Chaperon by Papa - FINISHED - Model Shipways - Ron Gove
I purchased the Chaperon after spending two weeks camping on  the Mississippi River in West Memphis, Ark.
I think it is the best MS kit I've every had.  Here are 3 shots of my progress to date.
If I had better organizational skills I'd have done a build log.
Ron Gove
Link to comment
Share on other sites
Ron:
I put mine on flush with the deck planks.  Installed centered would trap rain water on the deck.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Link to comment
  • 4 months later...
Chicken dinners.
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
Link to comment
I assume that, as in maritime vessels, a supply of fresh eggs would be highly desirable. Even on a settled river, having your own is better than buying them, and the hens can be fed in part from table scraps.
Your Chaperon looks good so far.
Link to comment
Eric's correct - I just noticed I forgot the smiley face to end my previous post.
Kurt
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
Link to comment
Kurt has built (and thoroughly researched) this model, so he's the final authority on its specifics. But a chicken coop would be a completely normal feature of a steamboat. Also, to my eye, that structure looks too small for regular human use (especially in original photos of Chaperon), and its placement isn't right for an outhouse. Its location would drop straight into the after cabin; these boats didn't have complicated plumbing. The actual outhouses are likely within the superstructure on the boiler deck, overhanging the paddle wheel (which does a good job of disposal). I don't think any boats would have made passengers climb to the hurricane deck to use the outhouse, and there would at the very least be two of them (gents and ladies). All of which confirms that it's a chicken coop.
Link to comment
I agree.  When I get some time I will dig up some photos of these common features.  Meanwhile here is a photo of a model I did with the outhouse overhanging the wheel.  The glue OOPS was removed after I saw the original photo.
Kurt
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
Link to comment
Oh, the wheels would have been washed plenty clean by their inherent action, and technically many of the outhouses weren't dropping directly onto the buckets, just into the zone where the wheel's downward motion helped disperse the material. Probably cleaner than the bows of some sailing vessels. Although I recall a possibly apocryphal story of some crew doing repairs on a sternwheel while having someone else standing guard outside the ladies' hut to ensure that the workmen vacated the premises before any lady had to use the loo to avoid any, well, upward glances.
I do suspect you're right that, if the model shows the shed being completely solid, it's not quite accurate: there should be some ventilation and light allowed in, at the eaves at least.
Link to comment
I have attached most of the decorative railings. Everything fit perfectly together. The skylight is done and attached. I assembled the skylight fully before attaching to the deck to ensure that it was square. I am working on the Texas (which I placed on the skylight for the photo). I decided to assemble it before adding the 1/32" sq. battens. The battens are a bit  more tricky to add this way but I was concerned that they would interfere with bending the fore and aft sections. Although the sections are pre-bent using a supplied jig, there is a lot of fiddling to get the curve right when everything goes together. Since the battens are laid over the grooves that need to expand as the sections are bent, i thought it best to do them last.. I may actually get this model finished in less than 1 year!  I appreciate all the "likes" and comments.
Ron
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
