KHauptfuehrer
  • Content Count
    162
Posts posted by KHauptfuehrer
  1. A note about the bowheads.  The plans given in the instructions reflect their present configuration.  There is no scale given, but after I completed my bowheads, I measured them, and compared them to the elevations, and they matched.  So you can use the drawings as they are for your construction.  Speaking of looking ahead, I decided not to permanently mount the seats of ease, or enclose the bowheads in order to facilitate installing the gammoning.
  2. Very nice job on the deck.  The beams look great, and I do not see any seams between sections of decking which is amazing.  The glued up decking I used was not long enough to run fully fore to aft, which, I must admit, was one reason that I left the waist unplanked.  As for the instructions, I found that not only are there gaps in the information needed to do all the detail, but there are actually wrong procedures which can lead the builder to make mistakes which can result in a cascade of problems which require considerable ingenuity and creativity to rectify.  I would also recommend to anyone about to build this kit to get the Marquardt Anatomy of the Constitution, and also buy the Revell plastic model to use as a reference.  Thanks so much for your gracious compliment.
  3. Stern sheet bench, thwarts, mast step, breast decking, and exterior bulwark strakes installed.  Stern sheet bench was cut out from 1/64" birch plywood.  Thwarts, mast step sides, and breast decking are 3/32" by .020" basswood planking stock from Bluejacket.    Now to cut the oar locks.  Bluejacket provides enough Britannia oars to put 6 in each boat.  Rudders will also be added.  I have sanded the outer hull with #400 grit sandpaper to take off the shine so that the paint will stick.
    568634712_CALDERCRAFTPINNACECONSTR_4AS.thumb.jpg.41906ca8910cf4f21f9d6b8836baa0b0.jpg
  4. The port open foot walings and rising strake installed.
    742914823_CALDERCRAFTPINNACECONSTR_2S.thumb.jpg.f0e5178293919c5e7063b8354d4cf79b.jpgT
    The breast and stern foot walings have been done in the same manner as the ones in my first attempt at a Pinnace build, except that the details were first printed on  brochure paper, the design treated with flat spray fixative, and then glued onto 1/64" birch plywood as in the whaleboats/gigs.
    1822156277_CALDERCRAFTPINNACECONSTR_3S.thumb.jpg.db905c6e4cdf8927322642ba8b340574.jpg
  5. I decided to install all the loose foot walings and the rising on one side first, then do the other side, applying lessons learned from the first side.  These foot walings are .020" by 1/16" basswood planking stock from Bluejacket instead of card stock, which sagged a bit between ribs in my last attempt.  The ribs in the Bluejacket casting are straighter, but these are closer to being in scale.  My 1/32" inboard gunwale strake deviates much less than the one in the Bluejacket casting, and therefore will not interfere with the installation of the breast decking, the thwarts, and the stern bench, which will sit on the rising (identified as the clamp in the instruction book).  The splash strake will be painted only after the external gunwale strake has been installed, and the oar locks have been cut.  The slightly flatter bottom of the boat shape allowed all the waling strakes to be installed more easily.
    1081308440_CALDERCRAFTPINNACECONSTR_1S.thumb.jpg.a07a656fb371e197af31b073325702f5.jpg
  6. Here is less my less than prize winning first attempt at ribs for the pinnace.  I submit this in the hopes that another novice out there might be alerted to possible pitfalls this method may pose.
    I determined the spacing with  dividers set to match the plan, which I scanned from the instruction booklet then sized in Corel Draw to match the 1/96 scale. Those plastic strips bend every which way, and I found that keeping them straight while handling the casting, the ribs, and the CA glue dispenser simultaneously was a real challenge.  One advantage of the Bluejacket casting is that you can fix the attached block of resin in a vise.  I finally found that clamping the rib on one side and holding it with my finger on the other side. worked better.  The first 5 ribs forward and the last 2 ribs aft were done that way.  I tried to free the broken rib with CA debonder to no avail.   I do not know what to call the extra ribs that help support the foot waling, so I will just call them waling ribs.  These were glued in at the center line and left extra long and loose at the outboard end, so I can trim them once I have determined how long they should be. To do this, I plan to temporarily install the foot waling strakes with rubber cement, mark the proper length, remove the walings, cut the ribs, then glue them down.  This done, my boat project will hopefully look better than it now does.   The next time I do this, I will adopt Geoff's suggestion of grinding the clothespin jaws to match the curve of the boat's hull.  While I am at it, I might also try cutting off the nose section of the jaws, so the occluding part is visible as I work.  I felt that I was "flying blind" much of the time while using the clothespins.
  7. That is great advice!  Thank you so much!  I have just finished doing the ribs on this boat, but I will definitely try your techniques on the next one.  I think I got the spacings right, but did not always get the ribs to lie perfectly straight.  I thought of using a spacer, but could not figure out a way to avoid gluing it in along with the rib with the liquid CA glue I was using.  As soon as I glue in the inboard gunwale strakes, I will post the results.
  8. I ordered another casting of the pinnace from Bluejacket in the hopes that the deviating inboard gunwale strake described above was an anomaly.  As always, I found the folks at Bluejacket to be both accessible and friendly.  I appreciated the fact that they made several castings to select the best one for me.
    934518138_BJPINNACENEW1S.thumb.JPG.03aaf111d459187fae03db85e36bffc5.JPGUnfortunately, as you can see, the gunwale strake deviates up and down as before.  This would not be a problem if the strake was 1/32" wide as it is in the plan.  However, the width of the strake (1/8") puts its bottom edge at the level that the thwarts are to be installed.  If the plan is to be followed,  these thwarts must therefore butt up against the bottom of the gunwale strake.  Consequently, the deviation seriously interferes with the proper installation of the thwarts.
    I therefore ordered a boat shell casting of comparable size from Caldercraft.
    72329483_CALDERCRAFTPINNACE1S.thumb.JPG.2d8b7c31c29a1aaef300097a9eb21d69.JPGAs you can see, this is a clean cast.  No filing, filling, shaping, or sanding needed here.  The obvious disadvantage is that now I will have to do the ribs, keelson, stemson, and sternpost knee myself.   Also, the boat is cast to a different scale, and is 1/8" too short, so, if I use it, my Constitution will have a 35' pinnace instead of a 36' pinnace.  Comparing the shape of each casting with the plans, I see that neither casting matches the plan exactly, but I think that the Caldercraft is a bit closer.  It looks like I will have a bit more room to install the foot waling strakes to get the proper number.
    111938430_PINNACECOMPARISON.thumb.jpg.9bf2ac86e8fb58c3cd5dd6e26c712209.jpgThe
    The obvious disadvantage is that I will have to do the rib, keelson, stemson, and sternpost myself if I use the Caldercraft.  If I continue with my modeling, I will need to acquire these skills at some point anyway, so I might as well have a go at it.  The plan is to do these details and see which pinnace looks the best.  Accordingly, I ordered .020" by .030" by 14" styrene strips from Evergreen scale models.  Here goes...
    I am almost done with the ribs.  I will post the results when I complete them.
  9. I have only recently realized that the three smaller boats that I have been working on are not whaleboats.  They are captain's gigs.  Although both types of boats are double ended, they are shaped differently, and whale boats do not have splash strakes fore and aft as the gigs do.  The  planking pattern of the stern benches and the bow decking are also different.  The pattern I have reproduced here are for whale boats.  Too late to change one of them to the gig configuration now.  Oh well... Also, whale boats have a bent sternpost essentially identical to the stem, and gigs have a straight stern post.  The cast gigs supplied by Bluejacket most closely resemble gigs, but their stern posts are only mostly straight.
    1209162777_BOATSTERNS.thumb.jpg.8ffe95e1a856ad4222e40068b7769c5f.jpgAnd so the question arises - which type of rudder to use: the one pictured above for a straight stern post, or a paddle shaped one suitable for a bent stern post?  I opted for the design pictured above which is scanned from the Marquardt, imported into Corel Draw, and sized to scale, then printed out on card stock to make a template.  This design is to be used for all four boats. Mounting the rudders on the boats is problematic, because their stern posts are "neither fish nor fowl".  Fortunately, it was customary to stow the rudders inside the boats, so this is what I will do.
    Four rudders were cut out of 1/64" birch plywood, and notched to accommodate the pintles.  1/16" lengths of .020 brass rod were cut for pins and glued to the forward edges of the rudders so that 1/32" would protrude downward into the notch.  Pintle straps were made from brochure paper which had been printed black on the computer, then coated with satin varnish.  The rudder post was cut into sections and a piece of card stock painted black and cut into 1/16" strips glued to either side so that a 1/32" gap would be created into which the tiller would be inserted.  I wanted to make them so that I can either insert the tiller(s) into the rudders, or display them side by side.  The tillers were made form 1/32" x 1/32" basswood stock rounded at one end by twirling it with one hand and  holding the other end against sandpaper with the other hand.
    1123961481_BOATRUDDERCONSTR.1.thumb.jpg.bf568083ac444dc05297f360cbf1b04e.jpg.
  10. I tried the decals, and I prefer the method shown above.  The decal darkened the items on which it was applied slightly making a color match difficult.  With several trials and errors, I did manage to match the color of the printed design to the painted wood pretty well.
    The nice thing about the whale boat castings is that the raised floor made it easy to install thwart stanchions.  Just drill the hole, insert brass rod, and paint.
    1775309296_WHALEBOATCONSTR_5B.thumb.JPG.454f92b2c868190db4849c796a6b7e5b.JPGGetting the thwarts done was more challenging.  I used 3/32" by .020" planking stock from Bluejacket.
    Here is another shot which shows the thwart stanchions.
  11. I recently came across a discussion in which there was a posting of one of my build photos to illustrate a point.  It was taken down by admin. because I had not given permission to use it.  I hereby give permission for my photos to be used.  Even if it is to illustrate what not to do, I am OK with it if it will help someone else in their modeling endeavors.
  12. While waiting for the decal supplies to arrive from Micromark, I have gone ahead with the plan to print out the design on brochure paper, then glue it onto a 1/64" birch plywood backing to see if I could implement the plan effectively.  I made up the stern sheet foot waling, the stern sheet bench, and the breast decking and placed them into the boat casting.
    I will do the same when I get the decal supplies to see which looks the best.  Incidentally, I did try to cut up a stern bench into planks, paint them, blacken the edges, then glue them back together onto a plywood backing, to see if I could pull it off at this scale.  I couldn't.  Perhaps, as my skills improve, I will be able to do that sometime in the future.  Now to do the thwarts...
  13. Illustrated here is my scheme for getting the detail I want for the stern foot waling, the stern bench, and the breast decking.  Scans of the plans from the instruction manual, and a photo of the boat are imported into Corel Draw and sized appropriately.  Using drawing tools, the lines in the plans are duplicated (1), then transferred to the photo (2) for  adjustments if needed.  That done, I transfer the drawing onto a background colored to match MS Bulwarks Brown (3).  This is printed out on brochure paper.  The plan is to cut them out and glue them to 1/64" birch plywood.  I have also ordered a decal making kit from Micromark.  The designs would be printed out on the decal sheet, which would be applied to the plywood which has been painted with MS Bulwarks brown.  Let's see which looks better.
  14. Work on the whale boats continues.  Interior of the boat is painted.  Unfortunately this process reveals a plethora of little anomalies and irregularities in the casting process which I have neither the tools nor the skills to smooth out.  I have done some cleaning up with the metal castings, but resin is a different animal altogether.  The exterior will be painted just before installation on the ship.  Two of the boats will be white, and one green as is currently the case on Constitution.
  15. Thanks so much, Jim, for your kind words.  I left them out on the gun deck because I could not find space for them because of the knee details, and because of the manner in which I rigged the guns.  Nor did I see space for them on the spar deck because of the pinrails, and, again, because of the gun rigging.   I could not imagine fitting them under the pinrails, and still having room to belay the lines.  Also, because I am a novice, I shied away from tackling that challenge.  My hat is off to you if you pull that off.   I saw Lawrence Arnot's model when I visited the Constitution museum.  He glued them directly onto the deck.  I am following your build with great interest to see how you deal with the unique challenges posed by this kit.  I see you have completed the coppering.  It is excellent!
  16. The boats provided by Bluejacket are resin castings.  Details include inner bulwark molding, ribs, stemson, keelson, and sternson knee.  As far as I know, Bluejacket is the only company that does this.  It save a whole lot of time.  The builder makes open waling, stern foot waling, breast foot waling, stern bench, and breast decking, thwarts and their knees, and rudder from scratch.
    The whale boat castings are different in that they have a raised flooring.  This means that the thwarts, stern bench, and breast deck must be located closer to the top of the gunwales than is the case with the real boats.  I do not see how I can include thwart knees.
    The boats provided in the kit originally were full of holes, presumably caused by bubbles.  Bluejacket graciously agreed to replace them.  I subsequently saw a notification on their website that it will be up to be builder to fill in holes with putty.  The whaleboat castings are great, but the pinnace was severely misshapen upon arrival.  I ran it under hot water and was able to bend it back to a reasonable shape.  I decided to attempt completion of the interior details.  The thickness of the inner components of the real boat is no more than an inch.  1/64"  plywood is thinnest wood stock I know of which, at this scale translates to 1 1/2" so some of these elements are made of 67 lb card stock, printed in the right color by a laser printer, and sprayed with fixative.  Such is the case for the open foot waling of the pinnace.
    To get the details of the stern and breast foot waling, the boat plans in the instructions, which are detailed, but not to scale, were imported into Corel Draw and sized to match the casting.  Lines were drawn over the ones in the plans, then separated as a unit from the plans and superimposed over a rectangle filled with the appropriate color (to match MS bulwarks brown).  These were then printed, sprayed, and cut out to get this result:
    Edges of these elements were painted bulwarks brown.  The long open foot waling strakes are to be added after the rising is in place.
    3/64" wide by .020" thick planking strips from Bluejacket are to be used to construct the rising.  The plan is to install the thwarts just below the inner bulwarks molding, with the rising just underneath.  In attempting this, a possible fatal flaw in the casting became evident.   On the starboard side, the molding deviates up and down.  It also joins the stemson at a different level than the port molding does.
    1839935515_PINNACE4.thumb.JPG.74c672f1fb3225d9a812540950358db4.JPG1436007452_PINNACE5.thumb.JPG.fee6825541da464bc1a8eb95a5413622.JPG Oops!  What to do?  I have ordered another Pinnace from Bluejacket.  If that does not work out, perhaps one of the lifeboat kits from MS might work.  One of them is approximately the same size.
    Meanwhile, I might as well start work on the whaleboats.  I soaked the above described planking strips in water then clamped them to be boat to get the curve.
    They were subsequently trimmed and glued in place.
Our Emblem
