GuntherMT
Everything posted by GuntherMT
  1. I got this from Amazon for $6.00 - http://www.amazon.com/gp/product/B0006HVRPO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 It's an X-Acto soft countoured handle and it has the single-slot blade grip instead of the X type. It's also got a raised spot on the handle to keep it from rolling off the desk.
  2. Ah, that's good stuff to know if I ever want to try a trick like you did there. Thanks!
  3. Nice job on the boat Ken. Look forward to seeing your work on the Rattlesnake!
  4. Gorgeous work Keith. Curiosity though - why did you point out 'not Titebond' as far as glue, is there an issue with Titebond?
  5. Nicely done John. Your log is making me look forward to seeing the real CW Morgan next October at the conference!
  6. Hi Dave, I'm pretty new to this hobby, but one of the first 'aftermarket' decisions I made was rigging line. I throw out the kit rigging line and get line from Syren. At some point in the future I may go down the road of making my own, but for the time being, I'll let Chuck make superb line and just buy it from him.
  7. Sorry to see you are stopping the log, I've enjoyed following along on a build that is very different from my own. Best of luck to you, and hope to see is completed at some point.
  8. Thanks for your encouragement and likes folks. Puttering along with the deck planking now, the custom shaped planks alongside the hatches are pretty slow going, especially since I've had to remake 2 of the 3 along the way, but I think the end results will be worth it, I'm really liking it so far, and this holly is just wonderful to work with, it just blows basswood away, even ignoring the 'looks' part. I think I'm going to place the margin planks very soon, instead of waiting until after the deck planks are in, as I've decided to go with hook & scarf planking into the margin, instead of nibbing, as that wasn't prevalent in ship building until 40 or more years after the date of this ship (see discussion on nibbing in the planking sub-forum). Since hook & scarf deck planks don't require the margin plank to be cut into, I think it will be easier to get a neat mating to it with the deck planks if it's in place first. Thoughts on that?
  9. Thank you all for the suggestion, tips, and likes! So I decided that the advice to go with the outside border on the grating was the way to do it, so I simply abandoned the measurements from the plans, and winged it (shocking, I know)! Instead of measuring anything, I first cut the pieces and built a new grating. I had barely enough grating material left to make one long and one short piece after this, so I figured that it had better work out! I assembled the new grating on some reversed masking tape to hole it together for assembly and gluing. After finishing the grating and gluing it together with fast CA, to make the coaming I simply used the grating itself to mark the length of the two 'inside' ends, and cut them. I then glued them to the grating, and after letting the glue set, I sanded the exposed ends until they were perfectly flat with the grating edge. I then used the new assembly to measure the wood for the 'outside' pieces of the coaming, and glued them to the grating assembly. I then beveled and sanded the entire new assembly, and then checked the measurement on deck. It was slightly larger than the original galley hatch, so I used a chisel and carefully trimmed back the already glued deck planking, filed the new edge flat with a riffler file, and then trimmed the final bit needed off of the single plank on the other side until it was a snug fit. I then slapped on a coat of poly, and ta-da! Here is the new galley hatch sitting in it's future home. Mission success!
  10. Sorry, but I'm not familiar with this model (I'm only now working on my 2nd model myself), so I really don't know.
  11. Be careful trying to match the tops of your bulkheads to the outside lines on those plans, as the plans you have pictured are from above looking down on the deck, and the width of the ship will continue to widen above the top of your bulkheads and deck into the bulwarks (framing above the deck). From the upper left photo, it appears that the bulkheads actually match very closely with the deck level on the plans. It's hard to tell on the stern, since the model overlaid on the plans is covering it up because of the reinforcement blocks, so I can't really tell where the deck edge is under it.
  12. So I figured out what is wrong with the galley hatch. It isn't the grating, it's the coaming itself - it is ever so slightly out of square, and I'm not sure why. Measured from 2 corners it's square, but from the other two it's not. I messed up a tiny bit somewhere, but it's enough that my eyeball catches it as being 'off'. As a result, the planking won't match up correctly unless I fix it, so the next order of business will be making a new galley hatch tomorrow night. I don't think I can make it with the grating having the outside edges like Frank suggests, as the grating material isn't the right dimension for it (works great across the short side, but doesn't work across the long side). I would have to go off-size on the plans to make that work, so I'm not sure I'm going to try. I'll take a fresh look at it tomorrow before I remake it to decide. I can't really explain why, but I really do enjoy doing the deck planking. It's going well so far, and I'm not going per-plan at all, rather I'm sort of emulating stuff I've seen in various builds here. We'll see how it works out long term, but I like the first little bit. The hatches are not glued, they are just being used to the planking fitment, which is why I need to remake the galley hatch now, because I need it to be right before going any further with the deck planking.
  13. Glad they came through for you with the deadeyes John. Going to be finished in no time!
  14. I have this kit on the shelf, so I'm happy to see someone else starting on it and will be following along. For fairing, I'd suggest adding bulkhead reinforcement so that there is less chance of breaking a bulkhead, but I'm sort of hamfisted, so you may be fine without that if you have a lighter touch. You can see the sort of reinforcement I'm talking about in my AVS lod, there is an index in the first post. I'm on my phone or I'd just give you a link. There are some great guides on fairing as part of some of the planting tutorials which you can find in a sticky post at the top of the planking subforum. Good luck!
  15. Thanks Frank, it will be a while before it gets glued down, and no real reason I'd need to glue it until the end really if I wanted to leave it loose. Thanks.
  16. Thanks gents, for the comments and likes. I made the galley hatch, but it looks.. off. I'm not sure what it is, the measurements are all good, and it's square according to my square, but it's off to my eye. I may remake it. In the meantime, I put everything on the deck together just to see it, not glued obviously and not even in exactly the right spots, but just for the visual. Need to put a coat of poly on the hatch still, but waiting for the glue to dry since the grating is a bit touchy. In the meantime, I can start working on figuring out the deck planking. Woo!
  17. So I have no idea why I thought I'd be going faster once I got to the deck furniture, because this is all new to me, so I screw up and have to remake lots of parts, but I'm learning, and am reasonably happy with the final results. This morning, after working on this all day yesterday (and having started it by making the base some days ago), I completed the companionway. Looking at everyone elses build logs, this little structure seemed neat, but nothing all that complicated, but after completing it, I counted, and there are 73 individual parts in this dumb little thing! Today I hope to get the final hatch completed, and maybe start on the deck planking, which I've really been looking forward to!
  18. Ben Lankford's name is on the plans & instructions for the Armed Virginia Sloop & Pride of Baltimore II by Model Shipways, as well as the Niagara. He also is named for revisions to the instructions on the Fair American by MS, but not the plans.
  19. Looking great! Sorry to hear about your CS issues with MS. I'm one of those guys who has had nothing but excellent support from them, so no idea what the problem is in your case. It's a bummer though.
  20. Looking great! If you don't mind sharing, where did you source the decals?
