el cid
Posts posted by el cid
On 7/31/2020 at 2:13 AM, Blue Ensign said:
In my opinion you can't beat The Cruel Sea, for a realistic depiction of the Atlantic convoy story. A stark depiction of a corvette in the uboat war.
B.E.
And Das Boot (book and movie, not the recent mini series) can’t be beat for its stark depiction of conditions on the other side.
v/r,
Keith
- thibaultron, jud, mtaylor and 2 others
- 5
Nice work, Spits and Mossies, two of my favorites.
I built several of the ICM a/c many years ago and seem to recall a potential issue with fuselage or engine panel fit when the actual engine is used. I think I left the engines out and cemented blanking pieces inside the exhaust openings in order to mount the exhaust pipes themselves. A side benefit is a decent stand-alone Merlin model.
HTH, cheers,
Keith
You might consider using a dark charcoal gray instead of straight flat black for the base paint. Or maybe flat black lightened with some white. This serves two purposes. First is “scale effect,” which kind of mimics the effect of viewing a real ship at a realistic distance. Second is that straight black is pretty stark. IRL, the paint would start looking chalky pretty quickly because of sun fading and salt deposition.
FWIW,
Keith
The Scientific Dos Amigos was my first wooden ship model. It was a gift from my parents when I was around twelve and I recall the thrill of opening the box. The finished model survived in my childhood home until a few years ago when I finally wrote it off. May be primitive by today’s standard, but with aftermarket fittings and rigging, the kit can surely be built into a beautiful display.
Good luck!
Keith
The framers of the Constitution were mostly lawyers, not soldiers.
FWIW,
Keith
- popeye the sailor and Canute
- 2
I’m curious the backstory behind naming a super carrier after Miller. Up until now, heroic and notable naval and marine corps personnel were honored by having destroyers and frigates named for them. Including more than a few Medal of Honor recipients and people of color. Not sure how/why Miller was bumped to the top of the list of heroic figures, but it seems odd. On another site someone suggested it would have been more appropriate to name the lead ship of the new class of FFGs after Miller, I think I agree.
FWIW,
Keith
- thibaultron, Bob Cleek and Canute
- 3
Well, no “tallship” experience here, just small power and sail boats and modern warships. I’ve found that a properly led single figure 8 with a final twist seems to hold most everything fine, even with synthetic lines. As for needing extra figure 8 turns to safely slack a line under tension, in my experience it can be done easily with only half a figure 8 turn around a cleat (and presumably a pin). Even large mooring line tension can be safely slacked with only half a figure 8 on the bitts. It was however common practice to make extra figure 8 turns on bitts when moored.
fwiw,
Keith
- Bob Cleek, BETAQDAVE and Keith Black
- 3
My thinking is the mast would be stowed in the boat or lowered down to the boat crew after launch, then rigged. Seems like a boat with mast rigged and protruding fore or aft would be difficult to maneuver through the ships rigging.
FWIW,
Keith
- mtaylor, Roger Pellett and thibaultron
- 3
5 hours ago, tigerdvr said:
If you use real used oil you will have a new height in realism--smell, odor like only an engine room can have.🛠️
Then the bolt counters will be able to discuss weather it smells correct⚔️
A really marvelously detailed engine.
Cheers, Harley
To me the engineering spaces always smelled like diesel fuel, hot lube oil, and ozone.
Cheers
If nothing else, you might consider doing a “wash” to help make the engine details pop,
I’m really enjoying your build.
Cheers,
Keith
Very nice work, beautiful boat. I’m not familiar with competitive practices at the time, but at 1:1 scale I’ve always put a figure-8 “stopper” knot at the bitter end of my jib sheets to prevent them running loose through the block or fairlead. If a confirmed practice for J-class it might be a nice (and easy) detail to include.
Cheers,
Keith
9 hours ago, Duanelaker said:
I’m struggling with the keel post at the bow...any advice? I’ve made this piece three times now only to have it break on me.
For particularly delicate or small features, I sometimes fabricate it as a larger piece and attach it to the model, then carefully trim, file, or sand it to final size/shape.
HTH,
Keith
- Duanelaker and Elijah
- 2
1 hour ago, popeye2sea said:
Great information! Though I am not convinced about the gun port being closed after each shot. The port would have had to stay open to allow for the rammer, swab, and worm to be able to be inserted into the muzzle for loading the next round.
Regards,
This from page 42; it seems closing the gun ports between shots was situational, perhaps as a ship rolls or comes about in heavy seas?
- jud, Gregory, thibaultron and 1 other
- 4
Pages 52 - 54 describes securing and housing a gun, but I'm having a hard time visualizing exactly how the breeching, side tackles, and train tackle are used in the process. Lots of new terms to decipher. It does mention the use of two different types of wheel chock, which I don't recall ever seeing modeled.
Thanks again for posting this reference.
Cheers,
Keith
Good stuff. The “Boy’s Manual of Seamanship and Gunnery” (found via google) seems to indicate Royal Navy practice was similar (surprise).
As for stowing the guns on actual seagoing vessels (as opposed to static museum ships), a web search for L’Hermione cannon images may give some ideas. Seems that crew often uses the side tackle falls to shorten and secure the breeching line. They seem to secure the guns as I would, using all available lines to help ensure that the thing can’t shift as the ship rolls. I suspect an actual navy crew would have had very specific techniques for doing same.
Cheers,
Keith
Bob, I’ve wondered about this too. I assume when a gun is stowed, the tackle is used to secure it against the bulwark to prevent it rolling about. That would require the line be secured to itself or some hard point (cleated, stoppered, knotted?). Were wheel chocks used as well? I imagine great care was taken to prevent a loose cannon. Leaving a gun untended with the tackle lines just coiled on deck (flemmished or otherwise) doesn’t seem prudent.
Jason, your model is magnificent!
Cheers,
Keith
Re: the use of CA for photoetch, for bigger assemblies/longer joints, after bending and tacking the assembly together, I run a bead of thick CA along the inside (not visible) side of the joint and sprinkle the joint with baking powder before the CA cures. The baking powder causes the CA to set quickly and form a filet, making a more solid structural bond.
Also, those GLS sets can be pretty challenging (IMHO), so don’t beat yourself up if you find them difficult. Looks to me like you’re getting the hang of it.
Cheers,
Keith
- mtaylor, Canute, Old Collingwood and 3 others
- 6
Not an expert, but I suspect some artists use their imagination to create dramatic effect. To me the whole stuns’l apparatus seems rather weak and only suitable for making the most of light winds. I bet they were quickly doused when winds picked up (more likely with any indication winds would be picking up).
FWIW,
Keith
I suspect there’s a market for high quality period figures, there’s just not much available now. With the advent of 3D printing, well-designed figures could be scaled up or down as needed. Can figures be designed as digital models directly or do you still have to sculpt a prototype? If digital only, maybe more economically feasible.
FWIW,
Keith
- mtaylor, chris watton and Canute
- 3
Marine Clothing room configuration.
in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Not sure about storerooms 18 and 19, but have heard references to the Marine Clothing compartment. It’s common knowledge in the US Navy that Marines are fond of wearing pretty clothes, so I suspect room 5 would have shelves for fluffy sweaters, drawers for lacy undergarments, and perhaps hangers for sexy dresses. Oh, and shoe racks for their CMFM pumps. And of course a full-length mirror somewhere on a bulkhead.
HTH,
CPO, USN (Ret)
