| Who is Online? |
In total there are 59 users online :: 16 Registered, 1 Hidden and 42 Guests
Registered Users: bbusa, Captain Slog, danvad, deckape, Ferrux, Janos, javimetal, Padreh, Peter Jaquith, popeye_the_sailor, reklein, riverboat, spud, TristanHallett, w33, Zarko
[ View complete list ]
Most users ever online was 209 on Tue Jun 26, 2007 2:15 pm
New Page 1
Cut-Throat Jake
Admiral (Moderator)
Country: uk
Thought I'd post this to help with all the filing and sanding that's going on with the Triton cross-section build.
I find it next to impossible to sand or file a small surface area flat, to my satisfaction, without a jig.
This sanding jig can be constructed with little more than a few pieces of scrap, a drill, a square to line things up, and a couple of bolts. You can remove the feet if you make recesses for the lower bolt heads, or use a clamp and a ruler to replace the fence. The holes can be used instead of the two slots, or to insert pegs to hold the workpiece against. Use wing-nuts to make tightening the bolts easy.
Glue the abrasive paper to the sanding bock with rubber cement. Use both sides of the block with different grades of paper. The small strip of wood on the bottom 'shelf' stops you sanding your jig instead of the workpiece.
If you want to use a flat file, then hold it again the block as a guide.
I used a similar commercially available jig for a while, until I thought of this little baby. No more fiddling with your futtocks, Triton-heads!
Jake
| Back to top |
Cut-Throat Jake
Admiral (Moderator)
Country: uk
| captainpugwash wrote: |
| What about an attachment for gripping futtocks? |
Assuming nothing has gone previously awry in the machine shop, then Mk 1 hand (2 pieces) with attachments a, b, c, d and e, usually suffice.
Or you could drill a few holes for pegs perpendicular to the sanding direction. With only two pegs you'll always have two points of contact on a curved surface.
Another cheap tool that I find incredibly useful in conjunction with the jig is the angle setter
Jake
| Description: |
| Filesize: |
44.06 KB |
| Viewed: |
3644 Time(s) |
| Back to top |
DELETED
Guest
Country: Не выбрана
DELETED
| Description: |
| Filesize: |
169.27 KB |
| Viewed: |
3250 Time(s) |
| Back to top |
| Choose Display Order |
| User Permissions |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
