davyboy
Posts posted by davyboy
Hi Allan,I used Eddings 3000 black permanent marker on the wales of my current build. It is waterproof,doesn't fade and doesn't rub off when dry. The wales have been on the hull about 1 year,despite much handling of the model they look as good as when first dyed.
Dave.
- Mark P, Keith Black, Gregory and 3 others
- 6
Hi Cliff, R. C. Andersons' books Seventeenth Century Rigging and The Rigging of Ships in the days of the Spritsail Topmast 1600-1720 will have I'm sure info pertinent to your search. Both books are for sale on Abebooks and cheap. While there are no rigging plans per se there is much info to be found in them.
BTW,there is a rigging plan in the 17th Century book but it's for the 96 gun St George of 1701 later than the SoS but may still be of some help to you.
Dave
Have you tried heatshrink ? Blue Ensign uses it to great effect. Easy enough to drill a hole into it and glue in an eyebolt.
Dave
- niwotwill, mtaylor, Keith Black and 2 others
- 5
Interesting,but why not make your own zero clearance inserts ? I have the Proxxon FET saw,I made my own zero clearance inserts from aluminium strip which is cheap enough. Cut to size and drill and countersink fixing screwholes,fit and slowly raise the blade. Bingo,you have an insert for every sawblade. JMO,but I think it would be a little dangerous using tape for this purpose.
Dave
- thibaultron, TBlack and allanyed
- 3
When I planked the main deck of my POB model of Speedwell I had already made the various hatch and grating coamings,also the mast partners. These were pinned in their correct positions,I then planked from the centre outwards following the planking pattern on David Antscherl's plan. This ensured a very good fit of the planks. They were then removed to allow sanding/scraping of the deck planks. Looks good to me,nothing looks worse than deck fittings sitting on top of the planking.
Dave
- bruce d, Roger Pellett, mtaylor and 2 others
- 5
17 hours ago, Roger Pellett said:
I doubt if Bob has much control over how his books are shipped. I suspect that he provides whoever warehouses his books with the buyers shipping information and they take it from there.
Roger
He does.
If you would like the phone number of his warehouse/shipping depot PM me. The ladies there are very helpful and will give you info and a tracking number.
Dave.
The book has now gone.
Dave
- ferretmary1, mtaylor, GuntherMT and 1 other
- 4
I received the wrong book when I ordered The Ketch rigged Sloop Speedwell volume 2 from Seawatch being sent instead volume 1. I have no use for this book having volume1 already and they don't want it returned. Anyone who is interested in acquiring Speedwell volume 1 c/w plans send me a PM.
I only ask that the recipient pays the value of my postage from Switzerland in US dollars and donates it to the MSW Forum funds.
Thanks,
Dave
Hi there,
A normal hair drier or variable temperature hot air gun will do the job perfectly well. No need for hot water at all.
Dave.
- J11, thibaultron, Bob Cleek and 3 others
- 6
Kurt,
In that case can you explain why the (wrong) book that was sent one month after my order in October only took 11 days to get from the USA to Switzerland. Posted 20/11/20 arrived in my postbox 1/12/20. No 90 day delay in the post there. Just the usual excuses given out.
Incidently,any ideas why it takes over a month for a (wrong) book to be sent after order and payment in October.
Dave.
- thibaultron, Jorge Diaz O and Canute
- 2
- 1
Hi Jorge,
Luckily,at least you have some of your order,I'm very happy for you. I'm still waiting for the replacement book volume 2 of Speedwell which I was told was being sent one month ago. Original order made 3 months ago. Never known of such poor customer service anywhere. Far too many excuses are made for this company.
Dave.
- 2
- 1
Hi Druxey,
A replacement would be sent if you could contact him in the first place on the contact details on his website. If I hadn't called the number on the paperwork that came with the wrong book I'd probably still be trying to get a reply from him. A very pleasant lady at his shipper sorted out my problem at once,the correct book is in the post to me. I'd also like to know why it took over a month from him receiving an order and payment (in my case) to a book being sent. Incidently,it only took 10 days for the wrong book to come from Missouri to Switzerland (20th Nov to 1st Dec). Can't blame the US Postal service at all.
Re my post on the 13th Dec,two members PM'd me. I PM'd them the phone number and their problems were sorted out,one of them I know was also given a tracking number,says it all. They can provide tracking numbers.
Dave.
- WalrusGuy, toms10, Jorge Diaz O and 1 other
- 4
Good evening Maurice,
Another beautiful model from your shipyard I look forward to following your next build. Best wishes for next year.
Dave
- BobG, Martin W, Blue Ensign and 1 other
- 4
Hi Greg,it's a waste of time doing that or telephoning the number there. I tried contacting him about the wrong book being sent,no replies. Found the number of his Blue Springs MO department on the paperwork that came with the book. Called and a very pleasant lady sorted my problem out straight away. Correct order on its way.
Dave
Hi ASirWnt2C,
According to Lavery in his book the Arming and Fitting of English Ships of War breechings were 3 times the length of the Gun Barrel. However,this is for English Ships but I suspect US Warships were similar if not the same .
Dave
- wefalck, mtaylor and thibaultron
- 3
Hi Allen,top of this page,planking tutorials etc. All you wish to know is there. Normally the Wales are fitted first.
Dave
5 hours ago, RussR said:
I have a Proxxon FKS/E saw (with 10mm arbor) with several carbide tipped blades like the third one pictured. The problem with these blades is if you are cutting 1.5mm planks, over half of your material is going to end up in your vacuum cleaner.
What blade does everyone recommend for cutting planks?
RussR
Hi RussR,the Proxxon 50mm blade #28020 has 100 teeth and is 0,5mm thick. It will do the job perfectly,I use one for plank cutting everytime.
Dave
Hi Mark,I've been following your build since you started.Exemplary carpentry and dedication indeed. A little fix you may find useful when drilling hawse holes. Drill about 2/3 of the diameter required then open out the holes using a tapered reamer of the req size then ream from the other end.Then run a straight reamer through to remove the slight constriction in the holes centre. You wont get any tearout and really smooth hawse holes,no filing marks. Just a thought,anyway it worked for me.
Dave
Good evening Maurice,exemplary work from you. Kit bashing is certainly your forte. Just a thought but I'm a bit surprised that you didn't think of using braided steel wire as used for fishing traces for your tyes. It comes in various sizes/diameters relative to breaking strain and is quite flexible. Looking fwd to following your next little masterpiece. Regards,
Dave
Flags supplied by Amati look to be too big
in Masting, rigging and sails
Posted · Edited by davyboy
Hi Dave,
www.becc.co.uk You may be lucky and find the sizes you require there. I think cornwall model boats also sell becc flags.
Happy hunting,
Dave
