RegisterRegister
Classified AdsClassified Ads Search AdsSearch Ads
MSW NAVIGATOR
New Page 1
New Page 1
New Page 1
Your Details
Username:
Password:
 Remember me
I forgot my password
Don't have an account yet?
You can register for FREE
Who is Online?
In total there are 53 users online :: 12 Registered, 1 Hidden and 40 Guests
Registered Users: bbusa, Captain Slog, Chuck, danvad, deckape, Janos, Peter Jaquith, popeye_the_sailor, reklein, spud, TristanHallett, Zarko
[ View complete list ]
Most users ever online was 209 on Tue Jun 26, 2007 2:15 pm
New Page 1
Member of International List of Scale Model Related Web Sites
Deadeye rigging jig
Post new topic   Reply to topic   printer-friendly view    Model Ship World Forum Index -> Wooden Tips and Tricks and Making Jigs
captainpugwash
Admiral Of The Fleet (Admin)
Country: uk
PostPosted: Sun Sep 03, 2006 10:09 pm    Post subject: Deadeye rigging jig
The jig is made by using a balsawood block. The block is placed on the channel and its location marked with a pen at either end of the channel. Each shroud tackle is then pulled taut to the centre of the lower deadeye, and its 'run' marked on the balsa block to the point where it intersects the lower deadeye. Now you must mark a line which indicates the upper line of the upper deadeyes (the uppermost height). Where this upper deadeye line intersects the tackle lines, place your deadeyes (it doesn't matter about orientation at this point) immediately UNDER the deadeye line and fix it in position with a couple of brass plank nails. A simple push should be all thats required. AT ALL TIMES, keep this jig assembly clamped to the channel as I have in my pictures.
NOW the hard bit....pull each tackle line taut and around each deadeye. Using tweezers (and keeping everything tight), arrange the tackle so the wrap-round occurs (obviously at the top!) in line with the tackle line you drew earlier. Seal with a drop of CA. DON'T glue the deadeye to the tackle!! This now needs to be orientated correctly. NOW, each line should tie up with the same tension and the deadeyes be at 99% the same height.
What you don't see, and I should have explained also, is that there is a jig on both sides of the ship when the tackles are connected to the deadeyes. This is simply to ensure that the tackles are evenly tensioned, and not over tensioned causing the mast to be pulled from alignment.
This method is quite easy on a large ship, but if I had employed it on my Artesania San Francisco, it would have worked equally as well.
I don't have a problem in rigging the deadeyes once they are mounted....in fact, its a joy, its so easy. Just remember to add a sticky label to each tackle with a number to identify which is which.
Once all deadeyes are rigged and tensioned, I decided to modify the same jig and add a height to it which is equal to the length of the tail (wrap around) which would be bound to the shroud, above the deadeye. This then gives me a gauge by which to cut the tals to the same length. This also varies in length on a shroud as the rearmost tackles are angled more. I find this solves that problem.
And finally, don't throw away that jig just yet. It can be used to solve another fiddly problem.....that of binding the shroud above the deadeye. Once all deadeyes are rigged and tensioned, simply place the jig back to where it once sat, and use some brass nails to secure the upper deadeyes to the jig by pushing them through the threaded holes. You may need thin brass pins for this, but I found on my model that there was ample room to do this without damaging the deadeye rigging.
Now, the deadeyes are secure and won't move anywhere.....this means that the job of binding the shroud above the deadeye is now a LOT less fiddly.
Does that make sense? I'm fairly bad at explaining things. A teacher...I am not.
Jim
_________________
Model Ship World
Maximus, perspicuus, optimus!
www.modelshipworld.com
www.modelshipwrightsdatabase.com
http://www.scaleplasticandrail.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website Skype Name
kelvin12
Admiral (Moderator)
Admiral (Moderator)
Country: australia
PostPosted: Sun Sep 03, 2006 11:11 pm    Post subject:
G'Day Jim,
What a good idea. Always a problem to keep them in alignment.
Glad to see you bak again.
Dirk
Back to top
View user's profile Send private message Skype Name
DELETED
Guest
Country: Не выбрана
PostPosted: Sun Sep 03, 2006 11:34 pm    Post subject:
DELETED
Back to top
captainpugwash
Country: uk
PostPosted: Sun Sep 03, 2006 11:42 pm    Post subject:
shipmodelmaker wrote:
Jim,
Looks great Exclamation
One question Question
Why balsa wood?
Jerry G (Glickstein) 8)
Hi Jerry,
Its just easy to push pins into and remove them with fingers when you have to finally align the deadeyes. I figured that once you had rigged the tackle to the deadeye, you wouldn't want to use anything other than either fingers or tweezers to remove the eyes from the jig, lest they are snagged. My wimpish way I suppose! Laughing
Jim
_________________
Model Ship World
Back to top
DELETED
Guest
Country: Не выбрана
PostPosted: Mon Sep 04, 2006 2:53 am    Post subject:
DELETED
Back to top
Gene Bodnar
Admiral (Moderator)
Admiral (Moderator)
Country: usa
PostPosted: Mon Sep 04, 2006 10:36 am    Post subject:
This sounds and looks pretty fool-proof to me. I'll try is on my Essex in another month or so.
Gene Bodnar
Sidney, NY
Back to top
Page 1 of 1
Choose Display Order
Display posts from previous:
User Permissions
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Jump to:
Skin Created by: Sigma12
Powered by phpBB © 2001, 2002 phpBB Group
Cache Posts System © 2006 AmigaLink
