Posts posted by James H
1:60 H.M.S. Beagle
OcCre
Catalogue # 12005
Available from Ages of Sail for $209.00USDHMS Beagle was a Cherokee-class 10-gun brig-sloop of the Royal Navy, one of more than 100 ships of this class. The vessel, constructed at a cost of £7,803 (£613,000 in today's currency), was launched on 11 May 1820 from the Woolwich Dockyard on the River Thames. In July of that year she took part in a fleet review celebrating the coronation of King George IV of the United Kingdom, and for that occasion is said to have been the first ship to sail completely under the old London Bridge. There was no immediate need for Beagle so she "lay in ordinary", moored afloat but without masts or rigging. She was then adapted as a survey barque and took part in three survey expeditions.
The second voyage of HMS Beagle is notable for carrying the recently graduated naturalist Charles Darwin around the world. While the survey work was carried out, Darwin travelled and researched geology, natural history and ethnology onshore. He gained fame by publishing his diary journal, best known as The Voyage of the Beagle, and his findings played a pivotal role in the formation of his scientific theories on evolution and natural selection.
The kit
Hot on the heels of their H.M.S. Terror kit, reviewed HERE, OcCre have hit the ground running with H.M.S. Beagle, of Charles Darwin fame. Both Terror and Beagle are of course well-known for very different reasons, and their familiarity shows OcCre not straying too much from that comfort zone. As with Terror, Beagle is packaged into a standard-type OcCre box with a cut out to display the nice fittings box that is a feature of these kits. A large, printed product label is affixed to the lid, and the kit itself is packaged in shrink film to protect it. For your information, the finished model’s dimensions are given as:- Length: 720 mm
- Width: 230 mm
- Height: 480 mm
Lifting the robust lid reveals a protective lower box through which you can see the instructions, and this box then splits open to access the contents. One half of the box holds three substantial bundles of very nicely cut timber, held together gently with elastic bands. The most obvious bundle is the lime, which is used for the first layer of hull planking. This creamy-looking material is super sharp with no fuzzy or split edges and is consistent in size.
Our next bundle holds all of the remaining strip wood of all persuasions and sizes. There is more lime here of course, but also the Tanganyika for the second layer of hull planking. Colour is consistent too. Lime is provided for the deck planking.
The last bundle contains both strip and dowel.
All of the remaining timber parts have been packaged onto a wrap of heat shrunk and sealed clear plastic. I do think this approach actually aids warpage as the boards have a curve induced in them due to the wrapping. Once the plastic is cut away and removed, we get to look at the false keel and assess it. This ply part does indeed have a warp along its length, so this will need to be steamed and left flat on a sheet of glass or similar.
There is no warp in the next sheet. This one contains the fo'c'sle deck, main deck, poop deck, transom, windlass mount and various interlocking structural elements. All laser cutting on this kit is excellent, with only minimal scorching.
This sheet is also, thankfully. Warp free, and it contains all of the hull bulkheads and bow profile parts. Three inserts are also included which fit perpendicularly to the false keel and provide mounting points for the masts.
We have a mixed bag with this sheet, with parts from all over the ship, plus elements to help build the four wooden launches/supply boats. Note parts here for the mast tops, trestletrees, cannon carriages, forward cannon rotating ring, channels etc.
As an aid to the modeller, the upper outside of the hull sides are produced as shaped ply parts, with the grain running short-ways to allow them to bend properly around the hull. These are cut with the cannon ports in situ, so there’s no awkward fumbling to try and locate the positions of these. The second planking will of course lay directly over these ply faces.
This sheet seems to deal solely with parts needed for those timber launches, and contains jigs, false keels and bulkheads.
Our last timber sheet is walnut-stained ply. Many parts on this are for the display base, but you’ll also find keep, stem and stern parts, as well as mast steps. My sample does have a slight warp in this sheet.
A single fret of bare brass photo-etch (PE) is included with this release, containing such parts as chainwales etc. Manufacturing quality is excellent with good parts definition and small tabs to remove the various elements.
If you like your models to be fitted out with sails, then you’ll be happy to know there are a full set included in this release. These already look a little antique in appearance and are quite neat. A little fuzziness can be seen on the edges in some places, but that is easily fixed with some trimming and dilute PVA. You will need to attach your own bolt ropes though.
There’s plenty of rigging cord included, in both natural and brown, of various sizes. All is neatly spooled with the diameters clearly given. Cord quality is also very good with no fuzziness being apparent.
All OcCre kits come with these snazzy fittings boxes which are well worth keeping even when the model is complete. They are a great way of keeping organised. Eleven compartments contain all kit fittings, plus four more spools of rigging cord that have been placed there to stop the metal fittings rolling around.
The metal parts are made from a zinc alloy (Zamak) which gives the parts are real nice definition, as can be seen from the gear teeth on the windlass. There are some slight seams to remove, and a jeweller’s file will do that nicely. Note that the anchor stocks are also cast in metal instead of made from wood and these just slip over the anchor stem. There are also davits here for the launches, and a whole rake of brass wire in different diameters.
A set of printed flags is also included.
All belaying pins, deadeyes and rigging blocks are manufactured from a pale wood (box?) and are not at all shabby. A few of the blocks may need a drill passing through them to make a totally clean exit hole.
The brass pins are fine, sharp and with no deformation. Quite happy with those. Here you see the parrel beads, closed heart blocks etc.
Here we can see the various pintles, gudgeons, chain, rigging pins, all made from brass.
As well as more blocks (this time single hole) and deadeyes, and more metal fittings, such as the cleats, figurehead, wheel, and strangely enough….the quarter galleries. An odd choice of material for a couple of things here, but they are manufactured with good definition.
The last items here are also zinc alloy. Thee cannon do look excellent. Just a few minor seams to tackle.
There are two sets of sheets that involve construction of Beagle. With the first, you see a series of drawings that concern the masting of the model, and there is also a comprehensive parts list.
For the second set of sheets, a series of clear, colour photos take you through the build. These are pretty self-explanatory and shouldn’t provide any problem. Some drawings are interspersed with the photos. Thee last pages are taken over by rigging and masting illustrations, and also a deck plan for reference.
Conclusion
You get quite a lot of kit for your money with H.M.S. Beagle, and most certainly a lot of good quality material. My only real gripe is the packing of the ply parts and the ply they are specifically made from as there is warpage present. I know some modellers aren’t keen on MDF for these parts, but it sure doesn’t warp. Maybe they’ll consider this in future. Apart from that, there’s nothing really to criticise for a kit of this level. It’s also good to see that instead of packing white metal launches into this, all are made as separate projects in their own right. The use of zinc-based metal parts also lends itself to a far sharper end result, although the very minor seams will just take a little more work with a jeweller’s file. OcCre continue with their tradition of providing colour-photo driven instructions with accompanying text sheets, and these seem very simple to follow. All in all, this is a kit which could well provide an in-road for a modeller who wants to try their hand at wooden ships, or even as a nice subject for a more seasoned modeller. Another very nice release from OcCre.My sincere thanks to OcCre for the kit reviewed here on Model Ship World. To buy this kit from Ages of Sail, click the link at the top of the article.
1 hour ago, Kevin said:
Is it going to be the one that MSW FB fb was reviewing
No, that was the FIRST one! 🤣
- chris watton, Canute and mtaylor
- 3
5 hours ago, Kevin said:
Would that save me money in importing one of his kits,
No excuse not to buy Avos now!
- mtaylor, Canute and chris watton
- 3
1:64 H.M. Cutter Alert 1777
Vanguard Models
Catalogue # VM-01
Available from Vanguard Models for £180The Alert, built in Dover by Henry Ladd and launched on 24th June 1777, was the largest class of cutter in the Royal Navy. Alert originally carried ten four-pounder carriage guns and six to twelve half-pounder swivel guns. She was one of fifteen cutters built for the Royal navy between 1777 and 1778. Smaller cutters were often purchased or built by private yards and then purchased by the Navy, but Alert was purpose built from the keel up.
In February 1778, Alert docked at Plymouth for an overhaul, to which some alterations were made to her hull and the ten four pounder carriage guns were replaced with twelve six pounder guns, raising her broadside weight by 30%. The guns were changed because six-pounder shot was more commonly available and, of course, they were more effective. Because of the increase in ordnance, the crew of the Alert was increased from sixty to eighty men, and recommissioned under a new commander, Lieutenant William George Fairfax. In May 1778, Fairfax was promoted to Commander and Alert was re-classed as a sloop to comply with Admiralty requirements. (Although always remained cutter rigged)
On 17th June 1778, the Alert, in company with the frigate Arethusa, spotted and intercepted the French frigate Belle Poule and the armed lugger Coureur, with the latter overhauled by the Alert and surrendered, returning to Spithead after the action with her prize. On 8th July of the same year, whilst on an independent deployment, searching for the enemy fleet, Alert was taken by surprise and captured by the French frigate Junon. Alert is reported as lost without trace on 15th December 1779. Alerts sister, Rattlesnake lasted a little longer, being wrecked on the island of Trinidad on 11th October 1781.
The model kit of the Alert is depicted after her refit with twelve six-pounder guns and a full complement of twelve half-pounder swivel guns, giving an ordnance total of twenty-four guns. Although not stated in the records when researching, it is possible that the upper bulwarks were fully planked, rather than having the open drift. The decoration that adorns the upper sides and stern is optional, as it is unlikely that the original vessel, when in service, would have had such decoration. This is inspired by the two paintings of the vessel by Joseph Marshall, which formed part of the George III collection of ship model paintings. It is possible the decoration would have been painted on during launch day, or if a prominent (Royal) figure visited to review the fleet.
The kit
H.M. Cutter Alert 1777 is the very first kit from Chris Watton’s own brand label, ‘Vanguard Models’. Of course, you will have heard of Chris’s name from kits released under the Amati (Victory Models) and Caldercraft/JoTika companies, as well as some magazine part-work stuff etc. I’ve bbeen watching this project come together both on and off Model Ship World, and the sort of effort that goes into producing a model kit. Vanguard’s new kit comes in a reasonably large box which is adorned with photos of the completed model, and some profile illustration too. Guess what? I got kit #001!! I’ll not claim any preferential treatment though! Lifting the lid and the first layer of bubble-wrap reveals a personalised customer letter and also a MASSIVE A3-size instruction manual which is spiral bound. We’ll look at this again a little later.
Fittings
A neat little labelled box contains all of the fittings for Alert, carefully kept in one place, and very professional-looking too. Cutting the tape tab reveals a series of labelled bags. Everything in this kit is also labelled in the same way and easily cross referenced against both the parts inventory and during construction. It really does appear to have been made as intuitive and easy to follow as humanly possible.
The fittings are generally a mix of either resin or white metal. In the first pack we have the large winch which is cast in resin. This was originally intended to be white metal, but the quality of the parts was poor, so a new part was 3D designed and cast in light grey resin. Only a little clean-up is required to push this into service on Alert. Also in resin is the smaller windlass for the topsail bitts. The anchors are cast in white metal, and these look great. Very little preparation will be needed before they can be used.
More white metal fittings are supplied for the twelve 6-pounder cannon and the twelve half-pounder swivel guns. I would give these a clean-up with a file and some steel wool. Another pouch is supplied for the cannon shot.
One of the next packs contain steel pins for assisting with the first layer of planking. These look very nicely made and are sharp, with nothing malformed. It could be an idea to pilot drill the plank before using these, so as not to split any of the MDF frames or the planks themselves. The next two packs contain deadeyes and deadeye sheaves. The quality of these is very good, and definitely some of the nicest I’ve seen recently.
Three more packets contain two sizes of single block and one size of double block. Again, quality is evident here.
In the last three packets in the fittings box, you’ll find triple blocks, parrel beads and also the mainstay ‘mouse’.
Rigging
A zip-lock wallet contains six spools of very high-quality rigging cord in natural and black colours, as well as a sleeve of thicker natural thread which I think is for the anchor cables. This latter is handmade by Syren in the US, so you can be assured of its standards. Also note how each spool is labelled and inventoried so you won’t accidentally use the wrong cord when rigging.
Timber strip
Onto the timber strip. This initial release of Alert contains boxwood for the deck planking and pearwood for the hull. This sort of timber isn’t normally found in kits, with the recent exception of Master Korabel’s Avos kit’s XS Edition. It certainly is very welcome to see, and the standard of timber is excellent. I do believe that Chris will be releasing a slightly cheaper version of Alert with Tanganyika instead of pearwood and boxwood. Chris hopes this will retail for around £155 and is actually the same as he used in the prototype model you can see on the box lid and the photos in this review. All timber strip is packed into thick, sealed plastic sleeves, and clearly labelled so you can cross reference with the inventory to make sure you are indeed using the correct wood for the specific task.
Timber standards are high with a nice uniform colour per batch, no coarse grain or split ends and fuzziness.
Sail cloth is supplied too, just in case you do indeed want to display in this manner. The material is provided as sheet, and you will need to use the drawings to draw out the shapes on the cloth and cut/sew. Sails aren’t really for me, but the option is there, should you want to display her in all her sheets to the wind glory!
Sheet material
Now we come to the sheet material. There are two thick, clear sleeves containing laser-cut material. This first sleeve holds all of the main constructional elements plus something rather unusual for a kit like this, and that’s a clear acrylic display base!
The base is a simple but attractive slot-together affair whose parts just need to be gently removed from the sheet. They are also covered in a protective film that makes it look dull in my photo. Rest assured that the material underneath is crystal clear. To assemble this, you could either use an acrylic cement such as Tensol, or an epoxy that will also dry clear. One such product that comes to mind is from HpH Models in the Czech Republic. You can of course use Cyano glue, but make sure it’s the odourless variety so it won’t cloud the clear plastic.
The constructional stuff here comes in two sheets of 3mm MDF and one sheet of 2mm timber, all nice and warp-free. On the MDF, you’ll find the false keel, bulkheads, inner and outer bow patterns, stern planking and securing patterns, and the ship’s stove flue. The timber sheet contains the lower deck pattern (constructional element), and stern frames (middle, inner, outer). Laser-cutting is nice and neat with almost no localised scorching. It wouldn’t really matter either way though as these parts will be either hidden or bevelled.
Our second sleeve of parts are all laser-cut from timber, with no MDF. Here, we have a combination of 3mm, 1.5mm and 1mm sheet material, containing parts for absolutely everything else timber-related on Alert, from gun carriages, hatch coamings, keep parts, cap rails, transom rails, tiller arm, trestle trees etc. You name it, it’s here. There are a few parts on the 1mm sheet which are hanging by only a few tabs due to the relative fragility of the tabs on a thin sheet, but all parts are perfectly fine. This material isn’t too rigid either, so those parts that need to be curved, such as the transom, will do so without any problem whatsoever.
Photo-etch
The inclusion of photo-etch in models these days is almost de rigueur, and Alert is no exception. Three frets are included in 0.2mm, 0,4mm, and 0.6mm bare brass, and all as good as any such material that I’ve used in any of my magazine and book work over the last 10yrs. As well as the obvious and intricate outer hull scrollwork embellishments, you’ll find metalwork here for the bowsprit and masting, cleats, windlass parts, stanchions, rudder gudgeon and pintle brace, eyebolt rings, deck grating, anchor ring, rigging components, and even a neat nameplate for the clear acrylic stand. All parts should be nice and easy to remove with them being held with thin, narrow tabs. A jeweller’s file will be needed to clean up any nibs remaining from the tabs.
Instruction book
This is epic in size! Printed in colour on thick paper stock in A3 size, the manual us spiral-bound instead of just being stapled. This means it will be easy to turn pages over, and the size is good for the eyes for those of us of whose youth has long since slipped away. The manual is 56 pages and begins with a side and upper elevation drawing of Alert, followed by a history and building tips/suggested tools and materials list. A full inventory is then supplied, along with images of the various sheets and PE frets. As the timber elements aren’t numbered on the sheets, you are advised to number each yourself before removal from the sheet.
Construction sequences are given in photographic form with crystal clear English explaining everything along the way. All illustrations are also clearly annotated where required. The photographs are interspersed with more drawings of the vessel in various profiles, clearly showing the task at hand. A good example of how comprehensive the instructions are is the inclusion of a deck plank showing the planking format and the shift between the planks.
When it comes to masting, drawings are supplied for this with accompanying dimensions and diameters. As I always find masting the most frustrating task, the drawings are a big help and clearly mark out the plan of attack. Excellent rigging illustrations are also supplied, showing everything clearly, including seizing, ratlines etc. A guide to exactly which rigging block to use is also provided. No guessing like on many of the legacy kits that got so many of us started in this hobby. As also mentioned, sail plans are supplied so you can make and add these from the cloth that’s provided.
Conclusion
What a great start to Chris’s new venture, Vanguard Models. He does keep telling me that he’s learnt so much from this that he will change in future releases, but he does sell himself short, dramatically. If you know of Chris’s work from his previous designs with Amati and Caldercraft, then you will know his own personal style comes through in attention to detail and design approach. This is a gorgeous kit that will present many hours of fulfilling bench time. Materials quality is what what we have come to expect from high-end kits. All in all, a fantastic package!My sincere thanks to Chris Watton for getting this out so quickly for me to feature as a review here on Model Ship World. To purchase directly, click this link at the top of the article.
25 minutes ago, SpyGlass said:
I just released Lord Cochrane for sale on behalf of Chris.
Hope the order/shipping process works - this one just goes by mail
I have one here and it is amazing!
I'll try too get some photos this weekend.
- Jorge Diaz O, Canute, paulsutcliffe and 1 other
- 4
Maybe there should be an Alert Group Build here if we get enough interested parties?
- Ryland Craze, Canute, Haliburton and 2 others
- 5
- chris watton, mtaylor, JeffT and 1 other
- 4
I should have a review and kit contents posted next week for you all.
- realworkingsailor, Rustyj, mtaylor and 7 others
- 10
12 minutes ago, Haliburton said:
Does anybody ever use solder for PE? I saw an article in finescalemodeller about using it. But it seems to me most just use the glue.
Sometimes, yes.
- Haliburton, Canute and CDW
- 3
5 hours ago, Ian B said:
Hi
Can someone point me to a suitable thread (I did try and find one!) or advise me as to some basic tools for cutting, bending etc P.E. I am hoping to embark on my first plastic ship with P.E enhancements and my main concern is cutting and shaping, I assume CE glue is OK for the actual sticking?
Sorry if this links sounds stupid.🤡
If you pop me your address via PM, I'll send you my 5.5inch Hold 'n Fold. I have two, so don't need another. It's not new but is perfectly ok. It's high quality machined aluminium and very precise. All I ask is postage.
- Canute, CDW, Landlubber Mike and 1 other
- 4
Amati 1:64 HMS Victory - LATEST NEWS
in Wood ship model kits
The ultimate Victory kit is the 1:64 unreleased Amati kit, designed by Chris Watton.
That thing is epic, and I'm trying to convince Amati to get off the fence and actually release it!
I'm sure @chris watton could give you more info...
