of trying to do this on the ship (Oops - major mistake) and, as you described, the liquid would seep behind the windows and spread. I will really need to find some of that gel.
A very authentic look; I will do it this way in the future also. I used a two part resin/expoxy called "Liquid Gloss" - I wonder if product type is another contribuiter to the finish? With the latter, you didn't need to touch it at all, but you did need to blow across it to remove any bubbles caused from the chemical reaction of mixing the hardner and the gloss.
Another point someone raised was what reaction the "glass" would have if you painted it with a varnish during the final sealing of all of your work. I have not tried this yet, but in future I intend to seal the window frame paintwork first (varnish over white or whatever frame colour you need before the glazing work - that way there will be no need to go anywhere near the glazing with varnish). I think they were more worried if you "spray-painted the varnish / finish - can always mask this off now as the frames are presealed.
Many thanks for this excellent tip
cheers
Pat
_________________
Stand tall - but learn to duck quickly!
Current Build: AL Endeavour (Bashed Kit)
Next Build: Syren (Scratch - Community Build)
Completed Build: Battle Station
Back to top
View user's profile Send private message Visit poster's website
adrift
Rear Admiral
Rear Admiral
Country: uk
PostPosted: Wed Dec 05, 2007 10:12 pm    Post subject:
Hi Pat.
I tried to do it first of all just using the gel but as you said this shrunk back and formed a concave window. I tried building it up but by the time I had finished it looked rubbish so I ended up just using it to seal the cell.You can obtain the gel in Aus at http://www.parkersartsupplies.com/golden.htm you will find it half way down on the right of the page.
As I mentioned you need to paint first to stop the laser burn causing a brown tinge to the resin. I would not varnish over after as this will take away from the clarity of the window and is not necessary.
Any queries just post em up. cheers Eric.
_________________
ADRIFT.
Back to top
BANYAN
Admiral (Moderator)
Admiral (Moderator)
Country: australia
PostPosted: Wed Dec 05, 2007 10:16 pm    Post subject:
Hi Eric, many thanks.
I will go a lookin'
_________________
Back to top
adrift
Rear Admiral
Rear Admiral
Country: uk
PostPosted: Wed Dec 05, 2007 10:24 pm    Post subject:
Pat.
And I will remember the trick about blowing across the surface, I did get some small bubbles but I said to myself that this is 18C cast glass and it would have had bubbles anyway. Wink
_________________
ADRIFT.
Back to top
Page 1 of 1
Choose Display Order
Display posts from previous:
User Permissions
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Jump to:
Skin Created by: Sigma12
Powered by phpBB © 2001, 2002 phpBB Group
Cache Posts System © 2006 AmigaLink
