maltbyguy
Posts posted by maltbyguy
i agree with the Proxxon I use it to turn all my spars ideal tool to start out with
Andy
Hi Tom I have the same problem a Billings kit and Coral fittings that was my thought how to paint the "brass" fittings
I even soaked them in paint stripper to see if I could get rid of the coating but it didn't touch it
Andy
Hi sorry I haven't posted for a while but as I have said before I am a model builder not a photographer !
I have been finishing the deck fittings and the rigging
The deck houses were built up as per the plan re enforcing the corners with some scrap I never like to see bare plywood so I cut off the overhang and made a frame from some walnut from the scrap box. the doors were made up and painted and dummy hinges fitted
not really much rigging to do so a couple of pictures cover most things
The anchors were missing so they will have to wait until I can find some of the right size
next project ????
Hi I am just starting my build a bit of an odd one a billings kit but coral fittings
What paint did you use to paint the gilded items they seem very shiny to let the paint stick.I did think of stripping them but either my paint stripper is old or they can't be taken back to the base metal
Thanks Andy
I decided to paint inner bulwarks probably not strictly correct but as I have said before I am no a "rivet counter" I make my models for the enjoyment of the hobby and to make something that is pleasing to look at
Masts were tapered on my Proxxon lathe I like their products this small lathe is ideal for mast and spar making
Its amazing how much better a model looks with masts fitted even if its a temp dry fit
Andy
1st planking and 2nd planking both finished but I didn't read the instructions correctly so planked all of the hull in walnut the top 4 planks should have been in the lighter colour
Deck and inner bulwarks have all been planked in the lighter timber I am not sure what it is but it seems impossible to sand it clean so I decided to leave it slightly dirty and say it adds character to the deck
Hi all I am still trying to work out my next major project I still want to build a POF model rather than the usual POB kits that I buy. I was browsing through E bay and found a part built Swift kit and thought it would make a good quick filer I put a £50 bid in it and won it for £45 !! bargain
The kit arrived safely but the previous builder had made a bit of a mess the main bulkhead was bent the mast supports were in the wrong place but nothing ventured nothing gained so I broke the backbone in two added more supports and glued back together
Next job was the deck this has quite a camber to it so loads of string and clamping methods were needed to get it to sit on the bulkheads correctly
The 1st planking was so poor in quality I think it was just pine that it broke at the slightest bend so that made some nice paint stirrers ! and I used some pieces of walnut I had in stock I know it seems a shame to use it and then cover it up but when needs must
- Piet, DavidM, MarisStella.hr and 1 other
- 4
Thanks Mike I will take a look at them
I am also looking at Model Shipways Syren but the $100 post charge puts me off
I am hoping Chuck will eventually get his HMS Winchelsea kit up and running
Andy
Yes Mike I like caldercraft I have already finished Agamemnon and mars
I fancy an admarlry style plank on frame but kits seen to be non existent here in the UK
And as I said being a backroom builder with neighbors all the noise scratch build might causeproblems
Andy Griffith
Thanks for the encouragement
I am not sure about the next project Mike I fancy a pof model but not sure if I have the talent to do it justice I also am a back room modeler so all the sanding and sawing wouldn't go down well with the neighbors
Any ideas ??
- GrandpaPhil, hexnut and DavidM
- 3
Thanks for the information Jeff
Maybe there's a business opportunity for someone to start producing Bob's kits again ?
thanks for the information blue jacket
Unfortunately they seem to be another U.S. company that don't reply to my e mail
Has anyone had dealings with the royal shipyard plymouth ? They list several kits but don't seem to reply either
Is it just me :’-(
Hi
Thanks for all your suggestions
I have tried the lumberyard and Plymouthships but neither have replied yet maybe they are both having a bad day
Scroll saw is a good idea for cutting out the frames maybe I shall have to invest in one I already have proxxon bench saw and band saw so an e mail to Germany seems best way to go
Hi
having built several plank on bulkhead kits I would now like to build a plank on frame kit something along the lines of hms victory navyboard style
my problem is I don't have any method to mill or cut out the parts I live in a flat and the noise wouldn't be very friendly to others living in the block
does anyone know of a kit manufacturer hopefully in the uk that could help
Thanks
Andy
Just a thought
When I asked Jotika why their Nelson series were all in 1/64 but victory was 1/72 they said they had plans to do a 1/64 kit but the carriers said it would be too heavy to economically send, hence the 1/72 kit
I wonder if anyone at Amati has thought of this?
thanks for the comments Patrick
I know how helpful all can be on the site I have found this and the mark1 version to be of great help
I just hope that my work can do justice to the excellent models shown
Any and all even the foam safe non oder types
Spent a fortune trying different types
Humidifier in the room helps but doesn't cure
Hi has anyone found a cure to CA allergy?
I only have to use for a couple of minutes and I suffer for the next 2 days
plank length
in Click Here for Topics dedicated to planking!!!!
hi all
I am sure I have seen a table somewhere that gives an idea of deck plank length against model scale
I have been searching for it but can't find it maybe it was in the earlier site
I am building a 1/75 Vasa any ideas as to the plank length would be helpful I am planking the deck rather than the printed deck supplied
Thanks
Andy
