davyboy
Posts posted by davyboy
Lovely job on the Q' Deck bulkhead Chuck. I spent quite a number of hours and bad language making mine for my POB Speedwell.
I built mine in 3 separate sections on a piece of 1/64th ply,looks pretty good but not in your league unfortunately. Several dozen
separate items were needed to accomplish this.
Dave
HI brunnels,
I have a pack of identical looking blades which I inherited about 20 years ago. They are called Balsa hobel klingen (plane blades) manufactured by a German firm called Martor in Solingen. I've only ever used them for scraping decks etc,they're good steel and hold an edge. I suspect your blades are likely a product of the PRC.
Dave
Very nice Job on the square tuck fashion pieces Mike,not the easiest items to make. I wasn't happy with my first (stbd) one,binned it and had no problem with them after,a lesson learned I'll bet yours are just as good as the computer generated laser cut versions with the added satisfaction that you made them yourself.
Dave
- Ryland Craze, FrankWouts and mtaylor
- 3
20 minutes ago, tom q vaxy said:
so .... if Byrnes fails to open, take it off the table for now, is there a #2 saw that will perform? not perfectly, universal opinion points to the seemingly unobtainium for the immediate, but adequate no one will have angina over using it?
is Proxon or Micro-Mark acceptable if talked about in hushed voices? i find it hard to believe the future of the hobby clings on one man's hiatus.
Hi,
There is nothing wrong with the Proxxon FET saw whatsoever. I have had one for several years which does excellent work with no problems,I really like the fact you can tilt the blade for angled cuts. Something which the Byrnes saw cannot do as far as I´m aware. I can´t speak for Micro Mark,however I´ve heard their saw may be a Chinese made copy of the Proxxon saw. I´m fairly certain´that Mr Byrnes business will be open again soon. Patience is a virtue
Dave
- mtaylor, Gregory, tom q vaxy and 2 others
- 5
7 hours ago, Ferrus Manus said:
How would you possibly be able to construct a shell-first carvel-built ship? At least with clinker-built ships, the overlap of the planks provides a general direction for where the planks should go.
7 hours ago, Ferrus Manus said:How would you possibly be able to construct a shell-first carvel-built ship? At least with clinker-built ships, the overlap of the planks provides a general direction for where the planks should go.
It was done by the Dutch on a regular basis. There was a build by a Belgian (?) member doing it this way on MSW 1 back in the day.. There is also currently a build doing this in the Ships of Scale forum successfully it would appear.
Dave
- Ferrus Manus, Canute and mtaylor
- 3
Hi Turil,
Cornwall model boats sell Model Shipways kits. They appear to have a good selection on their website,and also have a very large selection of Ship/Boat modelling items and tools . I have been buying items from them for years,they have excellent and fast service. My last order took only 5 days from ordering to arriving in my Briefkasten in Switzerland. Postal cost is about 20% of what the American post charges. Please dont waste your money on items like you have underlined. Welcome on board to MSW.
Dave
- Keith Black, Turil and mtaylor
- 3
On 9/27/2023 at 2:36 PM, Jaager said:
Siggi,
I regret that you have perceived my interpretation of the stern as being any sort of order. My intent is to challenge you to verify your plan if it is less complicated.
Planting a seed of doubt about preconceived plans is the goal. Better now, than after it has been constructed. Subtleties of tone obviously do not survive either in written form or after translation.
I will do my best to bite my tongue from now on. Fair winds and calm seas going forth.
Jaager
Give it a rest,Siggi knows what he is doing by following the original draft of HMS Tiger. He doesn't need your sniping about trivia.
Dave
Thank you for the explanation Maurice,a kit modification,makes sense I guess. Epoxy will be a must then when fitting guns through the ports. The words "tweak matters"intrigue me. I'm fitting Speedwells' guns just now,5 port guns fitted and pinned to deck,stbd 5 in progress. No guns being fitted in ports #3. Twice I've knocked off the break (sp) pumps trying to fit guns there,end of story empty ports.
Rgds,
Dave
Hi Maurice,looking very good indeed. A question if I may,what is the purpose of the wedge shaped item behind the trunnions ? I have never seen anything like that before in any pix or drawings. A cap square it is not.
Dave
Hi Nix,
I can confirm what Allan says. However although it's of little or any value it's a nice example and certainly worth keeping.
Dave
- Nix, mtaylor and Keith Black
- 3
Hi Maurice,
A delight to see this which is so much better looking and far more authentic than 4 rows of straight planks.
Dave
- mtaylor and Blue Ensign
- 1
- 1
Hi Dave,
There is a company called Metal Clay Ltd in Wareham who sell some miniature carving tools, I bought a set of 1.5mm Dockyard Tools from them last year,good quality mini carvers. Google them,I'm sure you may find what you need,they are also a bit cheaper than Flexcut. Both of which are American imports. Happy hunting.
Dave
- mtaylor, thibaultron, Keith Black and 4 others
- 6
- 1
Great news about the sweep port lid hinges. Speedwell at 1:48th has sweep ports 3/16"x 1/8th". I'll be keeping a weather eye open for when the size I need is available.
Dave
- thibaultron, Nirvana, Chuck and 2 others
- 5
Hi Kevin,
Your recovery paint job looks tip-top. Such a shame you had to do that on Boxwood. I would have removed the damaged planks and redone that area. I had a problem when planking the upper hull on my Speedwell build. I was in the middle of the 6th row of the Stbd strakes when I realised all was not well,a couple of wrong measurements😢. Hey Ho,I ripped the Boxwood (Buxus Sempevirens) off both sides plus I damaged the Stbd upper wale so that was ripped off too. **** happens,a months work in the bin. Lesson learned,pay more attention.
Dave
- Kevin, Ryland Craze, mtaylor and 3 others
- 6
Lovely result with your hand carving Kortes. More satisfying for you than having a computer driven machine making them for you then just glueing the bits on I wish I had your skill,I am struggling a bit attempting to do the carvings on my Speedwell build.
Dave
Steven,Great Harry looks absolutely tip-top. You must have the patience of a saint to have accomplished this. Respect
Dave
- Keith Black, mtaylor, Louie da fly and 2 others
- 4
- 1
Sloop Speedwell 1752 by Rustyj - Syren Ship Model Company - 1:32 Scale - POF Sloop
Great,another Speedwell build for me to enjoy following. My scratch 1:48 scale POB version from David Antscherl's plans started around 5 years ago will hopefully be completed later this year. Another kit success story from Chuck's stable.
Dave
