Posts posted by drobinson02199
Finished the bowsprit standing rigging (see pics below). The chains are a nice touch, and they are more than decorative -- they do provide a counter force to the upward pull on the bowsprit from the foremast stays.
I found that Mantua didn't supply enough chain to do the job as specified on the plans. Fortunately, I had some leftover chain and used that for three of the top fittings -- the brass in my leftover chains is a nice contrast with the Mantua black chain used elsewhere.
This is my first Mantua kit, and it's about the third place in this kit where I've been short on something. I've concluded that while Amati provides more than you need, Mantua provides "not enough". I'm counting and conserving things to make sure I don't run out.
[Just noticed an unclipped rigging pigtail in these pics -- ]
Regards,
David
- petervisser, Javlin, Tom E and 6 others
- 9
I'm doing this ship differently than the other two rigged ships I've built. On those, I mounted all the yards on all the masts before doing any of the standing rigging.
On this one, in addition to the shrouds on the foremast, I've decided to do the foremast stays as well, and then complete mounting the yards. I'm concerned that if I don't tension the foremast now, I'll have problems in two areas: (i) The remaining yards, which have only the yard lifts for vertical support, might move a bit up or down as the mast is tensioned by the stays, and (ii) I don't want any "wrinkles" in the ratlines due to slight shifting of the shrouds.
So finish foremast stays and bowsprit stays, then hang the remaining foremast yards, and then do the foremast ratlines. Then move on to the main in the same way. We'll see how that works.
Pictures of progress to date on the foremast are below.
Regards,
David
- Henke, GrandpaPhil, tasmanian and 4 others
- 7
I've built the lowest yard on the foremast -- pictures attached.
The brass swivel fitting gives about a 90 degree swing to this yard, which I think could spell trouble while I'm building, so my next move will be to put up the foremast shrouds to give some side support to the yard. The upper shrouds are already rigged so they will support the next yard up, and then the ones above have wooden fittings which will be stiffer. I was originally reluctant to fix the masts too soon as I thought I might want to remove them to mount these lower yards with brass swivels, but now that I've done it it's actually easier with them fitted on the ship.
The swivel assembly on the yard is difficult and a bit fragile -- took a couple of tries to get it right.
Regards,
David
Peter:
Thanks for your comments. In previous boats, I have left the natural wood wherever possible because I too like that look. My Revenge, for example, is all natural vs. white hull, and looks wonderful.
On this ship, however, the second planking strips are not very good, and there was a lot of chipping that I had to fill with wood filler. I have never figured out how to use wood filler on a natural surface, so at the end I was glad to cover this one up.
Thanks,
David -
Chris:
Nothing so fancy. I taper the masts using a rotary drum sander (Dremel size), first square and then octagonal, and then finish with sandpaper. The mast top you see is actually a small spare deadeye I had, with wood filler in the holes. Mantua didn't supply anything in the kit.
Have you finished your riverboat yet? Haven't seen any posts.
Regards,
David
I decided to rig the upper shrouds before mounting the masts, because the deadeyes are very small and it's easier to manipulate the mast while working them. See pictures. One with flash to make the lines show up (but too many shadows), and one without.
I'll do the ratlines once the masts are mounted.
Thanks,
David
Charles:
Well, the square holes in the planking could serve as scuppers, since there are no cannons.
Regards,
David
Charles:
The issue you raise is one I gave some thought to. Thinking ahead, once those ribs are removed, you have some long stretches of planking with no rib support above the deck. So it's important to glue the sides of the planks to each other across that whole length, at least, so they support each other and remain flush.
I went ahead and glued the planks to the ribs, because you want the ribs to shape the run of the planking both horizontally and vertically and keep the planks flush, and I've never been a fan of pins as I find they don't hold. Used CA medium glue. Then, when you are ready to remove the ribs, take a pair of long nose pliers and fix them to a rib lengthwise from the top down to the deck, and wiggle gently side to side to detach the rib from the planks. Then twist the pliers to remove the rib. That will leave a stub at the deck which you can sand or grind down. The sanding doesn't have to be too pretty because that whole area is covered over by a molding later on.
Now that I have typed the above, I belatedly realize that I planked the deck AFTER removing the ribs, as stated in the manual, so that I could plank over the rib stumps and not mar the planking grinding them down flush with a Dremel drum. But again, as long as you are careful to grind them down in parallel with the planks and not extend too far out toward the center of the ship, the molding will cover any marring of the deck. What you can do is punch out that molding and see how far it extends from the planking toward the center, and that will tell you where to be careful and where you can grind away.
Hope this helps.
Regards,
David
- coxswain, Dubz, GrandpaPhil and 5 others
- 8
Cornish Pirate:
I think that's how I did it. Don't have any view on the thread.
Regards,
David
- Henke, petervisser, GrandpaPhil and 5 others
- 8
Re my comments above about drilling holes under the channels for the deadeyes, I used the right size (short) drill on an angle and then angled in the bottom of the chain plate. Worked OK, but some distortion of the rods that I couldn't fix. I did that on the side that won't be visible.
Then I just bit the bullet and used a 1/16 inch drill straight down, which gave a hole a bit too large, but since I was reinforcing these by bending the other wire under the channel, worked fine. A picture of that below.
Regards,
David
I've now pretty much finished all the deck structures and fittings. Pictures here of all that.
Some comments on sequence. I'm not exactly sure why, but I chose to go ahead and do the stern deadeyes early, which was a relief when I installed the curved stern railing. I'm not sure I'd have been able to avoid mangling it if I'd done them in the manual sequence, which is during the rigging stage.
Speaking of those, the manual and drawings show a way to create the chain plate from wire, and then fix it to the deck below the deadeyes, which is conceptually fine for those in the middle of the hull if you have a 3 inch long .75mm drill bit -- mine are shorter, and I'm not sure they exist. I may still do it by drilling on an angle. It still looks like a flimsy fixing for the tension on the deadeyes, so I'm going to reinforce them to the bottom of the channel.
But there's no clear way shown to attach the ones on the stern that you see here -- so I improvised by creating a sort of wire "plug" on the deadeye and gluing that into the hole. I'll do the ones on either side of the hull next, as I won't want to try to maneuver those into place with masts and yards up (which is the way the manual would have you do it).
The other improvisation is the small front railing between the ladders. I lost one of the stanchions on the floor somewhere, and of course Mantua provides no spares. So I had to fashion the two rear stanchions out of wire.
Before I get to the rigging, I need to build the lifeboats and mount them, which is the next step.
Regards,
David
I finished and mounted the rudder, and applied the bow and stern decorations. Pictures below.
The drawing shows the white rubbing strakes running straight to the figurehead at the bow, and the brass decorations on that same line without the bend you see here. While the rubbing strakes would "frame" the top decoration, I'm not sure what the bottom of the lower one would look like. In any event, as I mentioned above, I had missed that in the drawings and terminated the strakes at the end of the hull. So I extended them and applied the decorations as you see here.
Also as noted in my earlier post, the space between the strakes at the stern was not wide enough for the stern decorations, so I had to file them down to fit. That seems to have worked out OK.
Regards,
David
- hof00, GrandpaPhil, Henke and 3 others
- 6
The white rubbing strakes are now on. The manual wants pins to hold the curve, but I steamed the curve into the strips, then painted them, and then used CA glue.
I think I may have ended the strakes too soon at the bow, and if so, I'll fix that later. I KNOW I have an issue at the stern where the width between the strakes isn't quite large enough for the brass figures that go in there, but I ran out of stern to fix the lower strake to, so I'll fix that as well by cutting down the brass to fit.
I need to touch all of this up now with black and white paint.
Regards,
David
- gieb8688, hof00, GrandpaPhil and 4 others
- 7
Back from vacation, and found the extra copper plates waiting for me. Took me a while amidst post-vacation catch up tasks to finish off the coppering of the hull.
That brought me to finishing off the keel, bow and stern. I had planned to use copper tape for that, and as things turned out, it worked really well. I've attached pictures showing pre-taping rough sections, and then the finished product.
Found there was a learning curve in handling the tape to minimize crinkles, but they show up no matter what you do, so I'm glad I used the plates for most of the hull, and equally glad I used tape to finish off the edges.
Now I can go back and pick up the sequence items I skipped waiting for the extra plates to arrive.
Regards,
David
- hof00, GrandpaPhil, Javlin and 4 others
- 7
- vossy, GrandpaPhil, Tom E and 5 others
- 8
- tasmanian, GrandpaPhil, Henke and 5 others
- 8
- gieb8688, coxswain, GrandpaPhil and 4 others
- 7
- GrandpaPhil, gieb8688, Henke and 3 others
- 6
Cutty Sark by drobinson02199 - FINISHED - Mantua/Sergal - Scale 1:78
in - Kit build logs for subjects built from 1851 - 1900
Google says it's "Nannie the witch"
Regards,
David
