Peta_V
Posts posted by Peta_V
- yvesvidal, Edwardkenway, ccoyle and 14 others
- 17
Thank you very much for all reactions!
Preparation of the mast. It is carved from 6mm dovel. Not sure what kind of wood that is. Top mast, yards, boom, gaff are all in pear again. First I was sad that the main mast is not also in pear but now I like the light color. It will look good with contrast of other pear items.
3 minutes ago, DPK said:
Please pay attention, that the first variant was done in a way, mirrored from the one, presented in the drawings. You fastened the standing end not very close to the hilt. So obviously the fastening points on the bulwark have to be moved in this case. If done according to the drawings, no moving is required. Especially because the rudder rotation angle is not that great.
Hi, yes you are right. I did the mistake that the blocks on the tiller were fastened further from the end (that was the first version). I have corrected it and this is the final result (with hooks).
- Dutchman, JayCub, Galley Slave and 7 others
- 10
Adjustments of tiller tackles.
According to the scheme from Dirk I draw the lines to AVOS plans to see how much I need to move the bulwark double blocks. It turned out that not much which is great as it will not be in the way of latrine doors. I have take the tiller out of the model and made Iron belt with 2 eyes for tackle hooks
And the result (the coil will be replaced later)
- JayCub, lmagna, GrandpaPhil and 11 others
- 14
11 minutes ago, Dubz said:
Hi Dirk,
thanks for your comment. Looking at your picture it is clear that the tiller has to move around the circle which the setup from the kit will not allow! I had this section in mind for a long time. I plan to re-do it anyways. Use iron hooks instead of strap on the tiller (so the tackle can be easily removed) and also I will look at the possibility to move the bulwark block more aft.
- Dutchman, Fernando E, lmagna and 3 others
- 6
- Ryland Craze, JayCub, muratx and 10 others
- 13
- Gregory, Ryland Craze, Dubz and 10 others
- 13
- yvesvidal, Fernando E, Dutchman and 13 others
- 16
- Galley Slave, Elijah, JpR62 and 12 others
- 15
Thanks a lot guys! I'm trying to do my best. It is a lot of fun to build this kit!!!
- Beef Wellington, ccoyle, Gregory and 18 others
- 21
Thanks a lot guys, also for all the likes! Much appreciated. If I could make one person interested in ship modeling through my build I'd be more than happy! Having so many followers and reactions is really great motivation. Never thought I could cought so many people by building something what many now days people think didn't exists. Happy to be here in MSW! THANKS
- Ondras71, Elijah, Edwardkenway and 2 others
- 5
- Mirabell61, coxswain, Rudolf and 12 others
- 15
Second anchor + anchor tackles.
It still needs some final touches but first I need decide few things.
Running the anchor cable through windlass... I'm convinced I have it right (same as in plans) as windlass wind the anchor up rotating anti-clockwise and pawl in the bell bitt securing the spinning other way. But when "sinking" anchor is the cable still Running through windlass and spin with it? Were both anchors operated in one go? It does not make much sense to me how it is in plans. In this setup I do not see the way how to detach cable from windlass. PLEASE HELP!!
Plan
50 minutes ago, greenstone said:
Hello
This is russian gun of the end of the 18th century - the beginning of the 19th century, just for the tender "Avos"
Thank you Evgeny! Exactly what I need 👌
How is that breeching rope secured in the second picture?
- lmagna, Mirabell61 and Elijah
- 3
AVOS by Peta_V - FINISHED - Master Korabel - scale 1/72 (exclusive kit) - Russian tender
Not much new to show. I'm preparing yards. Lot of sanding and lot of mess.
