RegisterRegister
Classified AdsClassified Ads Search AdsSearch Ads
MSW NAVIGATOR
New Page 1
New Page 1
New Page 1
Your Details
Username:
Password:
 Remember me
I forgot my password
Don't have an account yet?
You can register for FREE
Who is Online?
In total there are 52 users online :: 11 Registered, 0 Hidden and 41 Guests
Registered Users: bbusa, Captain Slog, Chuck, danvad, deckape, Janos, Peter Jaquith, popeye_the_sailor, reklein, TristanHallett, Zarko
[ View complete list ]
Most users ever online was 209 on Tue Jun 26, 2007 2:15 pm
New Page 1
Member of International List of Scale Model Related Web Sites
Shaping spars, etc. with an electric drill
Post new topic   Reply to topic   printer-friendly view    Model Ship World Forum Index -> Wooden Tips and Tricks and Making Jigs
bobbollin
Sub-Lieutenant
Sub-Lieutenant
Country: usa
PostPosted: Tue Mar 04, 2008 2:02 am    Post subject: Shaping spars, etc. with an electric drill
This is the text of a post I made in the LSS forum while building my AVS.
CONSIDER THIS A "POOR MAN'S LATHE" Smile
Working on the spars, gaff and boom, I came up with a method of tapering that works for me and may be of some use to others. I have had a good deal of success with tapering masts on my drill press by supporting the free end in a hole drilled in a piece of scrap 2 x 4 clamped to the drill press table. This is impractical for doing the spars, etc. due to the fact that both ends must be tapered plus the fact that they are such slender dowels to begin with. I was considering how to do them and one of the problems I have read about and have experienced first hand is that it is very easy to turn a round dowel into an oval dowel when shaping by hand. So one solution is to spin the dowel. I decided that I could spin the small dowels in my 3/8" drill but needed a method to keep from crushing the end that is clamped in the chuck. The answer was right before my eyes. I merely placed a 1" piece of silicone tubing over the end of the dowel and chucked that in the drill. The tubing keeps the dowel from being crushed and also provides an excellent grip on the wood. Then it is simply a matter of folding some sandpaper over the dowel and pulling the trigger.
This silicone tubing is available at most any hobby shop that deals in model airplane engines. It is sold, generally by the foot, as fuel tubing and comes in small, medium and large sizes. I used the large, which has an i.d. of about 1/8". You do NOT have to crunch the chuck down tightly on the tubing/dowel like you would on a drill bit. It is still possible to smash the dowel by doing so. I'd recommend getting some dowel from the local Big Box or lumber or hardware store and doing some experimenting to get a feel for the technique before you attack the kit wood. The added advantage of the tubing is that it provides a sort of crude universal joint, so that if you get slightly off center while sanding, the tubing distorts rather than the dowel breaking.
I used 100 grit sandpaper for the gross shaping. Use moderate speed on the drill (assuming yours is variable speed). If you get going too fast, you'll know it 'cause the sandpaper will get real hot under your fingers. (Remember the Boy Scouts and starting a fire by rubbing 2 sticks together? Same thing...only I personally was never able to start a fire that way!) Once I get down to within a millimeter or so of the final size, I switch to 150 grit and then finish with 220 grit.
I determined the middle point of the dowel (lengthwise) and marked it with a pencil before starting so that I knew where to not sand. After that it is simply a matter of concentrating more towards the ends and less towards the center to achieve a nice parabolic taper.
Using this method I was able to taper each end of the spars, etc. in about 10-15 minutes/end. The nice part is that you wind up with a nice smooth finish and perfectly round spars. The flats for the jaws and the little shoulders on the ends of the topmast and the boom still have to be formed with good ol' carving and hand sanding. I also recommend a final hand sanding using 220 grit lengthwise with the grain on any of the spars that you turn with a drill to eliminate the little sanding scratches around the circumference of the spar.
 Description:
 Filesize:  33.97 KB
 Viewed:  5042 Time(s)
 Description:
 Filesize:  46.14 KB
 Description:
 Filesize:  21.32 KB
 Description:
 Filesize:  26.8 KB
_________________
Best Wishes
Bob B.
Nautical Society of Oregon Model Shipwrights
Back to top
View user's profile Send private message
knightyo
Admiral (Moderator)
Admiral (Moderator)
Country: usa
PostPosted: Tue Mar 04, 2008 5:55 am    Post subject:
Silicone Tubing = Brilliant! Very Happy
_________________
Current Builds: USS Syren; USF Confederacy; Continental Navy Brigantine Lexington; HMS Triton
Future Builds: Royal Albert, George or William
Back to top
View user's profile Send private message Skype Name
Cut-Throat Jake
Admiral (Moderator)
Admiral (Moderator)
Country: uk
PostPosted: Tue Mar 04, 2008 6:05 am    Post subject:
Nice one! I've added this tip to the links section in Masts and Yards in the MSD.
If there have been any other tips that folks have found useful, make sure you let us know so we can add the links to the MSD.
Rich
Back to top
View user's profile Send private message Send e-mail
Jim Lad
Admiral (Moderator)
Admiral (Moderator)
Country: australia
PostPosted: Tue Mar 04, 2008 6:18 am    Post subject:
I've always rounded and tapered my spars by hand and, you're right, it's very easy to end up with a nice ovel mast!! Mad
This looks like a great idea - I'll have to give it a try.
John
Back to top
EdBardet
Admiral (Moderator)
Admiral (Moderator)
Country: usa
PostPosted: Thu Mar 06, 2008 5:58 pm    Post subject:
I've used this method in the past but the tubing idea is brilliant! I was leaving marks on my masts that had to be sanded out.
Ed
_________________
Current Build - Charles W. Morgan, Draw and scratch build.
Yesterday is a memory, tomorrow is a mystery, today is a gift - that is why it's called the present.
Web Page http://home.comcast.net/~knotian
Back to top
View user's profile Send private message Visit poster's website
les rogers
MSD Special Contributor
Country: australia
PostPosted: Mon Apr 21, 2008 5:13 am    Post subject: Mini Lathe
Hi Folk
This is a simple and cheap lathe that I have used for the making of masts
spars and other deck fittings.
It consists of a drill press extended by a length of aluminium
tube. I have used an old drill that has fwd, and reverse as well as speed variation. The end opposite the chuck is adjustable for all lengths and
the base plate takes several sizes of collars to handle diameter sizes.
I employ the usual methods of shaping with files and sandpaper glued to various timber shapes.
The cost was minimal at $20 for the stand plus some parts of another stand. I have purchased the Dremel saw with the hood and will have a go at converting this gadget to a drop down saw.
 Description:
 Filesize:  83.78 KB
 Viewed:  4526 Time(s)
 Description:
 Filesize:  89.95 KB
Back to top
extrastring
Warrant Office 1st Class
Country: usa
PostPosted: Thu Jan 22, 2009 4:14 am    Post subject:
Excellent - thanks!
_________________
- Hari
Current build log: http://modelshipworld.com/phpBB2/viewtopic.php?t=7195
Back to top
Janos
Sub-Lieutenant
Sub-Lieutenant
Country: australia
PostPosted: Mon Jan 26, 2009 10:27 pm    Post subject:
Les,
I used to use 4-5 rounds of masking tape for the same purpose but the polyethylen tube is a much better idea. I had some marks from the chuck jaws sometimes while using the masking tape.
Janos
_________________
Past builds (OK, some of them): Duyfken, Grosse Jacht, Chebec, Golden Hind, CH-123, James Watt
Presently building: Rattlesnake, Royal Yacht Caroline,
Future builds: Het Staten Jacht, Fubbs, Matthew,
Back to top
Page 1 of 1
Choose Display Order
Display posts from previous:
User Permissions
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Jump to:
Skin Created by: Sigma12
Powered by phpBB © 2001, 2002 phpBB Group
Cache Posts System © 2006 AmigaLink
