Wintergreen
So Where Do You Do Yours Then (Model making That Is)
Where do you do yours then?
553 members have voted
  1. 1. Where do you do yours then?
    • On the kitchen table.
      50
    • On the living room table.
      42
    • Other living area facility.
      156
    • In the basement.
      80
    • In the attic.
      14
    • In the garage.
      63
    • In a workshop.
      157
    • In the patio (yes, I've seen it before).
      8
    • Other...
      48
    My shop is located below our sun room that has a sunken hot tub. (Here are two shots of the area from my blueprints.) Originally that area was designed as a slab on grade with frost footings and compacted fill.  Due to grade changes, the frost walls became full height walls.  After the foundation was done and waterproofed, I found that  it would be a cheaper option to put a wood framed floor above and a basement floor slab below than to haul in and compact that much fill, plus it would just make that much more usable space in the basement.  So I decided to have the builder cut an opening through the separating foundation wall for access to that area.100_4260.thumb.JPG.f2f4fc5483cf740cfd7528741d6cbc26.JPG100_4261.thumb.JPG.874c78e18526f25102b66c2053cd3205.JPG              Eventually, after having used the hot tub regularly for many years, it developed a lot of problems leaking from inaccessible (short of pulling out the tub) areas so we decided to just drain it.  (As it turned out I wouldn’t be able to get in and out of it any more anyway.)  So I thought that the area would be a perfect area to set up my model shop as it had its own power sub-panel, basement floor drain, and with the addition of a solid core wood door and a vent fan to the outside, it could be separated from the rest of the basement.  (Just trying to keep saw dust and flammable vapors away from the furnace.)  It was also a better alternative than continuing to use my unheated garage shop area, considering our WI winters.                              But then, right in the middle of all my remodeling, I found myself confined to a wheelchair, which kind of made finishing the rest of the room just a bit more challenging.    If not for my stand-up frame shown here and a helpful neighbor it couldn’t have been done!  I also ended up having to modify all of my stationary power tools so that I could still use them. Perhaps reading this posting may give other people with disabilities some ideas on how to make the best of it.100_4024.thumb.JPG.ebac512d13a757da0842d5889d1edce7.JPG              I installed additional outlets and ceiling lights. I also had a white finish acoustic ceiling installed by a friend to help brighten up the room.  Almost all of my equipment was made to be mobile on casters to make it easier to move around. (I no longer have the strength I used to have)  Running my power tools in the room still proved to be a bit too loud, so I tacked up some cork bulletin board panels over the black tar waterproofed concrete walls with a few tap-con fasteners and fit them around the electrical conduit, which had the added benefit of lighting up the room some more.  (Adding several years’ worth of nautical calendar photos to the cork panels didn’t hurt either.)
            Here is the entrance to the band saw and drill press area (approx. 7 ft. x 11ft.) of the shop below the sunken hot tub above.  My Dads old Craftsman band saw needed a much lower base, so I removed the metal stand and made a custom roll-around cabinet with some ¾” birch plywood, ¼” hardboard, 2x4’s, 2 1/2” locking casters, an old piece of countertop, and some recycled plastic drawers.  I designed it similar to my other bases but mounted the motor on a hinged shelf.  (The motor projects into a gap in the stud wall)  Beyond the band saw is a Ryobi drill press mounted to a similar base but I used some cardboard box bottoms from quite a few orders of premium pears for the drawers instead.
100_4224.thumb.JPG.e22d536091ea5ab1c0afd9517fc2d548.JPG           Here is the reused old band saw stand on its roll-around base with a heavy generic disc/belt sander mounted on it. (I can use it in the garage for the real heavy sanding jobs where I can be wheel it outside if necessary.)
          This is the entrance to the main part of the shop, (approx. 11 ft. x 15 ft.) where I seem to be hard at work. (Or play?):P
         Here is a small generic belt/disc sander and a MicroLux table saw mounted on another one of my custom wheeled benches. I have a small (but quiet) shop vac next to a converted roll around kitchen cart that I used a recycled heavy piece of solid laminate for the top.  It has a Craftsman scroll saw bolted down on one end (It’s at a perfect viewing height for me in the chair.) and a couple of movable cutting/sanding jigs that mount on some threaded inserts.
        This is the rest of the kitchen cart with all of my Dremel tools including a drill press with a Proxxon XY table.  Next to that is a roll around drawer cabinet re-purposed for misc. supplies and hand tools (Formerly a waxing station reclaimed from my wife’s closed hair salon minus A LOT of scraped off wax!) with a small reused plastic drawer cabinet and a weather radio on top.  (Also from her shop)  Next is a modified roll-around retail sales case for basswood storage.  (I picked it up at hobby shop closing and trimmed 18” off the bottom for easier access from my wheelchair.)
    This is the soldering station end of a custom designed heavy duty roll around workbench I built to allow my wheelchair to roll under.  By using the top row of wood screws on the face of the bench, that allows me to temporarily mount some interchangeable plywood base-plate mounted tools including a small metal vice (that is shown mounted here), an anvil, and several bending jigs. A shelf for my I-pod and Bose powered speaker is mounted above.
          This shows the rest of the heavy duty bench with a portable Sjobergs wood vice (several threaded insert mountings allow various different placements) and a portable desk lamp. (With several pre-drilled mounting holes also.)  Next to that, I have some general storage made from metal shelf supports set on the basement floor and bolted to the foundation wall with shelving made from some salvaged 1 3/8” hollow core bi-fold door slabs.  (All of my basement shelving is made with these slabs.  They are light weight but are still very sturdy and resist sagging quite well.
         The rest of my general storage including an old steel hinged auto parts wall cabinet salvaged from a closed gas station and several plastic drawer cabinets.  (From my wife’s shop of course.)
         This is my primary modeling table.  (It’s a very sturdy recycled roll-around computer station with a shelf and a desk lamp that I added to the top.)  I added a homemade plan holder, a power strip, and two drawers made from some extra roll out trays from our pantry cabinet added below.  Beyond the modeling table I have a roll-around steel tool stand with a fan for hot days and an electric heater for the cold ones.  Also next to that on the floor I have a dehumidifier and my old stereo cabinet with a glass door for reference materials below.  It has a brush cleaning station and radio/disc player mounted above on a sink cut-out from an old kitchen countertop.  (All of that stuff on that dividing stud wall behind everything is all of the equipment for the hot tub above.)
100_4230.thumb.JPG.eb8355d25e723f26f55cb8666b0031de.JPG          Just outside of the shop is a computer dedicated to modeling only.  It’s not connected to the internet at all, so no crashes for my info.  (It’s also safe from all of my modeling dust.)
             Besides the basement shop, I still had the full size equipment in the garage that now also needed customized bases.  Everything was too high for someone in a wheelchair to adjust, operate safely or maintain.
            My Grandfather left my Dad his old Craftsman cast iron top table saw and Dad built a two wheeled semi-mobile dust catching base for it.  When that saw was passed on to me I originally just remounted it on a fully adjustable four wheeled roll-around base, but now being in a wheelchair, the table top was right at my eye level.  Not the safest situation to say the least!  So now I unassembled the base and cut the height down about 18” while still retaining the dust drawer below.  Now it’s not ideal, but definitely more usable and safer.  Now I can still cut my own planks.
          Also handed down from my Grandfather is this very heavy duty Walker Turner ½” bench top drill press. For this tool I took two old reclaimed kitchen cabinets, cut 18” off the tops, remounted the drawers for drill accessories, cut the doors down to fit, added a couple sections of solid countertops, and placed them about 12” from each other.  I mounted another section of that solid countertop between them to lower the drill enough to bring the drill controls within my reach.  The biggest shortcoming of the drill press was that the table had no lift mechanism and as the table was very heavy it was too tough for me to lift it from my current position.  Other than that, its large capacity still comes in quite handy at times!
         The last tool, and probably the most used, is my Dads old Power-Kraft radial arm saw that he mail ordered from Montgomery Wards back in about 1960.  (Except for the motor, it came totally unassembled in a couple of wood crates.)  This included a heavy gauge steel base that I had previously put a wheeled base on, but once again this saw was too high for me.  After a lot of work with just a hacksaw, I managed to shorten the legs, enclose the space below, add a shelf, and reassemble on the mobile base.  The power switch was bad and stuck in the on position.  The replacement switch was no longer available, so I mounted a power strip to plug it into and use that to turn it on and off.
         I had to carefully measure the height from the floor to the bottom of the radial saw table top to allow the table saw to nest under it and save some room in the garage. (For the cars, since that’s what a garage is really for, right?)
          As you may have guessed by now, I am one of those people who really believe in recycling.  (We really have become a “throw-away society” haven’t we?)  If I can modify or fix something to suit my use, why spend money to buy it new. (Especially since a lot of the “new and improved” versions of that equipment are probably of poorer quality anyway.)  Being in a wheelchair now, finding new tools that would work for me now would probably be both hard to find, and a lot more expensive anyway.
           Personally, I have found out the hard way that it seems that if someone is to be handicapped they should first be rich!  It seems that every piece of handicap aid equipment that you need starts out at about three grand.  My current manual wheelchair that I’ve had for about ten years now, for example, ran about $3,400.  Eventually I’ll be looking at some kind of power chair that comes in at two or three times that, not to mention some kind of conversion vehicle to accommodate it!
            But, all things considered, I still feel more fortunate than most of the other people like me with muscular dystrophy.  I just remind myself of the old saying “things may look bad now but then things could always be worse”, so just enjoy what you do have!
Share this post
Link to post
Share on other sites
Dave says: "Personally, I have found out the hard way that it seems that if someone is to be handicapped they should first be rich!  It seems that every piece of handicap aid equipment that you need starts out at about three grand.  "
My wife uses a left foot gas pedal on her car.  Has about $20 in parts, and maybe an hour assembly and another for installation.   The company charges around $500.  Turns out, a pile of that is "insurance" in case the manufacturer or installer get sued".   Seems to be that way with anything labled "handicapped". Hell if I understand why, though.
I like your attitude and the modifications.  Well done on all counts.
Share this post
Link to post
     Thanks for all the likes guys.  Like I said in the post, I hope that it shows others with disabilities that you may still be able accomplish quite abit even with them.  As Dirty Harry once said:  “you’ve just got to know your limitations”, then find a way around them.;)
      By the way, when I said that I know other people with MD that are worse off, some of that comes from having a younger brother who also has it.  He is 18 years younger, has the same variety (Beckers) of MD as me, and yet has already been confined to a power chair for about 15 years.  This disease is inherited and quite often in families having more than one sibling affected, the younger one gets it worse.  So, all I need to be reminded of how good I have it, is to think of him.
Share this post
Link to post
Dave,
Excellent post, it is easier to give up and vegetate, your a poster boy for one with severe injuries that has overcome and has not given up the ghost, I have had 6 back surgeries when I start feeling sorry for myself or get a little depressed I will come back to this post Kudos to one that has overcome.
Share this post
Link to post
Its not much but I manage. I have a shed out on the patio with a small workbench for my drill press chop saw and other power tools.
I also have to store a small part of the RC Fleet in here.
The green one is a CR-914 ready to sail when ever I want to go to the lake across the street and relax. The other is a Fairwind that is under construction hopefully ready for the summer season.
Share this post
Link to post
Art,
That's a very nice setup.
Having a smaller building area reduces the clutter....... something that doesn't apply to me.....:P
I see two of AL's Bluenose II kits..... are you to build a fishing version and a racing version?
Share this post
Link to post
Since I picked them up for really cheap and the fact that it will be my first real ship build I had planned on one to keep in reserve in case the first one winds up a mess. As far as the clutter goes it only looks that way because the Admiral insisted that we hold a stem to stern field day (spring cleaning) last week.
Share this post
Link to post
Thanks Richard.
They are all over the place in the RC Sailing world so while I did design that one i cannot take credit for the idea. I did do some dimensional drawings with parts lists in Auto Desk Inventor and would be more than happy to share them if you are interested in building one.
Regards
Edited by Osmosis
Share this post
Link to post
Because I need to clear some space in the Garage in order to be able to work on Maria over the winter I needed to move a couple of tools into the model shop, and it is already getting a bit crowded.
The first thing was to move the soldering area to the opposite corner to the left of the door.
I also took the opportunity to put some stabilizing wings onto the milling machine stand.
And you can see the two tools moved into the model shop which are basically metalworking tools and are not dust generators. the filing machine and I put the metal cut off saw onto a new wood stand, I never did like the flimsy metal one.
By moving the soldering station to the opposite wall I still needed to somehow take all the items that were stored under the rolling stand that the cutter was on before I put it onto the low one in the middle that allowed me to put the full mast up. One of the items stored under the cutter was my small home-built lathe which was on a large board. this was another opportunity to get sorted a job that has been hanging in the wings. I cut down the baseboard and remounted the motor off the back.
The only problem was that by flipping the motor mount around the motor was running in reverse, and it is a non reversing motor. Thinking about watchmakers lathes and how versatile they are and that they use round belts got me thinking about a solution.
by mounting the motor at an angle the belt is able to get crossed without touching itself at the crossover point which gives me now the option of forward and reverse by flipping the belt around.
Up in the other corner I mounted the second old drafting table on the wall and when it can be flipped down after the ship is gone I have a card cutting table.
And back over the soldering station I was able to mount the larger drafting table I had to cut it down to 48 inches wide because of some water damage while it was set against the wall of the garage due to melt water from the ice on the car over last winter. My parallel rule was only 48 inches wide so it was not that big a tragedy. I took the opportunity to replace the edge channels with some stainless angle that I had been hanging onto since 1969 I knew they would come in handy one day.
The board up and the flap hinges and catches on the top edge of the drawers below. the top of the rolling cabinet placed on top of the drawers created the handy set back for the flap.
and folded down ready to draw, I just need the green mat to loose the curl from being rolled up all winter.
It is amazing how these tasks accumulate until one need to deal with them. I am really looking forward to having the ship out of the shop because it is taking up a lot of room.
Michael
Share this post
Link to post
Michael following your model building is in itself inspiring. Following your workshop saga is mind blowing. You have put an incredible amount of work into tools and organization. Your investment in your shop re- build should pay many dividends to you in your work. We all could takea lesson from you.
Joe
Joe
Share this post
Link to post
Thanks Joe, in the real world I learn so much from people who frequent this forum, great Ideas that are shared and ways of accomplishing incredible work with simple jigs and tools. I remember as a young boy of thirteen visiting a chap near my home in England who built model boats and other stuff, he worked in an 8 foot x 4 foot garden shed workshop there was a bench on one side a drill press and a small bench attached to the side with the window. My childhood dream was to have a model workshop just like his. I feel very lucky to have what I have, and now the time to play with it all.
Michael
Share this post
Link to post
Wow Michael,
now that is some serious model you have here. Forget the workshop, you must have a huge sideboard in the house to be able to put it on!!
Seriously, have you some detail of the model? This is really impressive and I bet you're going to tell me that it's a self-build too!!
Regards
Share this post
Link to post
My work room is small enough normally but around Christmas it gets turned into a store room for all of the decoration boxes and also for hiding all of our grand daughters gifts. Here it is before the gifts were even in there.20181222_091800.thumb.jpg.e69edcb6472ff1591ad0a82e6aa0715e.jpg
So during the time of year I have the most time off I get to spend almost no time hobbying. The Corona is for my Son in law not my Grand Daughter.
Share this post
Link to post
My wife just makes me dismantle my work area and put it out of sight until all possibility of company has passed. I will get my space back, The far end of the dinning table, (that will seat eight) and we only normally only have four. Oh well at least I am allowed in the house..... Well sometimes anyway.:blink:
Share this post
Link to post
16 hours ago, Osmosis said:
I am not sure CDW. Is there an modelshipworldwivesclub forum out the I am not aware of.
Part of the fun in a marriage and a way we've stayed so happy together after all these years...I always let my wife take advantage of me. It's actually to my favor to do it this way.
Share this post
Link to post
Currently my work area is in the 3 rd bedroom, My desk is located in the closet. But starting in the spring I intend to fix up my shed which is an 8 x 12 foot outbuilding. It needs some new t-111 and new roof and electric added. Once that is completed I intend to  move the desk into it and add a workbench across the back.
Share this post
Link to post
My tiny workshop: 1,8 m x 3,6 m wall to wall.
Under the right hand table is a narrow shelf for power tools, brazing pit, propane bottle, chainsaw, and some other carpentry tools. On the floor are four big plastic bins for scrap wood, sanding and grinding materials and all kind of hoardings I tend to accumulate
Under the left hand table is composite post-curing oven fixed on the bottom of the table, and on the floor is my drill-press, bandsaw, disc&belt sander, welding transformer and mask, vacuum and air compressors, and three shorter and narrower shelves for model airplane engines, model airplane accessories, all kind of metal hardware and a box of million bits and pieces I may someday find useful.
Behind my back is all building materials, field equipment, car maintenance stuff etc.
Besides the main door just behind me on the right side wall are four big Preston cabinets for screws, bolts, nuts, washers, nails, knive & saw blades and other consumables, and a hanger for some gardening power tools, extension cables etc.
No free wall space left anywhere. But I still fit in to do my stuff, and that's all that matters.
Wife is not permitted to enter without close supervision.
Edited by MHo
Share this post
Link to post
I admire your organization and space utilization. Neat, clean, and professional.
Share this post
Link to post
I have an annex off the main log cabin we live in specifically built for the purpose. The heavy sanding etc. I do out in my woodshop. The good thing about the annex is I can leave everything just like it is, even when we have company :)
Edited by Wallace
Image added
Share this post
Link to post
16 hours ago, mtaylor said:
 bestthe idea of having a chainsaw in the model shop made me chuckle
Mark,
You missed the mark (pardon bad pun) the chainsaw is a tool of last resort. To be used when sending a build to the boneyard that did not turn out well.
A modelers outlet for frustration and revenge, and a mental feel good moment.
Probably scare the hell out of the wife (de ja vue the shining)
Mho that is the laid out and use of limited space I have seen Kudos:cheers:
Edited by John Allen
addition
Share this post
Link to post
    No registered users viewing this page.
The Guild is a non-profit educational organization whose mission is to provide support to our members in their efforts to raise the quality of their model shipcraft.
The Nautical Research Guild puts on ship modeling seminars, yearly conferences, and juried competitions. We publish books on ship modeling techniques as well as our world-renowned quarterly magazine, The Nautical Research Journal, whose pages are full of articles by master ship modelers who show you how they build those exquisite details on their models, and by maritime historians who show you what details to build.
Our Emblem
