Posts posted by Ferit
Hi,
Thank you for your visits, comments and likes.
I decided to fix some blocks to the bowsprit mast.
I have to smulate rope wrapping. With a 4 mm block it's to difficult to bind a block to the mast as in the real ship...
I post some photos showing how I try something...
For the first block it' s done with success...
- popeye the sailor, mtaylor, NMBROOK and 1 other
- 4
maybe dragged onto the beach it's used to fix the poop, preventing it from swinging in waves...
Scratch hook is much better Denis.
- Piet and popeye the sailor
- 2
- popeye the sailor, mtaylor, zappto and 8 others
- 11
A would be toe logical choice
A was the subject... My English language?!... (sorry)
4 minutes ago, popeye the sailor said:
A would be toe logical choice........the part in the back is a knee.
Hi Denis, you mean -a-
Isn't it?
Hi,
Being sick of doing the same repetitive action, rigging ratlines, I want to touch the wood... Building the crow nest of the bowspirit
The kit offers a block (black area). I don't want to use the block, I think it must be build in two parts. But I don't know which solution is correct.
(a) or (b)?
I need help. (as if -a- chic makes more sense)
Thank you.
I am amazed by seeing this transformation in all models...
- Piet, popeye the sailor and Omega1234
- 3
Actually, I wanted to express the final appearance of the shrouds that the rules of physics obliged more than the working principle of all that rigging system as wefalck says at his last topic; "Given their size and weight, it would be impossible to put so much tension on them that they were completely straight. There is always a slight catenary in them."
At every look Michael, I notice an another new detail. IMO you too did not even think at the beginning you would end up this build with so much and nice details, presenting a reference document... Wonderful!...
IMO,
A thick rope has heavy weight and that weight causes the shroud to hang due to gravity. The problem is at the first shroud (the closest to the mast). It must also have a sag but as same direction of the farthermost shroud (not like a hour glass). Actually full straight shrouds lines are not realistic.
And ratlines also have to sag due to gravity and after many usage from the crew...
- mtaylor, EJ_L, thibaultron and 1 other
- 4
I found a post about rigging ratlines. Very good option for rigging a ratline to the first and last shroud....
https://modelshipworld.com/uploads/monthly_03_2013/post-1141-0-90127500-1363268395.jpg
But I'm late for that... I have done many knots as Corel plans show... (Too hard!)
Many thanks for your kind words and support, OC, Hamilton and Mike and for all likes...
I want to make my own stern lantern, I don't like kit casting example.
I am confused about whether it was made of wood or metal at Berlin's period 1674.
I looked at some examples via web but some of them were made of metal and some worked as wood.
I will thankful for the answers.
Hi Mike,
Another Euromodel kit, another good choice...
Another beautiful ship.
- Landlubber Mike, robdurant, mtaylor and 2 others
- 5
Fine work on the painting after a fine work on the planking the hull...
IMO although painting the ship makes her accurate, nice and more attractive, it is a bit sad because it closes the all wood workmanship. A contradiction?
But knowing what is under the paint layers is a consolation, a respect to the memory of all that labor on the wood.
And you and us know that...
- NMBROOK, Landlubber Mike, Barbossa and 8 others
- 11
How does she flourished suddenly?!
High level work...
- Old Collingwood and zappto
- 2
Frigate Berlin by Ferit KUTLU - Corel - 1/40 - 1674
