Posts posted by Brucealanevans
Elijah
thick CA will work well, but it takes a while to set. Hold it in place for a minute or more, then carefully let go. After a minute more nudge it if it has moved and hold carefully a bit more. Once it’s in place don’t touch it for an hour. Don’t ask how I know. It fils gaps. Don’t put them on until you’ve stained the hull. That’s what I used for that piece, as well as gluing the ends on the cannons. For those make sure you have the barrels vertical so gravity doesn’t upset things.
Medium CA doesn’t work near as well.
Epoxy will also work if you already have that.
Thanks John, I appreciate that. One of the bits of fun working in this scale is the ability to push the envelope with detailing.
Downside: those Smithsonian plans were expensive, but I could not have done much of this without them and their wealth of detail. Not enough detail in the two books about the Philadelphia I got.
- John Allen and Elijah
- 2
I've finished the rigging, except for the yard braces and the mainsail boom, which will be added at the very end. The rigging varies from the kit instructions. Firstly, due to what is necessary to handle the sails. I have used the Smithsonian plans for that. Secondly, those plans also show the topmast shrouds passing down to deck level and fastening through bullseyes tethered to the lower deadeye strops. So I did that.
I might add parenthetically that this rigging job was made much easier than my previous jobs due to equipment overload:
1. Michael Mott's third hand, and especially the wood clamp arms that are perfect for holding line tightly for seizing without damaging the line
2. TWO very good tweezers to hand small line
3. Chuck's seizing method - in my hands, a series of closely spaced overhand knots alternating above and below, pulled tight. At the end (4-5 loops in this case) these can be slid down snugly with careful use of a tweezer. followed by some dilute white glue and when dry trimming the ends and compressing the loops.
4. Small electrical clips (the plastic kind with a retractable hook) to hold lines together when seizing if necessary.
Will be moving on the the fore stanchions and rail and rigging the (already constructed) anchors next.
- John Allen, Osmosis, captgino and 6 others
- 9
- Altduck, Elijah, Duanelaker and 3 others
- 6
- Elijah, Tom E, Captain Poison and 1 other
- 4
Daniel:
I will be buying La Real in the near future, as soon as I finish my current build. Will be making a few changes to approximate a Knights of St. John galley.
Is this kit going to also be upgraded to Pear? If so, at what time would that happen, as I would prefer that option if/when available.
Thanks
- Daniel Dusek, Canute, mtaylor and 1 other
- 4
I have made two sails, which are complete except for the boltropes. I don't like the look of sewing them on, as even at this scale the stitches would be out of scale. I have experimented with gluing them on with fabric glue, and will likely do that with a few stitches with very fine fly-tying thread to tack down at least the ends at the cringle. Experimented with white ink pen and pencil line to simulate panels in the sails and ended up opting for the latter. Corner reinforcements were cut out of dyed sail fabric and put on with fabric glue with pencil lines added.
The sails utilized some kit fabric I had from earlier kits, dyed with diluted coffee with a bit of black acrylic to get the greyish tinge as suggested by a build log on this site. I can't emphasize enough how this site and its wonderful contributing craftspersons enable erstwhile beginners like me to progress.
Note the mainsail boom below the mainsail. This is not to be attached to the mast but only to the corners of the sail. I wasn't going to add the sails if I couldn't produce reasonable looking sails, but I believe I'm happy with these and will go ahead.
While I was waiting for the admiral to get back from a trip to sew the sail hems, I put the forestay spreader together. Unfortunately it's very slightly asymmetric, but I can live with it. From this point on there is no major construction, just rigging, canopy, and deck detail things.
Once I get the boltropes on I can bend the sails to the yards and attach all the block pendants, etc, mount the yards to the mast(s) with their rope parrels, and them stick the mast in. Then on to the rigging.
I've been struggling with how to construct the fascines (bundles of wood used to provide more protection for the crew) at an appropriate scale. The 1/16 inch dowels I bought were actually closer to 3/32 and are simply too big (darn!). I experimented with 1/32 x 1/32 strips rounded through a drawplate, and discovered that a bundle of 40 (!) gave me the correct scale size for a bundle of 9" diameter with 1/2 - 1" sticks. I think I will be making fascines during boring parts of long winter nights (I live in Minnesota and it's acting like winter early this year.
A detour to make sails, which I've decided to add. The oars will be stored.
Need to address this before beginning the rigging, as the sails will need to be rigged to the yards prior to erecting the mast and adding the standing rigging. Will also need to order a few more blocks and more line as the model is not equipped for sails.
Also noted on the Smithsonian plans there is a boom to which the lower end of the mainsail is attached, so need to make that.
At this scale going to use cloth instead of silkspan. Dyed appropriate cloth with coffee and a few drops of black paint, and cut them out.
Will be doing some experimenting with the admiral on hemming them - she has a sewing machine foot that rolls and stitches a small seam, but we're not sure it will handle this thickness without fraying the edge. If the experiment fails, will turn and iron a 1/8 inch seam and likely sew it rather than use fabric glue like I did on the Morgan sails.
- Elijah and Tigersteve
- 2
Finished and (temporarily) mounted the rudder with the tiller. Almost forgot to add the nails. That was a bit of a pain.
Added details to the forward cockpit which I felt might not be terribly accessible once I start the rigging. Glued the stove in place with a couple of implements, and added a number of half barrels and a box containing bar shot and balls, as shown on the Smithsonian plans.
For fun, added some fake water in the bailing well along with the water scoop also shown in the Smithsonian plans (which apparently were drawn to guide the construction of the replica).
Now, on to the rigging.
- coxswain, John Allen, Robin Lous and 4 others
- 7
Back from a great Mediterranean cruise on the worlds largest ship with sails.
Back in the shipyard today -
Finished the stove. Bricks made with sculpy formed in the sheet the kit "bricks" of basswood were in. Modeling paste for mortar. Set up a charcoal fire in the stove. Suitably sloppy brick work!
Also added the pintels to the rudder.
- mcpwilk, Chuck Seiler, Tigersteve and 4 others
- 7
Noel, the stain was a mixture of 2 Minwax stains - Gunstock 1/3 and something darker 2/3. Can't find the can at the moment. Stains were suggested in the Ships in Scale series, and I liked how they looked. He was trying to match the look of the reproduction Philadelphia.
Art, to this point most of my additions have been cosmetic - I have added nails (fake, see above) to all planking and fake bolts (see above) to everything attached to the hull, such as the knees, the cathead, and so on. None of this is necessary for the build - I went into this looking to detail alot. The deck in the kit is in several large pieces which I cut into planks and (due to subsequent material loss for each cut) had to fabricate some extra material along the edges. Again, not necessary to the build and requires a precision saw.
Also, as has become my practice, I replaced all the blocks and line with material from Chuck's Syren Ship Modelling. Not necessary but I like the look.
I spend so much time building these that I don't mind spending extra to dress them up, but the stock model material would make a perfectly adequate model.
Added some cannon balls (not in the kit) and some small plastic hinges for the lockers (not in the kit).
I'll be fabricating stuff, such as making bricks for the stove from modelling material rather than the wood pieces the kit provides, as well as bailing scoop in the aft well, and equipment for the guns. Got some barrels too. All of this is eye candy and not necessary for a good looking model at your stage. That was my stage when I started with Picket Boat #1 and then the CW Morgan. I fell off the wagon when I made the Morgan's blubber rendering stove out of 2x3mm individual bricks with spacers for mortar.
The main thing is to have fun!
- Tigersteve and Elijah
- 2
Finished up the cap rail, the catheads, and the tholes, bits, and mooring bit. Put the cleats on the cap rail as well.
The forward facing 12 pounder sits a bit crooked in its carriage as you can see - I'll be fixing that later.
I'm going to depart from the instruction book sequence because I mean to do some detailing on deck supplies and equipment visible on the original Smithsonian plans, and that will be easier without working around the rigging and the canopy supports. So next will be the rudder hardware, the stove, and some other deck stuff.
Meanwhile tho I've tidied everything up and put the tools away as we are leaving on a 2 week vacation. Nice place to pause, as I've finished 5 of the 7 parts of the Ships in Scale series on this build.
Thanks for all the likes.
Does anyone have a favorite very thin cotton material for sails? Silkspan is not appropriate for this scale. Will probably use the same material for the awning - I don't like the stuff that came with the kit.
I've rigged the guns, using blocks from Syren (Chuck) and rope from the same source. Chose to strop with line rather than wire. Appreciate advice in one of Chuck's posts about seizing with a series of carefully placed tight overhand knots rather than wrapping line, with a drop or two of dilute white glue and some compression/shaping as it dries - much easier and looks good to my eye.
Constructed and set up the mast and mast band to the mast partner. At this scale I thought it would be fun to put actual sheaves in the main and topmast, and did so using discs cut off of appropriate sized dowels and mono-filament line as axles.
Lower deadeyes also placed; in this ship they are anchored with rope place through the ceiling planks and hull with stop knots on the exterior.
Will work on the cap rail today, but the shipyard will be closed soon for two weeks as the admiral and I take a vacation (on a five masted sail ship!).
I'm pleased with how it's looking so far.
- coxswain, Elijah, Duanelaker and 4 others
- 7
By the way, I think I made the separator character with an integral sign and strikethrough and italic styles applied. Can't recall for sure.
Interior structurally done, and exterior stained.
I made hauser pipes from brass tubing and glued the kit-supplied end pieces over the ends after the staining (as per the Ships in Scale series on this build, which I have found enormously helpful).
Then built the carriages, glued the cannon tubes together, stained the carriages to match the exterior stain, airbrushed the cannon tubes, and blackened the various bits including the washers for the transverse bolts (I used black covered 19 gauge wire for those) and the trunion caps (used Bluejacket pewter blackener for those as brass blackener won't work on brittania metal), and put everything together. Fasteners for the trunion caps made from a loop of black wire on one end, and brass wire flattened on one end with a hole drilled for the fastening bolt. Nails again simulated with inserted and trimmed monofilament line.
I did not glue the trunion caps down; they can be removed as I will want to remove the cannon tubes during further construction.
- Tigersteve, hexnut, coxswain and 5 others
- 8
Just a comment on the lettering. I used a word cell with black background and white or gold letters and put it on with modge-podge stuff, then flat clear over.
One advantage is the choice of fonts to match the real Morgan. A styilized italic "s" with strikethru style added gives you that divider character on the transom.
You can see the result in my build. If your ebony is true black it should work.
Got the idea from John's Morgan build log.
ALERT
Lesson learned: stain first, THEN place the monofilament pieces.
I thought I was very careful with the glue but still ended up with many halos after first staining. Had to spend time touching up with matching paint. Thank heavens this is a slapdash beat up looking ship and end result was ok.
Will give stain a sanding when dry, then wipe on a light final coat as I did with the inside.
- alde, Allamagoosa and Elijah
- 3
Not my original idea. Chuck showed this on his barge prototype. Unfortunately here I had over 700 to do on the outside (many fewer inside. Just finished this morning.
Did a google for black monofilament line and picked one supposedly 0.4mm diameter and used #76 drill bit. I think it came from Japan.
It's a fun kit because of the scale, although a bit of a monster for the same reason. I have an almost neurotic love of small detail and I think this kit is going to take me down that rabbit hole!
have fun.
Thanks all for the "likes"
- Elijah and Allamagoosa
- 2
Prior to staining the exterior, I've been working on placing the nails for the exterior planking. These were iron and clearly visible, as on the modern reconstruction.
Drilled all the holes with a pin vise, slightly widening the entrance with a sharp awl.
Placed short pieces of black mono-filament held with the needle nose pliers (tweezers don't work due to twisting or "snapping away" of the line piece) illustrated after dipping the end in a drop of CA. Then cut each nearly flush with the flush cutter illustrated. The second picture shows a row of holes, a row filled with the mono-filament pieces, and a row after clipping.
After some sanding with the grain of the planks the look is pretty good (last picture). They will be somewhat less prominent after staining of the exterior.
- coxswain, Ryland Craze, hexnut and 8 others
- 11
Added "nails" for the ceiling and decks with mono-filament line dipped in a touch of CA, inserted into pre-drilled holes, then clipped with a flush-cutter.
Stained the interior. To get the used-up look sanded the central "traffic" areas after the first coat of Minwax stain dried and applied another light coat.
Put in the knees and coaming with nails and bolts simulated. For the bolts cut out small circles with a punch from a card colored with magic marker, punched a small hole in the center with an awl, and slipped over a protruding piece of mono-filament line, glued down, and clipped the protruding line.
Now on the the repetitive job of nails for the exterior planking.
Gunboat Philadelphia by Brucealanevans - FINISHED - Model Shipways - 1/24
Steve
yes the light brown rope. I like it better than the tan.
