Scottish Maid by Fraser - Hall's 1839 Clipper Schooner - 1/8th scale - Finished
Been laid off for a bit. Christmas, outdoor work etc. and got back from the UK with a nasty chest infection...terrific so now drugged up, chest infection seemingly abating. The barky is now on it's base and the base is pretty well painted..bits of foam to be added....
I've also got the first sail up - hooray, but haven't included a shot yet as I've had to get help (thanks Weflack) about the run of it's sheets.....details, always more details. More tomorrow, all being well!
A tops'l
Rather useful having it on it's base as it creates a bit of a buffer zone...
Link to comment
Share on other sites
I have fallen horribly behind with updates to my build. Catch up time! On of the major considerations with this build has been that of trying to produce a reasonable accurate rig. I have three sets of plans of various 19th c. Schooners and they all differ, a lot. So everything I do is accompanied by a fair bit of head scratching and research. However, progress continues. Fore tops'l up -
Accompanied by a lot of tiny blocks, of course.
and more sails...
...and a lot more lines! the reef pendants really try the patience.
They're a far cry from perfect...maybe next time, but they look quite good with a bit of light shining through.
Generally, I think it's easier to get a sail laced to a yard, and then put up the yard. It's a good idea to make sure you have all the blocks needed in place first, unlike me. another lesson  learned.
So here's where I am now, a few sails, a stack of rigging, anchors and, shudder, a 17ft longboatleft to make. I think the open boat is going to be, uh, challenging
The colour balance is way off here, the sea is not such a lurid blue!
Thanks for looking!
Link to comment
Thank you! OK...nearly at the end of the rigging now. WHEW! All of the sails ( at least all it's getting...) are up now. There's a bit of fettling left and the main mast shrouds need rattling down... I think a couple of days off and then start on her boat and anchors. Now, before anyone says anything, I know that there are undoubtedly errors and omissions in my rigging. It's been a bit of a struggle finding out what where and when. Since this is my first scratchbuilt sailing ship, I'm reasonably pleased with how it's going.
Link to comment
Just found this log. Excellent work. She's a very pretty ship. I like the scale and the diorama style build too. Great job.
Link to comment
Beautiful!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
You should be pleased and proud.  She looks great!
Link to comment
Ah, she's a fine boat and something to be proud of.
Bob
Current build:  SS_ Mariefred
Link to comment
Somehow missed this log as well. The sails come on nicely. How are they done ? I don't seem to have seen an explanation.
Yes, please!  More detail on how the sails are done.  You are showing some fine work here and the details of how you are doing it would be greatly appreciated.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Link to comment
Ah, right, sorry about that, thought I had...duh...OK, here tis.
OK, Sailmaking for Dummies actually more like by a Dummy... Ain't rocket science, but um, ain't easy either... I've been doing a lot of experimenting...(read 'cocking up') I've tried various papers. Philip Reed uses tissue, but then he's working at a smaller scale. I kept ripping them. Daler Layout Paper, is strong, acid free and weighs in at 45g -thin- without being too fragile is what I'm using at the moment.
So watcha do is stain the paper a nice warm off-white with some yellow ochre water colour applied to both sides with an airbrush. I taped the paper to an old canvas stretcher so I could do both sides at once... Then, draw lines (both sides, and make sure they line up) to represent the panels that make up a sail, back then they were generally about 2ft. wide. It helps, a lot, to have patterns printed out to trace from. Layout paper is thin enough to see through to do this.
I tried printing the lines out, but couldn't get an accurate enough line up to do both sides... Right. Cut out yer sail/s
The usual thing is to then put the sail onto the 'mould' a ceiling light glass cover, in this case, but a a plastic bowl giving a reasonable curve would be best.
Then stretch a chunk of old tee-shirt over it and dry. A hair drier or fan heater is good at this point as blowing on it would probably be exhausting and take a long time...
Then you'd start gluing on the relevent doubled bits, like the edging and banding where the reef points go through..
In fact, I found that it worked OK to put all those bits on while it was still flat and then set in the curve. Here's a tops'l I made today. It's not quite right as it stuck slightly to the glass and shows a bit of damage so I'll be making yet another, but you get the idea: a translucent sail with the shadows of the tablings etc.
The sails are then laced to the relevant yard or boom and given another splash with matt medium and tdried with a hair drier, which adds to the curve.
After this there was a lot more block making...
and rigging...
Needless to say, much has been done since the last entry, Things have been a bit busy around here and I've gotten rather behind with postings.
A boat had to be made. Here's the first hull half, roughly carved.
more shortly...
Link to comment
Guillemot,
I'm just discovering your beautiful work. Thanks for the explanation of how to manufacture sails without the use of a sewing machine! This opens all kinds of possibilities.
Also, I read that you're not entirely happy with the color of the water. That's not the first thing that catches the eye. What is more remarkable is the texture nd the way it meets the hull. That's all very realistic. Besides, the water takes on all kinds of different colors in different parts of the world; who is to say what is a correct color?
Tom
Link to comment
More on the boat... This is one of those jobs you start knowing that there's a fair chance you won't get it right first crack...Making sure the gouges are really razor sharp  - less likely to slip and get buried in your thumb...and using a very light touch help.The two halves were gouged out till they were thin enough to be translucent.
Carved out and in... then a really thin bit of Degame  was cut to be the keel/deadwood/cutwater...2 attempts.
Then the interior was detailed.....
The hull planking is paper, think i might have used slightly thicker paper to make the 'clinker' more apparent. Now it just needs oarlocks cut, a rudder and oars, and paint and it can then be put onto the ship.
Oars, 6 of them for the ship's boat. Printed out the blade shape, doubled which is then cut out, folded and glued to the shaft. Then painted and put into the boat
Link to comment
Well done.  You make it seem so simple.
Bob
Link to comment
Link to comment
Very nice looking model I like the way you tackled the sails and the ships boat.
Michael
Link to comment
Blood, sweat and tears, mate! That's always the thing with WIPs, they get edited ;) Any time I try something new, like making sails, there's a stack of chuck outs, but we learn best through cock-ups, eh?
WOW! I thought I was the only one that had more trash than boat.  :P  :P
Bob
Link to comment
What did you draw the lines on the sails with?
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
