US Brig Syren by Hipexec - FINISHED - Model Shipways - 1:64 - building as USS Argus
Port side sweep ports finished.
Now I'm working on re-designing the stern of the ship since the Argus is quite different from the Syren. The Syren has a plain stern with two guns rigged for firing aft. The Argus has two structures port and starboard which are probably heads and/or flag lockers. The ports  apparently not for aft firing guns since there is a large step in the way that will prevent rolling guns into the ports. The inventory for the Argus only lists forward chaser guns and not aft chasers. Since the Argus was considered the "hot Rod" of the fleet while the Syren was a "slug", the reduced weight in the stern of the Argus might have played a role.
Link to comment
Share on other sites
post-8351-0-47297900-1458504250_thumb.jpgEnclosed version of these heads might be The Argus.    HM Cutter Cheerful
Link to comment
I'm getting ready for the stern construction. I re-designed the stern to make the Argus. Then I glued the two end frame pieces together as per the instructions. I then glued the re-sized center spacer to locate the first two stern pieces. I sanded off a lot of "char" to help make the glue stick. The "char" is very deep with this kit.
Link to comment
Well I can see that building the stern on this ship is going to be very, very tricky. First of all, way back weeks ago, I CA glued the stern  frame angles since they appeared very fragile. That seemed to work since the stern frames do not seem as fragile anymore.
Gluing the first "A" piece was a struggle. I tried several clamps I have, but none of them worked. I Finally drilled a nail hole in the frame and glued and nailed the frame to the spacer block. Now the first "A" frame seems perpendicular to the bulkhead and straight vertically. Nobody said ship building was easy.
Link to comment
Moving right along, I've added the second stern piece and second spacer. That's it for today since the PVA glue has to do its job.
Link to comment
Slow but sure the stern is getting done. At this stage it's very fragile, but the instructions say that will improve with the addition of sills and lintels.
Link to comment
I finished the stern's vertical frames faster than I expected. If it weren't for the use of nails, I couldn't have progressed this fast.
Link to comment
Now I realize I should have sanded off all the char on these stern pieces before installing them. Oh well?
Link to comment
Quote
The instructions call for me to cut out and tape the stern template on for part locations. Easier said than done. Longitudinally was no problem but vertically was. I finally laid a narrow straight edge on the deck so it lined up with the deck level blocks I previously  installed. Next the whole thing is like a fragile tuning fork, so I am experimenting with rubber band clamps to hold parts after glued. I have glued nothing yet.. This will take very careful measuring since the verticals will spread if too big.
Link to comment
Rich,  That does look tricky especially as you mentioned how fragile the pieces are just now.  Wishing you the best of luck as you proceed.  Just a thought - can you clamp across the tops of the stern extensions to provide some rigidity?  I'm thinking a wood strip on each side with alligator clamps to hold them.
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Link to comment
Doug,
I've glued a few pieces in and am getting some stability right and left, but there's a big unsupported space fore and aft. I'll have to figure out how to fix that before sanding.
Link to comment
I finished the stern fillers and port sills and lintels. I rough sanded the outside so I could begin to mark the stern's outline. I am sanding very carefully since I do not like the potential fragile nature of the structure at this point. It feels strong, but it's just the glue holding it on with no structural support.
Link to comment
Link to comment
Rich,
That surely is deep char.
I thought that my boat I currently had deep one, but yours is even worse. I am sorry.
Lots of sanding.
Respectfully
Link to comment
Well all that sanding finally caused parts of the fragile stern to come unglued. I'm holding together the fix with a rubber band.
Link to comment
If trying to out how to build this stern is any indication of the rest of this kit, I'm in for a long ride. The kit comes with very good drawings and a cutout sheet of wood for the stern. It just seems like I can't quite figure out how much material to take off to get the correct shape of the stern and still have smooth planking. The gunwales, when I use a plank for gaging,  don't want to line up with the pre drawn plan? I will figure it out...just not right now.
In the meantime I'm adding some filler blocks to give the planks some gluing area.
Link to comment
One problem I've found, Rich is that the plans are "flat" and the stern is curved... sometimes in two directions.  You're doing what Dirk did on his Confed and it does take some fiddling to get it right.  Same issue with following Hahn's method of gunports.. cut the plan, stick it down and cut.. doesn't account for the curvature of the hull.  You seem to be on the right track though.....
Link to comment
Mark,
I think you are correct. This kind of challenge keeps my old brain active. If I chew on the problem long enough...the answer will pop into my head eventually. I do think the curvature of the hull is where the answer lies.
Rich
Link to comment
I glued on more filler blocks to the base of the stern. I still haven't figured out how I'm going to skin this cat.
Also more sanding!  I think some of this char goes all the way through!
Link to comment
I think some of this char goes all the way through! - Ha ha. I hate char. I hate the way it smells and how it makes my fingers feel after sanding it. I feel your pain, Rich!
Link to comment
More sanding and shaping. I'm trying to get the shape of the whole stern correct. It's not easy.
Link to comment
Looking good. I find with that deep char if I sand it enough to get it smooth and get all of the "shine" off of it glue will adhere just fine. Still a pain in the butt.
Link to comment
Very slow progress while sanding and fairing in preparation for planking. I've made an array of sanding blocks trying to get into all the cracks and crevices. Char still is there?
I'm planning my own planking plan since I do not want to paint my ship and I do not want to copper it. I like looking at all the woodwork.
Link to comment
looks good, what type of planking are you thinking of using?
Link to comment
Don
I don't know yet. Where the black goes some dark wood and where the whitish planks go some nice blond wood. One thing I do know is the dark wood I pick as pretty as it is will not be Sapele. I had a terrible time planking my Connie with that stuff.
Link to comment
Time out from ship building while I install air conditioning in my Arizona garage. I insulated the garage doors, also. There's no working here without it in the summer.
Link to comment
AAHHH! Cold air!
Now I have to clean up the construction mess then get back to ship building.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
