el cid
Posts posted by el cid
Jim,
Perhaps my favorite sea story is Monsarrat's "The Cruel Sea" (and the associated stories compiled in "Three Corvettes"). Your North Atlantic convoy paintings really convey the atmosphere of the events he describes. Thanks again for sharing.
Cheers,
Keith
Peter,
Really, really nice build, thanks for sharing your progress and techniques. I did note one very minor issue that you may or may not want to address before you start masting and rigging. Double check your rigging of the steering tackle, I think the lines should run from the top of the steering drum instead of the bottom. Seems the way the lines run now, when the helm is put over in one direction, the tiller will also be pulled in that direction, which will cause the rudder (and vessel) to move in the opposite direction. Again, a very minor issue that few (if any) would ever notice (and I bring it to your attention with some hesitation).
Cheers,
Keith
And re: the presumed reason for painting bulwarks red, i.e., to prevent panic by concealing blood and gore, which I never gave much credence to. Perhaps this has led folks to assume bulwarks were a bright, fresh-blood color of red. But, maybe the “red” was to help conceal the dark, brownish color of dried blood instead? Spanish Brown would be just the ticket for concealing those stubborn hard-to-clean blood stains. I don’t really believe this and continue to think paint color was selected based on CO, XO, or bosun’s preference, local availability, and cost (and later by regulation). Fun discussion.
Cheers,
Keith
- Canute, thibaultron, mtaylor and 2 others
- 5
I’ve been thinking the same, but without any real evidence. Bulwark “red” perhaps wasn’t the relatively bright red commonly used on models, but more of a reddish brown (oxide red) like you show. Nice work looking at actual ship manifests for evidence.
- mtaylor, Canute, thibaultron and 1 other
- 4
I’ve two of these boat kits on order from a supplier in Russia and am looking forward to building them. Even though they are 1/72 scale, I intend to adjust them as appropriate and use them to fit out my 1/64 Syren as the cutter and barge (in addition to the kit-supplied launch).
Would it make sense to also scale these boat kits at 1/64 or is the difference between 1/72 and 1/64 too minor?
Best regards,
Keith
- greenstone, lmagna and Canute
- 3
Sorry for your loss Jack. My condolences to you and your brother's family.
Keith
- John Allen, Canute, Jack12477 and 2 others
- 5
Roger nailed it above. I don't have any experience sailing a square-rigged vessel, but on my little sloop, adjusting the rake of the mast even a little can noticeably change the way she handles.
Below is a relevant excerpt from a message sent by Lt. Stewart, Commanding US Brig Syren to Captain Preble in USS Constitution on 01 January 1804 (during the Barbary War, sourced from the US Navy History of same)...
"The 27th we sailed and kept company with the United States Brig Argus until the 29th. At midnight, a severe gale of wind came on with a tremendous sea that hove the Syren on her beam ends and filled her waist full of water. We got her before the wind, knocked out some of the ports, and freed her decks. The jolly boat was stove to atoms and lost. Nothing but strong gales from the westward, with heavy squalls (that prevented our carrying any sail but storm stay sails) prevailed from the 2nd of December to the 12th, during which time we were driven considerably to the eastward and all my officers sick but two young and inexperienced midshipmen."
Later in port...
"I immediately commenced the necessary repairs that the Brig requires. She leaks very much in her upper works, which has damaged some of the provisions and other articles. I am therefore under the necessity of caulking. Her rigging we take this opportunity of overhauling and also to shift her main mast further aft, which it requires, and feel confident it will much improve her sailing. I left at Leghorn Robert T. Spence, Midshipman, whose mind had been for some time deranged. He is a son of Mr. Spence, Purser of the Philadelphia".
Cheers,
Keith
- mtaylor, Roger Pellett, trippwj and 3 others
- 6
Looks really good. Seems the gun ports would be closed when carrying a boat at the stern.
Cheers,
Keith
Nice subject and interesting box-type bulwark construction, looks like its coming together nicely. Any indication what scale it is? Thanks for posting and please continue as you progress.
Cheers,
Keith
- thibaultron, Nirvana and Canute
- 3
Thanks for the replies. To help illustrate my confusion, below is the relevant section of the drawing from Chapelle, an unknown model of Syren from the web, the USNA museum Syren (Lightly model), and the MS Syren configuration (Chuck's interpretation). I'm still conflicted on exactly which deck opening(s) would most likely be used for access below (i.e. the ladderway/companionway) and which (if any) would be a skylight for below deck lighting/ventilation.
Any thoughts welcome.
Cheers,
Keith
Mondfeld in "Historic Ship Models" (p. 144) indicates that an opening in a ships deck to allow access below is either a "companionway" (merchant ships) or "ladderway" (warships). He then describes a "companion" as an opening in the deck of a warship that provides light and ventilation and is normally covered by a removable "skylight" but that is not a ladderway.
I ask because the plans for SYREN provided in Chapelle's "History of the American Sailing Navy" (p. 185) indicate both a "companion" and a "skylight" aft of the capstan, but no ladderway. Trying to reconcile with Chuck's plans (ie. did Syren have a skylight too?).
Any insight appreciated.
Keith
I think the lines attached to the anchor cable are "stoppers" (not sure how/if different then "nippers"). They are made fast to iron rings on the deck then secured to the anchor cable to ensure that an anchor can't run away if it somehow breaks loose. On modern ships chain stoppers and pelican hooks are used.
HTH,
Keith
Looking very nice. Re: the anchor stowage, I'll offer my opinion as a retired US Navy Sailor and as a private recreational sailor, not as an expert on period ground tackle practice. Number one rule when getting underway was/is to secure all gear (especially heavy items) for sea. Sometimes there isn't a dedicated storage space (or rack, cradle, fitting etc.) for all equipment, but sailors will be creative in finding a way to secure things to whatever is available...often involving the liberal use of rope. So, I suggest just putting yourself in your miniature bosun's place. How could/would you secure that anchor with the available fittings? I would keep in mind that you shouldn't secure to anything that would interfere with operating (or fighting) the vessel. Also, small ships pitch and roll a lot (sometime a LOT), consider how well your anchor will be secured against heavy rolls. And don't forget possible chaffing, ropes would be protected where they lead over edges on which they might rub. I suspect there is no absolute right way of securing that anchor, it would be the preference and judgement of the bosun and first lieutenant...now you.
FWIW,
Keith
Re: ship's lights. Below is a transcribed diary entry from a midshipman in SYREN during her expedition with INTREPID to burn the frigate PHILADELPHIA. I did my best to interpret the 12-hour clock times given to 24-hour time. Second para mentions lights, but doesn't indicate where they were displayed. Taken from "Naval documents related to the United States Wars with the Barbary Powers" five volumes of which are available online. Many interesting SYREN factoids within...grueling schedule for the small US force involved.
Midshipman F. Cornelius deKrafft
16 February 1804
Commences with fresh breezes, clear and pleasant weather. The Intrepid in company. At 0230, made the land on our lee bow. Hauled up the mainsail, took 1 reef in the topsails, and bent the stream cable. At 0330, backed the main topsail for the Intrepid to come up. At 0400, lowered down the cutter and sent 9 men on board the Intrepid with cuttlasses, pistoles, musquets. etc. At 0430, the boat returned, hoisted her up and made sail for the land. At 0530, mountain Togura (6 or 8 miles to the E of Tripoli) bore SSW, town of Tripoli SW. At 0600, tacked to the NW. At 0730, boarded main tack. At 0930, tacked to the SW, set staysails and jib. At 1000, called all hands to quarters and run out the guns, hauled down staysails and jib, and hauled up square mainsail, brailed up after mainsail. At 1030, spoke the Intrepid. At 1100, backed the main topsail, sounded and got no bottom.
Midnight moderate and clear, lost sight of the Intrepid. Hauled up the foresail, backed main topsail, sounded in 35 fathoms and filled away. At 0100, sounded in 14, 12, and 9 fathoms (from 0100 to 0400 standing off and on the shore). Showing lights for the Intrepid (which were answered). At 0100, called all hands to quarters, run in the guns and secured them, shipped the ports, wore and stood off shore. Made sail, the Intrepid on our lee bow. At 0800, the high land near Tripoli bore SW by W, 7 leagues. At 1100, the Intrepid tacked to the S and E. Noon, wore to the S and W, handed square mainsail, reefed the foresail, and set after mainsail. Moderate breezes and pleasant. The Intrepid bearing S ½ E, 8 miles distance.
These are amazing works of art, thank you for sharing. To me your talent is simply magical.
Warm regards,
Keith
- CaptainSteve, mtaylor and Canute
- 3
"Gathered 3 threads and twisted clockwise until they wanted to kink, and tucked it in my hand until I had all 3 twisted to the kink point, laid them together and from the end twisted counter clock wise, had what I needed. With the addition of some more hands or holding devices you can make rope without a rope walk".
This is the same general process for I use for making up "Flemish twist" bowstrings, although I can't imagine starting out with thread. Archers also serve the center portions of their bowstrings. Not sure how ship modelers begin and end their servings, but this link provides an elegant (IMHO) method used for bowstrings. Perhaps of some use to others (and I apologize if this is old news).
Keith
Hey Mike,
Are you familiar with the crew manual at Brig Niagara website (http://ssvniagara.com/wp-content/uploads/2017/02/niagara-crew-handbook.pdf)? On page 45 it provides a belaying diagram that shows the topgallant halyard (I think that's what your diagram is describing) belayed to a pinrail on the starboard side. Don't know which source should be judged most definative, but perhaps an option.
HTH,
Keith
I'm no expert on the rigging question, but considering the purpose of this line, I would think it would be cleated off on something, not half-hitched to itself. Would it be wrong to have a cleat mounted on the mast there?
Sorry I can't help resolve conclusively (but you probably won't go too astray if you think like a sailor, they were/are pretty practical).
Cheers,
Keith
- thibaultron and mtaylor
- 2
Good discussion and I'll add my 2 cents re: the "flemishing" of lines when not in use. I doubt this was common practice, except as someone mentioned, in preparation for an inspection or other ceremony when not underway. For longer lines that needed to run cleaning and quickly, "faking" the line on deck ensures it runs without twisting or tangling, flemishes don't necessarily run out cleanly. A longer line might also be neatly coiled on deck in what we referred to as a "birds nest." Warships are typically kept clean and orderly and I doubt lines were left faked, coiled, or flemished on deck for significant periods of time. Ships are very dynamic (rocking and rolling, shipping water on deck, etc) and crowded, so prudence would dictate that everything is well secured when underway. Found the below image from a modern US Navy training manual:
Cheers,
Keith
- Mark P, john_wilmer, thibaultron and 1 other
- 4
Hi Scott,
I'm new to NRG and wooden ship modeling, but have dabbled in plastic and resin for some time. If you're not aware, there's another modeling site that tends to focus more on "modern" warships, primarily plastic and resin, and I've found the guys there very helpful (like NRG guys). There's actually a specific thread there on the Queen Elizabeth class battleships:
(http://www.shipmodels.info/mws_forum/viewtopic.php?f=47&t=4719)
If you don't get a response here, you might try asking over there. Moderators, I trust I'm not violating forum policy by linking to another site, if so please delete and I'll refrain from doing it anymore.
HTH,
Keith
It seems common practice for modelers to leave their vessel's false keel "un-coppered", however the "General Instructions for building a Sloop of War" (appendix p. 517 in Chapelle's "The American Sailing Navy") states "The false keel as well as the bottom of the keel to be coppered before they are fastened together." I can't find any further info re: these "General Instructions" (Chapelle doesn't provide the source or date of this reference), so was hoping others here might provide insight on the applicability of coppering the false keel.
Cheers,
Keith
Securing anchor to chain plate or hull,what knot is used-not the anchor bend.
in Masting, rigging and sails
Posted · Edited by el cid
I don't know a reference or specific knot, but will offer that when underway in open water where the anchor wouldn't be readied for use, it would be very well secured with multiple lashings to minimize any chance of the anchor shifting (at least that's how this seaman would do it). I also understand that for extended offshore sailing the anchor cables would be untied and stowed below and the hawse holes plugged. Depending on the layout of the ship and availability of suitable hardpoints (e.g timberheads, cleats, etc), I would think multiple turns of a line around the anchor and hardpoint then maybe finishing on the timberhead with a clove hitch or on itself with some half-hitches.
HTH,
Keith
