HIPEXEC
USS Syren (USS Argus) by Hipexec - Model Shipways - 1:64
166 posts in this topic
I'm working up the energy to start sanding, so to still stay busy without sanding, I built a 15/32" X 15/32" square  jig to help me when I start making the gunport sides. Somehow using a jig to supplement my eyeballs will give me square gunports.
Share this post
Link to post
Share on other sites
Let the fairing begin!
There was a tremendous amount of excess material on the lintels, so I rough faired the lintels with my Dremel, and now the tedious task of smooth fairing the lintels on both sides. In the pic you can see the bent plank I use for a gage along with the various sanding sticks I use.
src, Heronguy, canoe21 and 6 others like this
Share this post
Link to post
I used the port and starboard templates provided to mark the gunport sides. I was surprised that it was a harder task than meets the eye. The goal is to get gunport symmetry, but on a couple I had to tweak them a millimeter or so? Go figure. This frame is as straight and square as I can make it, but it is off just a tiny bit?
(I placed the template in the photo just to show you what it looks like. When making the marks it has to be fixed up tight to the gunwale.)
Share this post
Link to post
I glued in the first gunport sides. Some sides are not as thick as most. The great news is there will only be a small amount of sanding to fair these pieces once installed since they are almost net size.
Share this post
Link to post
The instructions said to wait until the last frame before sawing bulkhead #24 because the structure will now be very strong. They were right. I had no trouble sawing through the bulkhead frame. If you remember....these same frames were very fragile when first installed.
I then lightly sand the frame smooth, so I can glue the the gunport sides. These side do not appear to be square with the frame.
Mahuna, mtaylor, Tigersteve and 4 others like this
Share this post
Link to post
Believe it or not, that lintel warped upward after I cut the frame so I rebuilt the whole aft end to take out the warp. It's glued and clamped as we speak. I'll let you know how it works out.
Share this post
Link to post
Here's the aft gunport repair. It looks straight now. I guess I made one or more lintels too snug and they put lateral stress along the whole series of lintels. When the bulkhead was cut it allowed the stress to relieve itself with an upward bulge. Moral of the story....do not make lintels too snug.
Share this post
Link to post
Good work, Rich.  It's better to find the problem early, so that it's easier to fix it.  You're moving right along - looking forward to seeing the Argus in a few weeks.
Share this post
Link to post
On 2/23/2017 at 7:07 PM, Omega1234 said:
Hi Lawrence
She's looking absolutely fantastic!
Cheers
Patrick
On 1/21/2017 at 10:55 PM, Hipexec said:
There is nothing as forlorn as an empty shipyard waiting for Fedex to deliver my next model.
Hi Rich
That sure is a very nice big ship yard you have there , shore would be a joy to be able to enjoy that much open space, how ever I would disconnect the garage door opiner,      ENJOY.
Regards   Lawrence
iner
HIPEXEC, mtaylor, Omega1234 and 2 others like this
Share this post
Link to post
Hi Rich
It's nice to see you back again after  your HMS Surprise kit that did not make the MSW Form. Just found your new build and have enjoyed catching up on your very good work and hints on framing your little ship. This sure will be a very interesting build as you slowly turn her into the USS Argus.                                                             ENJOY.
Regards   Lawrence
Nirvana, HIPEXEC, mtaylor and 1 other like this
Share this post
Link to post
Port side gunport walls roughed in except for the end port where I have to saw through the last bulkhead extension. I'll wait for the PVA glue to do its magic and cut it tomorrow.
mtaylor, Jack12477, Nirvana and 4 others like this
Share this post
Link to post
I cut the aft bulkhead and got no warping this time. I sanded the cuts ad glued and clamped gunport sides.  After the glue sets I shall begin sanding and fairing the gunport sides.
Mahuna, src, Ryland Craze and 6 others like this
Share this post
Link to post
Finished sanding and fairing the port side. That rocket ship looking thing is a kids balloon blow up pump. Since I sand with a mask, I use that to blow off the saw dust.
Share this post
Link to post
Believe it or not, I had to remove another pair of bulkhead extensions to make room for the sixteen sweep ports. This ship comes with 16 very long oars or sweeps and there will be 16 sweep ports installed.
Share this post
Link to post
Thanks Rich,
I'll make a note of that in my instructions - it looks like it was the 8th bulkhead from the bow - is that right?
(edit - I found it in my instructions - it does say to take out bulkhead extension at 8)
Riccardo1966, mtaylor and HIPEXEC like this
Share this post
Link to post
Yes...these two are at #8. Don't worry...these things are now strong as an ox unlike when they were first installed.
mtaylor and Heronguy like this
Share this post
Link to post
  • I'm installing the tops for the sweep ports. Seems like an overkill since the ports are 1/8"  x 1/8" and the top is 1/4"? Oh well it will give me more surface for gluing planks.
mtaylor, GuntherMT, src and 3 others like this
Share this post
Link to post
    No registered users viewing this page.
