Few pics for you Keith:
Just cut from a brass strip and crudely shaped. Hole drilled for a nail in top and a big hole drilled and ground to fit over the loop bit
I just played with some of my carbide and diamond bits to texture etc.
the bit attached to the chest bottom had two holes drilled into it and I made a ring eye - cut in half and glued into the drilled holes and into the wood of the chest.
Hinges made from brass strip cut to size and then cut to look like a capital "F" and the sticky out bits of the "F" were rolled back to make tubes - and a pin inserted through the holes
Current builds:
MS Syren
HM Suppy
Dos Amigos
Completed:
Schooner for Port Jackson
MS 18th Century Longboat
Bounty Launch
Believe me.. it was very crude :) I didn't even do a trial.. I was playing with the burrs and had no intention of actually making anything - just seeing what they did - and I used the trial bit of brass to make the lock bit.
Now I have some new tools (things that the burrs fit into... dentists drill - I am very impressed with it) - I suspect next time it will be a planned item and hopefully done a little better.
Current builds:
MS Syren
HM Suppy
Dos Amigos
Completed:
Bounty Launch
Hi Meredith,
Your boat turned out fantastic.  That chest is incredible also, thanks for sharing.
I love the colours of your boat, the rich wood tones against that blue is very pleasing to the eye.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Beautiful work, Meredith ... just amazing !!!
Arrr ...
:cheers:
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
