Fokker Dr 1 by Mike Dowling - FINISHED - Artesania Latina
On 26/03/2018 at 7:52 PM, Mike Dowling said:
Not quite my friend. What might sway your choice is that the rudder, ailerons etc on the Sopwith were supposed (!!!) to move when the model was finished. On this one, despite the appropriate cables, they are not supposed to function.
Which doesn't mean those should remain static ;) (can always try to persuade you ...)
Carl
Link to comment
Share on other sites
Popeye, everything you see is metal, no plastic at all on this kit except for the plastic thread provided for the tensioning wires which, by the way, doesn't work. Despite the video instructions on how to do it the thread will not stick to the deadeyes. I have had to resort to black polyester thread instead and sofar have done about half of them.
I know what you are thinking Carl and you can stop it !! This plane is going to be for'static display' definately. I only discovered this when I put in the control stick which has no articulations at all and my skills are not up to scratch building one that has especially at this tiny scale. Neither does the rudder pedal so the same applies. You will be wanting me to build one with a working engine next.
Previous boat builds:
Amerigo Vespucci Occre
Yacht Mary
In the Gallery:
Link to comment
very tedious work to keep all the pivots movable....then all the fastenings that go along with it.   my hat's off to all who can achieve this......an act of the purest insanity  ;)    I have trouble even with plastic kits......one ill drop of glue,  and I've failed :(
the kit has me fooled........clearly can see what looks like mold lines on the frame parts :wacko:  kinda interesting
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
There are a lot of pieces of brass tube that hold the metal sections together and small indents in various places where bits have to attach. If that's not what you mean Popeye then I didn't clean the edges well enough with filing. I thought I had done OK.
Now, joking apart guys, the Sopwith I made which was a model airways kit did have the correct articulations to make everything move in theory. What let the situation down was two things. Firstly the thread supplied for the cabling was quite stretchy and secondly a couple of what should have been pulleys in the wings  and rudder bar were not smooth enough to allow the thread to move freely across them. The end result was that everything did move as it should but not enough. John Blackwell who also did the Sopwith had I think similar problems. Obviously the AL kit was never intended to have moving parts. I don't know if the model airways version of the fokker does but I do know that the Albatross I have in my stash should !!
In the end who is going to move them anyway ? I can't find 1/16 pilots anywhere although I spent ages looking.
Yacht Mary
In the Gallery:
Link to comment
How are your bonsai skills ...?
Oh golly, another kit impatiently waiting for some TLC (knifes, glue, and paint) ... already looking forward to the next one. But first things first ... Dr 1 (could be a 007 film title ;) )
Carl
Link to comment
To be honest i wouldn,t worry about having moving parts ,as u say who will move them anyway ? i would be more concerned about the finished look  . problem with moving parts is people are inclined to move them and usually break them !!!!
Link to comment
Firstly a big thank you to all who are watching and liking what they see. Its great to be able to share the log.
Now, here is a turnbuckle.
After 36 of them and a lot of string (!!!) here is what it looks like now.
Yacht Mary
In the Gallery:
Link to comment
Yacht Mary
In the Gallery:
Link to comment
You have some well trained spiders, Mike.:o:D
Your rigging is excellent.
Ken
Started: MS Bounty Longboat,
Link to comment
Don't be such a scaredy !! If I can do it anyone can. The rigging on the fuselage of this is much more complicated than the Sopwith but conversely the wings on this are much easier - if  ever get to them - just wrestling with the tailplane at the moment.
Yacht Mary
In the Gallery:
Link to comment
I started going through your log day before yesterday, yesterday and caught up now. This sure brings back memories from a previous life when I owned and operated an aircraft repair business.  Yeah, repaired quite a few damaged steel tube fuselages and wooden as well as metal rib, fabric covered airplanes.
We never made much money but I had a lot of fun, especially test flying them after they were put together.
As a matter of interest the more modern steel tube fuselages do not have the bracing anymore. Some more high performance aircraft had diagonal tubing welded instead though.
You are doing a bang-up job Mike. Hope you don't mind tagging along.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
You are more than welcome Piet and thank you for the interesting information.
I think Boyd that piano wire was used for the bracing, in the Sopwith anyway.
Yacht Mary
In the Gallery:
Link to comment
We have a tailplane !
Yacht Mary
In the Gallery:
Link to comment
Most of the early WWI planes did use piano wire and turnbuckles for adjusting tension, if I remember correctly.  Lightweight, readily available, and relatively  simple to use.  The caveat is that later in the war, the faster, heavier fighters and the bombers needed something stronger and went to braided cable.
Link to comment
And now we have a fully rigged rudder and tailplane !!
Yacht Mary
In the Gallery:
Link to comment
Nicely done, Mike. The skeletons of those old string bags were ingenious construction.
Ken
Link to comment
holy cow Mike.....your moving right along!   the rigging looks super...stabilizer and rudder looks sweet!   your making me want to bring my Fokker out again.it's in the closet at the moment.......lot of sanding and shaping the leading and trailing surfaces of the wings,  as well as the fuselage.  :)    it's nothing like what your doing though.......really nice work there!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I must admit to being in a bit of a dilemma now. I know what you mean Boyd but I was only going to cover half the plane like I did with the Sopwith. All the insides would show from one side and likewise for the wings.
What do others think because I can't make up my mind ?
Yacht Mary
In the Gallery:
Link to comment
The magazines for the guns, the oil and fuel tanks are installed. The fuel tank was huge struggle as in order to fit it I had to file away quite two quite big areas on the underside to accommodate the legs on the firewall mount. I got there in the end. The firewall is held on by four 0.5mm bolts theoretically with nuts on. There is no way on this planet I could get the nuts on so I just had to cheat and glue them. They would be very hard to see anyway.
Basically the fuselage is now done except for 'wood' panels to go on the sides - they are made of metal but have to be disguised as wood. This depends on whether I cover half or not which is where I need your help viewers !
Otherwise the next stage is to start on the lower wing.
Yacht Mary
In the Gallery:
Link to comment
That shouldn't be a problem, just do two of them. One covered and one not covered. :)
"Peace is not something you wish for; It's something you make, Something you do, Something you are, And something you give away" by Robert Fulghum
Link to comment
That's one idea but the bank manager won't like it.
Yacht Mary
In the Gallery:
Link to comment
I know what you mean, I am surprised that I get away with what I do.
"Boys need there toys".
My vote is "not covered.
That is a lot of work to be covered forever.
Link to comment
Now look folks, maybe you don't understand what I am trying to decide about, but, for those who haven't sen the Sopwith - this is what I mean.
Yacht Mary
In the Gallery:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
