Posts posted by EJ_L
Excellent idea to carve the trim along the edge of a flat piece rather than try to make actual molding strips to install. I tend to try to apply normal construction techniques to these models which is extremely difficult and often times I end up with sub-par results. I'm going to have to remember this idea.
This sounds like how my last model railroad layout went. Wife allowed me to start with a simple 4x8 sheet of plywood and a simple oval track. Over the following 10 years, it grew into a horseshoe shape covering the entire 14 x 24 basement room until we moved. She is being much more cautious on what she approves for my new train layout. 🤣
Looking forward to seeing this evolve as I love dioramas and I think you have a good plan to get started. I would suggest that besides raising the entire land area the inch for the water beds, you slope the entire land area from the castle to the water, to give a more noticeable elevation change and most castle would be built upon higher land than the surrounding village.
- lmagna, Edwardkenway, Waitoa and 6 others
- 9
This looks like great fun! May have to look into getting myself a kit.
- Egilman, Waitoa, popeye the sailor and 4 others
- 7
The lower cabins are looking great. I love seeing interiors being built on these ships. Too often they are omitted and overlooked as they are rarely able to be seen once the ship is built. To me this is a tragedy as the interiors are an entire world of fascinating detail that really show how life was aboard a ship.
Also, the "wife's request" looks very intriguing! I would definitely be interested in seeing a log for it.
- yvesvidal, Old Collingwood, mtaylor and 1 other
- 4
Fantastic model and what a wonderful display! Great job!!
- Louie da fly, mtaylor, J11 and 1 other
- 4
My father has similar issues with his plastic Connie kit. The plastic has become so brittle that he has been forced to abandon much of the original in favor of custom made or extras that I had laying about.
Well done for powering onward and recovering. She has become a fantastic build, and so close to finishing.
I was curios as to how you were cutting all those curved lines, scroll saw, knife, etc... while I have done the "hundred hole" method, usually on inside curves and extremely tight radii, that would not have been my first guess. With as tiny of details as you are working, that may be the smart way though, and I certainly can't argue with the results.
- shipman, mtaylor, Hubac's Historian and 1 other
- 4
Quick update, the hull is fully planked! Just applied the clear coat and now waiting for the ship to dry. In the meanwhile I can give the shipyard a much needed cleaning. Now to start working on details, furniture, trim and decorations. I will add some better pictures once she is dry and I can move her to a better lit area.
- rybakov, Hubac's Historian, J11 and 10 others
- 13
Ah! No, that they did not provide. My S.R. kit did come with some made of metal, but they looked terrible in my opinion so they were tossed to the scrap pile. I had not given much thought to making those transitions decorative, just plain walnut at the moment. Might be worth reevaluating though.
I'm not completely sure which pieces you are referring to Marc. Can you point to them on a picture or where they go? I have a lot of fittings so it is likely that the kit did come with them.
I will say in regard to the fittings/furnishings/decorations etc., that the kit provided pieces are of decent quality. For someone not looking to make their own, these can be easily cleaned up, painted and used to create a very pleasant model. The biggest issue with them are the ones such as window frames and the decorative railings. Their appearance is fine, the railings are actually quite nice, however they were cast straight. While the metal is soft enough that it can be bent to proper contours, it also breaks easily and since it is so soft, it is easy to mar the designed with pliers or clamps if extra caution is not taken.
My other piece of warning on them is pay attention to how they fit as you are building. Especially the stern windows and the decorative arched transom pieces. Part of my problems stem from the fact that I modified my stern to allow for interior cabin spaces which has change the designed shape enough that the frames do not fit properly. Even if I had not done so, I think there would likely be some issues with how they fit if care is not taken while building.
Most of these I will only be using for reference or place holders for dimensions as I intend to do my own carvings and detail work. A couple of others though I am using in limited capacity. The ships wheel is one that I decided to use. The cast metal wheel assembly is fairly nice and since the wheel is nearly completely hidden under the poop deck, I saw no reason to make my own. The stern has the ship's name on plaque that was part of the lower cabin window assembly. I made my own frames and trim but I did cut free the name plaque as it is nice and will install it once it is painted and the hull is prepped.
Thank you all for continuing to follow along. I know this has been a slow build so far.
This update has the stern planking, poop deck, and cabin windows completed and ready for finish. I have spun the build board around and am ready to finish the bow and forecastle work. Once that is built, it will be out to the shop for more sanding and sealer.
- md1400cs, Hubac's Historian, KurtH and 9 others
- 12
Not a lot has been done lately as I have been busy on other projects. Now that those are wrapped up, I am back to working the planking ever upward. Hopefully I will be able to top out the stern bulkheads soon followed by the forecastle. Once everything is topped out, I can start working on the decorations.
- Old Collingwood, KenW, Edwardkenway and 5 others
- 8
Beautiful! The weathering is well done. Naval ships were usually well kept by their crews as a point of pride, but natural wear would still be present. I think you are doing an excellent job in showing this.
Working on the upper stern structure. Pierced the last of the gun ports and the four cabin windows in the office quarters. I had to adjust those two down as the drawings showed them in the middle of the poop deck. Also setting the poop deck beams and cutting channels to run the wires for the lights.
Fantastic! Was the year a historical detail or one of your own embellishments? I think it is a great idea either way just curious.
I've had a similar problem with those thin carvings separating. Then the challenge of keeping track of them all and gluing them back in the correct order was also fun. Glad to see your repair went smooth.
Beautiful figurehead! That is exactly what I had envisioned as well. She will look majestic at the bow of your ship.
Modifications are looking good. This has been a detail that has always bothered me on previous builds as most 17th century ships had this mast offset yet I don't know of any kits that are designed that way. Modifying for it always became one of those decisions that I chose to forego and always regretted it.
I personally like the use of various colors and shades on the decorations. I think that instead of leaving the horse and rider white, I would use a light brown and skin tone respectively. I think the white is too white and I'm thinking that if the artists did indeed use colors and not just gold leaf, they would have attempted to paint as realistic as possible.
Being that the horse, is more seahorse than normal land horse, a blue/grey or orange/yellow tint might also be appropriate.
Royal Louis 1780 by EJ_L - Mamoli - Scale 1:90
Building the quarter galleys, again... I’ve had to do a few rebuilds but I am getting there. On the wide blank spaces on the trim as well as the walnut panels below the windows will have decorative pieces that I will carve out of plastic once the wood trim is completed. The upper QG will also have a wrap around rail that will connect to the arched taffrail.
