Bounty by Baker - FINISHED - Revell - scale 1/110 - PLASTIC - semi scratch and extra detail
Welcome on  the build of Revell's Bounty scale 1/110
I got this kit for free from friends who cleaned up their attic.
My first idea when I opened the box. Was oops ....
On closer examination, it turned out that the model design probably dates from 1956. The mold is from 1978. Therefore the "lesser quality" of the details to current standards.
IMG_20181128_202451.thumb.jpg.6fdd20082c164623f60fd54ec871a76c.jpgIMG_20181128_202532.thumb.jpg.7855de5a9d1f1d88c4926a323d6dc9c3.jpg
First, i wanted to throw everything away. But it had some trouble with this idea.
So why not start on it and try to add some extra details.
This will not be an exact copy. My biggest challenge to make this model a bit nicer than what can be made with the contents of the kit. I am not going to buy extra parts, only items and plastic sheet from the parts box will be used.
My only experience with plastic ship models dates from my younger years.  I have only experience with military models in scale 1/72
So we shall what the future brings.
Main goals are : making of a good model and have fun.
Info about the ship and voyage
https://en.wikipedia.org/wiki/HMS_Bounty
Royal museum Greenwich
https://prints.rmg.co.uk/search?q=bounty&type=product
Info about the Revell model
https://www.revell.de/en/products/modelmaking/ships/sailings-ships/h-m-s-bounty.html
the deck is equipped with molded on details. Removing all this and making them new is impossible.  That's why I make a new deck first
Engrave the deckplanks on plastic sheet
Add hatches and "grating" (This grating may be replaced later by something else)IMG_20181230_145036.thumb.jpg.7411bb7fae95007f59ceba43a575b891.jpgIMG_20181230_155711.thumb.jpg.787dc06241d095ec4a9ac7eadeca1b02.jpg
Opening for a ladder. I dont throw plastic leftover parts away ....
IMG_20181230_163729.thumb.jpg.a43995be50b1c5c354fe036f1dbae0ec.jpgIMG_20181230_163716.thumb.jpg.fb8be2625316e8ba17753db525842889.jpg
A first test to see if the deck fits.  and... it fits
With 2 Bradley's in the background
to be continued, thanks for following.
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
Share on other sites
update
Both hull halves are glued together with the deck.
All molded on details on the inside are first sanded away. The round cannon ports are made square and all holes in the hull that are not needed are closed.
The outside of the hull is now being cleaned up.
IMG_20190102_182808.thumb.jpg.a054f9a25339874fd9d8805296eca01e.jpgIMG_20190102_192723.thumb.jpg.29a4d7bc3a65aa343c84d81cb5f9fdb4.jpgIMG_20190102_192825.thumb.jpg.ba42feea53fc4875843a29b42d431e52.jpgIMG_20190104_184516.thumb.jpg.17bb0b0e90f491d4bd30d311428d6bde.jpgIMG_20190104_184524.thumb.jpg.aa90f30627251617f7dbfcd651fb7e2a.jpgIMG_20190104_202848.thumb.jpg.1db0cc61f38804cfd4ade67d2f50dd41.jpgIMG_20190104_202804.thumb.jpg.e6fa241c371391ddee683c15f2302f18.jpg
Thanks for following
Regards, Patrick
Link to comment
I’ve build the Beagle from Revell once, probably around the same year it came from it’s mold and do look so similair to your Bounty...
Nice kit and good luck with the build.
Link to comment
Thank you,
In the meantime, a cautious start has been made with the fitting of bolts. These must be carefully sanded later
And an attempt to imitate the "nails and planks"
"bolts and nails" are made of stretched spreu
Edited by Backer
Regards, Patrick
Link to comment
Short update,
The rudder is cut loose from the hull and the bolts are placed. IMG_20190111_184710.thumb.jpg.23e21596fda53698690690026293a9f5.jpgIMG_20190111_205734.thumb.jpg.90376ad8928e9f15ae0870c669357ef9.jpgIMG_20190111_205818.thumb.jpg.2a9be6e18645e23edbc536fed82a2332.jpgNow can be started with the further finishing of the hull
Regards, Patrick
Link to comment
Made some progress  today.
IMG_20190122_184141.thumb.jpg.4d8488edf6fe2b5cc36c423a49bf3bdf.jpgIMG_20190122_184205.thumb.jpg.f988eabc27974beb12e85b87d3203bd9.jpgIMG_20190122_184240.thumb.jpg.f7b72aefd27e0104015768fc07241dd7.jpg
Regards, Patrick
Link to comment
Update.
IMG_20190127_100511.thumb.jpg.c2a0b4103558b92ee2be7be593f510b2.jpgIMG_20190127_100522.thumb.jpg.f5437c4b453243322890f8f7c7912dbb.jpg
Regards, Patrick
Link to comment
The channels have been cleaned up and are installed
IMG_20190127_104037.thumb.jpg.93b679277e2e8f05b087964cdaae73ad.jpgIMG_20190127_104057.thumb.jpg.a01f692c42f4a25a9bdff4f8b98c7370.jpgIMG_20190128_192344.thumb.jpg.02ac82078e4767629e654b25a883654a.jpg
The side windows are cleaned up and provided with clear plastic sheet.
IMG_20190127_110457.thumb.jpg.a5ed5ed9d1751a5c2dbcca435cfa2765.jpgIMG_20190127_115623.thumb.jpg.6619a808b2febb94b60aa76ec229cde9.jpgIMG_20190127_120909.thumb.jpg.75f92a2ed17aa70890121dab0c5d0cf6.jpgIMG_20190127_121258.thumb.jpg.0eb356065d5cb5a8b0d61e5eccc97072.jpg
Regards, Patrick
Link to comment
I am going to try to apply copper sheeting made of plastic sheet.
One side done (not really ok, could be better).
IMG_20190129_183959.thumb.jpg.ba3390791afd7766110fc2696a3dae71.jpgIMG_20190129_183948.thumb.jpg.3df61f293b2c1174cc8b89b15c60e24f.jpgIMG_20190129_185729.thumb.jpg.c5c968d54b18b74a4e712fede638f46f.jpgIMG_20190131_195434.thumb.jpg.fae0bfc075746547a5ea90c7cb8f6d3e.jpgIMG_20190131_195558.thumb.jpg.6ee655d4de7434624cfb29da631169a0.jpg
Regards, Patrick
Link to comment
The copper sheeting has been slightly sanded. Now I have started to apply imitation nails. I use a large steel needle for this.
IMG_20190204_161411.thumb.jpg.aadccbdba98f846288ad8b0a087b08f9.jpgIMG_20190204_161357.thumb.jpg.1cc64408f1900b6e1e0a9883e849bea0.jpg
Work in progres, still much to do and new hinges must also be made for the rudder.
IMG_20190204_155142.thumb.jpg.4e6bf0ec9194a2019b8171c5ab74c396.jpg1909880424_IMG_20190204_155035(1).thumb.jpg.899a429b75385d42ebd53bc783453fb5.jpg
Regards, Patrick
Link to comment
Thanks.
I used sheet of 0.2mm thickness. Too thick for this scale, of course. But the result is not that bad.
Regards, Patrick
Link to comment
update,
The copper sheeting is ready. The rudder now has 4 hinges as it should be (The model had only 3 hinges).
The railing has been removed again, it was not really what it was supposed to be.
IMG_20190210_162811.thumb.jpg.352c1619b6b9811158ff060a745f4a4a.jpgIMG_20190210_162845.thumb.jpg.8e368ec93b1b02f175d5877dccc54c4d.jpg
Tested with a metal color, can be okay.
( Shipyard closed in the summer, on hold until october, november 2019)
Edited by Backer
Regards, Patrick
Link to comment
Very nice work on the kit, look forward to following. Great idea for the hull, looks good so far!
Current build project:
CSS Alabama 1/96
https://modelshipworld.com/topic/20148-css-alabama-by-jonathan11-revell-196-scale-kit-bash-90-historical-accuracy/
Finished build projects 2018:
H.L Hunley 1/24
CSS Arkansas 1/96
Link to comment
  • 7 months later...
Welcome back to this fun build of a little Bounty.
I started reapplying the removed parts.
The belaying pins( primitive, but better than the original) and new steering wheel is under construction.
IMG_20191002_192320.thumb.jpg.c7f49fbb9dedee5c52dcf548c93ac07f.jpgIMG_20191002_192340.thumb.jpg.7068e8f26bd8061996d4619eb9f2eeb8.jpg
A piece of cargo bed from a 1/72 truck is perfect for the hatches on the deck.
IMG_20191002_195421.thumb.jpg.633f8537d11ad8cecf0d6b89ae6faaad.jpgIMG_20191003_185713.thumb.jpg.18ee97f7b8c54c55a6301bf798cfcd26.jpg
Removing the supports from cannons and rebuilding them.
IMG_20191003_193632.thumb.jpg.dd562e9c0e45416e5cf54840d38094cf.jpgIMG_20191003_200155.thumb.jpg.abbdd11ac77b0a093415b2a3fb767b9b.jpg
Regards, Patrick
Link to comment
Installed a new railing and all the cannon supports are in place
And also added some extra detail to the beakhead.IMG_20191017_193932.thumb.jpg.db6b3dc7c15b63c369af8dbe0808ccdc.jpgIMG_20191017_194001.thumb.jpg.4d63e1abb623da93adbe7e69aef52b17.jpgIMG_20191018_183622.thumb.jpg.2d67cd0c9ee6b610932bb346c292d7eb.jpgIMG_20191021_190931.thumb.jpg.b0099190bbd49eac8e099d3341a7db52.jpg
Regards, Patrick
Link to comment
Thanks,
I'm doing my best to give this old model a "upgrade".
Regards, Patrick
Link to comment
I like your technique for the copper bottom.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
Link to comment
Once again, you're doing a great service to an older kit. Great upgrades and fantastic photos, we can all learn from your example. I have to ask, in one of the photos in post #13 there is a ship in the background, what ship is that?
Link to comment
My version of the Golden Hind.
Regards, Patrick
Link to comment
Small update,
Some PE parts have been used (leftovers of military modeling)
Looking around this forum for different Bounty logs. It seems like there are different models. Every manufacturer of ship models has its own version.
I go for this solution.
IMG_20191029_183200.thumb.jpg.ffc3ed3291a15ea4e78749172e8a9fce.jpgIMG_20191029_185853.thumb.jpg.327d386196f95b55d4d9112f301ad26d.jpg
Regards, Patrick
Link to comment
Update,
The chimney from the kitchen below deck. On most models, the output faces forward. On the old plan it is directed backwards.
Original piece:(.
Adjusted and mounted on deck
Extra detail on the channels
The windlass
Original piece.
With extra detail
IMG_20191119_153102.thumb.jpg.770311c718c537cc27ef1f61b17953fd.jpgIMG_20191119_153142.thumb.jpg.6e9b25e986097b2c911fdb45144e4664.jpg
Regards, Patrick
Link to comment
Further progress
Made a ship's wheel, a capstan, pumps and a "dovecote" on the stern. All made of leftovers from the partsbox
And added eye bolts
the original partsIMG_20191121_184035.thumb.jpg.aad1586c6695bfd7f46632912a19de6c.jpg
A new ship's wheel (not yet glued on the deck)
the wheel itself is in the front of the axel and not in the rear as on most model kits
the capstan and 2 pumps.
The capstan (could be made better, but scale 1/110 is small) There are 2  pumps as on the origal drawing of the ship, and not a chain pump as on this kit.
The dovecote.
It looks like that this "dovecote" served to store the signal flags. The front part protects the rudder (not yet ready)
Regards, Patrick
Link to comment
On 11/19/2019 at 12:21 PM, Backer said:
Update,
Original piece:(.
The chimney for the galley stove was called, in English use, the "Charlie Noble."
Rather a lot of those were able to rotate, so that the wind over the deck improved the "draw" of the chimney (having the exhaust end face into the wind would push air back down to the stove--these chimneys were often quite short, so the draft was important).
At anchor, the wind would generally be over the bow.  At sea, the wind would be through an arc of around 200-220º centered on the stern.
Some Charlie Noble will hae a handle on them above deck to be able to turn them down wind.  Others will just have a handle under the deck beams to the same end--sadly, the plans often do not tell us of these fine details (which were often left to the preference of the shipyard building).
This is one more case where the people of old crassly and meanly focused on what was important to them, utterly without consideration of the minutae we modelers might require centuries later.  The meanies 😀
Edited by CapnMac82
spelling
Link to comment
15 hours ago, Barbossa said:
I was wrong to assume, the "dovecote" had something to do with pigeons...
Thanks,
We had pigeons at home. My father, and I, were "duivenmelkers"  translate to English??.
My childhood was influenced by pigeons, pigeons, pigeons.
So, my first idea was "a dovecote"
10 hours ago, CapnMac82 said:
This is one more case where the people of od crassly and meanly focused on what was important to them, utterly without consideration of the minutae we modlers might require centuries later.  The meanies 😀
14 hours ago, CDW said:
A real pleasure to see.
thanks for the explanation and the nice comments
Regards, Patrick
Link to comment
Small update
Added belaying pins around the masts
IMG_20191127_194711.thumb.jpg.8a92b405d26eafded80ee9d2c9ce6833.jpgIMG_20191127_194700.thumb.jpg.de4434e4bf683b05b0dfa0d1a63dfbfc.jpgIMG_20191127_194739.thumb.jpg.662005e24258c2b8aed5cd72e017deac.jpg
And this
Washed with water and soap and ready to start painting.
Regards, Patrick
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
